The Grand crawler/cruiser build - Page 10 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-29-2019, 11:55 AM   #226 (permalink)
Member # 166598
Since my diesel is down, i drove my tracker up to cottonwood for a couple days of wheeling. Just drove there and back each day. First day was Smasher Canyon on Friday. I had a choice to either run the drit roads with one group or run Smasher. After some fighting in my head, i decided on Smasher. Boy has that trail gotten dug out with all the rain this year. We all walked through without much issue but the waterfall at the end has a hell of a hole in teh bottom now. Many of the samurais didnt have the wheel base and tilted right into the rocks, smashing a body panel or cage. i was long enough it kept the rig from three wheeling into the rocks but got high centered on the rear diff and needed a little winch action to get me up. the final ledge has been on my mind. i made it once and denied once in the past trips on that trail. I was gunna make it this time. needed one rock in a certain spot and to get the rig to be in just the right spot and finally walked right up it. buddy of mine has some videos but didnt get me making it. Took 5-6 tries.
Saturday i stayed home and Sunday i headed back up with the family. Wife, 3 year old and 4 month old. We ran Broken Arrow in Sedona. nothing challenging other than a couple spots i played on. no issues or breakage again.
Put a total of 400 miles on her driving up and back, pretty happy about that specially with the wheeling we did.
some drifting into the air down spot
couple vids of smasher
https://www.youtube.com/watch?v=VZD3sdDeeos
https://www.youtube.com/watch?v=DqpW6hhoR8M
This is the waterfall
https://www.youtube.com/watch?v=Epm9vKQbfi4
final ledge
https://www.youtube.com/watch?v=jGr2JHfbC5w&t=8s
Broken Arrow
l
chevy1925 is online now   Reply With Quote Quick reply to this message
Old 05-29-2019, 11:55 AM   #227 (permalink)
Member # 166598
ost my fender trim along the way lol
really dont have much in the way of fixing to do. just the fender trim. Gotta put my truck engine back together and then get back on the damn long travel
Old 05-29-2019, 01:45 PM   #228 (permalink)
Member # 726945
:smoking:
"Mmmmm, Love me some coal rolled kippers"
OllieNZ is offline   Reply With Quote Quick reply to this message
Old 06-10-2019, 08:37 PM   #229 (permalink)
oober's Avatar
Member # 36289
Looking good!
These little trucks are fun. I just bought a mini-me mostly because of your build here. I will be shamelessly stealing lots of your ideas
oober is offline   Reply With Quote Quick reply to this message
Old 06-10-2019, 08:53 PM   #230 (permalink)
Member # 166598
Ha! No worries, you ainít the first
Old 07-11-2019, 08:15 PM   #231 (permalink)
YotaAtieToo's Avatar
Member # 25632
Originally Posted by chevy1925 View Post
Well i finally got fed up enough with the stock CV's, i said it was time to upgrade.
We had gone on a long trip up to Bagdad Mine where we would run some back roads to old mines and end up in the back side of Prescott. on the way to Black Pearl Mine, the road is pretty washed out and real fun obsticles. I decided to stay out them to keep the front end alive but another fellow zuker asked why in the world i was not following him... i was not urked about this situation lol.
So decided it was time to put the toyota cv conversion in ive had for this thing for the last 2.5 years. its by no means a bolt in for a 2nd gen but i could make it work.
Now the factory diff mounts are HUGELY in the way for the adapters on toyota CV's to work. My pass side has been clearanced already (as you can see in previous posts) but the driverside needed alot of love. i moved it away from the diff 1" and shortened it 1", i also lengthened the pass side 1" as the diff is not centered based off the axle flanges. adding the driverside stub to the pass side off set the diff 3/4" now. when i test fitted the toy cv, it was bottoming out before i could get the top strut bolt in. Moving it 1" away fixed that though its a bit much now yet the driver side is perfect so ill run a little 1/2 spacer on the pass side CV.
How much grinding did you do on the back side of the knuckle? I went to mock mine up and it looked like I would have had to grind the whole knuckle flat to make it work.
My shafts do have the dust shields still in place, so that may be a big part of the problem.
Any chance you want to make another pair of those collars for the spindle bushings?
Old 07-17-2019, 07:33 AM   #232 (permalink)
Member # 166598
yeah you gotta ditch those since the new setup will seal off the stub shaft.
i can make some but they wont be cheap. the material alone i used was 75 bucks for 6". these take 3" for both and couple hours of my time and time is real short these days, hence no progress on the tracker....
Old 07-17-2019, 08:22 AM   #233 (permalink)
Member # 25632
No worries, I was able to use the 1st Gen spindles.
$150/ft, what did you make them out of?
Old 07-18-2019, 07:20 AM   #234 (permalink)
Member # 166598
ooohhh its some rrrreeeeaaaallllll good bearing bronze from aircraft industry. i shouldnt have an issue with them ever wearing out
Old 10-07-2019, 02:05 PM   #235 (permalink)
Member # 166598
alright, update time. i decided it was time to address the rattly timing chain ive had for over a year. While i was in there, figured i would put the custom cams in i had done a couple years ago..... then the whole "while im there" struck and i wound up yanking the heads to put new valve guide seals in and new headgaskets/head bolts in. this thing burnt oil ever since i bought it. Compression and leak down test said the cylinders were awesome but after looking at the heads, i understand why.
head torn down
leaky leaky
im sure the guides need replacement but they arent sloppy, just a touch more movement over the intake. the seals on the other hand were hardly even touching the valve.
new seals
while i had the heads off, figured id check the health of the cylinders. cylinder service limit is 3.3090, im at 3.3087. out of round limit is .004, im at .003. cylinders look awesome. for retrospec, factory new fresh bore is 3.3076 to 3.3078. 233k miles and only that much wear, im good with that! shes ready for boost :roflmao:
miles of chain going back in
That brings us pretty close to up to date. The cams helped bring power in sooner and probably gained a few ponies as well but nothing majorly noticeable. that prompted me to start looking at these
which was a waste of time because ebay turbos are all the same regardless of trim, so f**k it, its boost time. Should have most of the parts here tomorrow. China turbo with 8psi internal waste gate, 20 x 7 x 2.5" intercooler, drain, feed, RR FPR, and other goodies.
i did this because i needed to put an engine cross bar in my rig to keep frame flex down due to some 2.5" shocks i planned to run for a trip to mexico at the end of the month. Bar has to clear the turbo.
Old 10-07-2019, 02:06 PM   #236 (permalink)
Member # 166598
so sunday i spent the day fabbing up shock mounts. Driverside is all done, just needs paint. Pass side is all tacked in, needs fully welded and painted. its tight as hell fitting the 2.5 shock in there but everything clears with over a 1/2" or more in every area (full bump, tires cranked or full droop and tires cranked). im hoping she will be a little more contained in whoops now
Old 10-10-2019, 10:07 AM   #237 (permalink)
Member # 166598
Everything is in and built a strut/shock cross bar to keep frame flex down. just need to revalve these shocks!
