engine cooling on a snow wheeler - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Snow Wheelin'
Old 09-12-2019, 06:37 AM   #1 (permalink)
Member # 172738
currently building a buggy/cabtruck and wondering about rad location
rear mount would give me the biggest rad but im concerned about when moving slowly along is the fans going too be running constantly too keep it cool?
front mount is very limited for space, but would a large oil cooler make the difference?
junkyard bone stock 5.3
lwb86 is offline   Reply With Quote Quick reply to this message
Old 09-12-2019, 06:40 AM   #2 (permalink)
Member # 172738
picture of said cabtruck/buggy thing
Old 09-12-2019, 06:42 AM   #3 (permalink)
KacksterK5's Avatar
Member # 5851
Rear rad with fans running at all times should be fine.
02 Chevy 2500 HD Tow Rig
KacksterK5 is online now   Reply With Quote Quick reply to this message
Old 09-12-2019, 06:49 AM   #4 (permalink)
Member # 172738
i guess my next question is do I want to rely on the fact that my fans would have to be running all the time? should I be adding a backup ?
as pictures show it pretty much a blank canvas just axles motor and cab suspension tacked in for mockup
Old 09-12-2019, 07:34 AM   #5 (permalink)
Member # 312354
pipe the coolant through some aluminum tubing underneath and let the snow help your cooling system, just like a snowmobile.
ironmangq is offline   Reply With Quote Quick reply to this message
Old 09-12-2019, 10:03 AM   #6 (permalink)
snowracer's Avatar
Member # 141697
run the biggest rad in the back with good quality dual fan set up and you will have no issues. just make sure you do a good shroud so that the fans pull the air through the rad and not from around it.
PLAN-B F250 on 44s
snowracer is offline   Reply With Quote Quick reply to this message
Old Yesterday, 06:53 AM   #7 (permalink)
gumboot cloggeroo
Muckin_Slusher's Avatar
Member # 467233
Yep. Can also make/buy a giant snowmobile style heat exchanger. Thick chunk of aluminum for a skid plate with square extrusion tubes welded to it. Or you can buy bulk extrusion. Weld it to skidplate with heat sink compound between exchanger and skidplate, or drill skid plate and do lots of plug welds.
https://crracingcanada.com/products/...=5726667046940
As for "emergency" situations with a busted or non-running fan, if the rad is mounted horizonal you can shovel snow on it. Can even make a box to fill with snow on top of rad. We do this for snowmobiles when crossing glare ice lakes. The skid plate should naturally load itself with snow. Probably wouldn't even need the rad when in snow.
Either way, note that you will be making TONS of liquid water, which if in very cold conditions can freeze up causing issues. I doubt "sno mexico" gets 40 below like we get.
Muckin_Slusher is offline   Reply With Quote Quick reply to this message
Old Yesterday, 08:04 AM   #8 (permalink)
Member # 212988
I run a Griffin 14x16 I can look up the part number if you need it but with a mechanical fan I have zero cooling issues. What makes you think you need a huge radiator?
HankScorpi0 is offline   Reply With Quote Quick reply to this message
Old Yesterday, 09:02 AM   #9 (permalink)
Member # 172738
If your running a v8 with a 14x16 rad with no issues Iíll take that part number
Old Yesterday, 09:06 AM   #10 (permalink)
Member # 172738
Iím two hours from the Bc/Alaskan border
Old Yesterday, 10:04 AM   #11 (permalink)
Member # 212988
My bad its 22x15.5
475-1-58181-XLS
