Samurai buggy... less, is more. - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-01-2014, 02:09 AM   #126 (permalink)
Member # 213773
Kawasaki 800 burnout - YouTube
jaredsamurai is offline   Reply With Quote Quick reply to this message
Old 04-01-2014, 12:26 PM   #127 (permalink)
mikeb273's Avatar
Member # 98652
The old KZ is probably a blast to ride! I assume it is lightning fast. And the old shovel gets bonus points for having dogbone risers...PIMP!
Cool bikes for sure!
mikeb273 is offline   Reply With Quote Quick reply to this message
Old 04-07-2014, 10:19 PM   #128 (permalink)
Member # 213773
This guy lets anyone drive his rig
Old 04-08-2014, 02:05 AM   #129 (permalink)
adamwende's Avatar
Member # 193461
At least she found 4low!
AZ Undertaker
adamwende is offline   Reply With Quote Quick reply to this message
Old 04-08-2014, 02:27 AM   #130 (permalink)
dogonmut's Avatar
Member # 125047
Big pile of douche-ness in that pic.
dogonmut is offline   Reply With Quote Quick reply to this message
Old 04-08-2014, 02:30 AM   #131 (permalink)
adamwende's Avatar
Member # 193461
Says the guy with a soft taco for a front wheel! Post up pictures if you or Chris got any.
AZ Undertaker
Old 04-08-2014, 11:31 AM   #132 (permalink)
Member # 213773
Touché
Old 04-08-2014, 12:07 PM   #133 (permalink)
dogonmut's Avatar
Member # 125047
It's only a slight tweek.
That's the only pic I took.
Old 04-23-2014, 02:35 PM   #134 (permalink)
adamwende's Avatar
Member # 193461
Did some wheelin over the weekend. Broke a steering stud, but replaced quickly. Probably should reinforce the arms somehow.... It was an awesome day of wheelin.
AZ Undertaker
Old 04-23-2014, 02:45 PM   #135 (permalink)
adamwende's Avatar
Member # 193461
AZ Undertaker
Old 04-23-2014, 02:49 PM   #136 (permalink)
adamwende's Avatar
Member # 193461
AZ Undertaker
Old 04-23-2014, 04:48 PM   #137 (permalink)
Member # 127171
Über jealous of your wheeling. Sweet pics. Is the gap on the hood bc it wouldn't reach when dove nosed without bringing the front in a few inches? I want to dove the hood on mine, but not much of a body man.
sleepsontoilet is offline   Reply With Quote Quick reply to this message
Old 04-23-2014, 06:40 PM   #138 (permalink)
adamwende's Avatar
Member # 193461
I do love the wheelin out here! Yes, that gap is from when i narrowed it. I'm not sure if i'm keeping the hood or not, I'd like to start with a cleaner one. Welding a beer can with a 220 welder brings the suck as well. I just wheel it as is for now.
AZ Undertaker
Old 04-23-2014, 07:14 PM   #139 (permalink)
Member # 127171
Mine has a few big holes in it, not looking to welding it with flux either.
Old 04-23-2014, 08:00 PM   #140 (permalink)
dogonmut's Avatar
Member # 125047
6 shooter knuckles with ARP studs, new cone washer and 25MM trunnions from Marlin. Problem solved.
I hit that rock that bent my wheel at 30-35 MPH. No issues with the steering at all.
You will have to machine the 6 shooter arm to accept the larger trunnion.
The trunnion on the left is the chromoly Marlin part. The trunnion on the right is the stock sized, who knows what metal.
Old 04-23-2014, 08:15 PM   #141 (permalink)
Member # 213773
That would double the cost of his buggy.
Old 04-23-2014, 09:10 PM   #142 (permalink)
adamwende's Avatar
Member # 193461
I'd have to wait years for that to be free...
AZ Undertaker
Old 04-23-2014, 09:13 PM   #143 (permalink)
adamwende's Avatar
Member # 193461
I keep thinking one tons and 42s would fix the stud issue..
AZ Undertaker
Old 04-23-2014, 10:18 PM   #144 (permalink)
dogonmut's Avatar
Member # 125047
That'd do it.
I waisted tons of money, time and friends patience dragging me to my trailer trying to make Toyota axles work in the HomeWrecker. The fix was Dana 60ies.
The only upside of all my axle building and swapping is the bitchin' front axle that migrated to RatZuki.
My recommendation is not to put 1 dime or any effort into Toyota axles and go with 1 tons. You will be money ahead in the long run.
Old 04-23-2014, 10:36 PM   #145 (permalink)
Member # 213773
ratzuki gots chromos and all the other goods?
Old 04-23-2014, 11:44 PM   #146 (permalink)
dogonmut's Avatar
Member # 125047
Yep. Long inners and Dirty30 outers. The locking hubs have 6 5/16 dowel pins instead of the 2 8mm factory pins and chromo hub gears. The knuckles were cut and turned to 17*. The drain plug was removed and filled in with a plate, then a 5/16 plate was bent to the shape of the bottom of the pumpkin and welded on as an additional skid. It has a cut down ZOR crab and the ram mount is a 1.5od .188 wall chromoly tube with 1/4 plate. The knuckle balls are guesseted and the axle is trussed and plated on top. Longfield wipers, TG backing plates, Koyo bearing, 3/8 thick link tabs and 1/4 thick shock tabs. And of course Marlin 25mm trunnions and 6 shooter knuckles with ARP hardware. additionally all other hard parts were replaced with OEM Toyota parts. I'm sure I'm missing a few items.
I built it for the buggy that kept bending Toyota housings so I wasn't f&@king around.
Old 04-23-2014, 11:48 PM   #147 (permalink)
Member # 213773
Good thing! Those 31's will tear up stock yotas. Teeheeeheee how long did you think I was gonna go before that came up?
Old 06-16-2014, 09:39 AM   #148 (permalink)
Member # 203500
Fifth stud solved my steering stud problems with full hydro
Do the fifth stud kit. The fifth stud can be a huge grade 8 bolt and because it is riding on a different plane than the 4 stock steering bolts it is quite strong! It has been argued stronger than the 6 shooters somewhere here on Pirate. I will link to it if I find it again.
Truggy33 is offline   Reply With Quote Quick reply to this message
Old 06-16-2014, 09:23 PM   #149 (permalink)
Member # 20490
Send a message via AIM to clemsonjeep
This is where i check out...the one ton debate is a hard one. I guess i can see where they make more sense out west where you typically dont have to fight for traction. Here inthe southeast its interesting to watch a samurai rig with one tons attempt a climb thats moderately slick and then watch one with yotas on the same climb. The difference is huge...the extra weight really becomes an issue and you can tell the rig is having to work so much harder.
Was your stud a stockone or ARP? Do you retorque them regularly?
'88 Sammy
91 1.6L 8v EFI w/ K03 Turbo
03-72LE 4 Speed Auto / 6.5 tcase
Toy's cyro'd 5.29s ARB HP front
Elocker rear w/ cryo'd lock collar & side gears
Trunnion bearing eliminator
Longfields/chromo hub gears
4 link air shocks front / 4 link air shocks rear
39 BFG Reds
Raceline Monsters
clemsonjeep is offline   Reply With Quote Quick reply to this message
Old 06-17-2014, 04:29 AM   #150 (permalink)
adamwende's Avatar
Member # 193461
I had a mixture of both arp/stock. and have broke both. I did flat file the two mating surfaces, and that seems to have helped.
I love yota axles, but they just dont hold up to az traction. Especially when you start getting into stickies.
There's no debate about it out here. If you wanna run the big boy trails on yota axles, you will break. They are on borrowed time, but im ok with it for now. Driving smart makes them live longer.
AZ Undertaker
