Suspension HELP! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-09-2019, 10:39 AM   #1 (permalink)
Member # 488145
Suspension HELP!
Hi guys i’ve built a suzuki samurai with a 4.3 vortec. it’s got a 4l60e tranny. i’m have a front suspension issue. i can’t find a leaf spring strong enough to hold up the 4.3. i’m looking for suggestions that’s not gna cost me out the @$$. but any help is appreciated
454bogger is offline   Reply With Quote Quick reply to this message
Old 06-09-2019, 07:04 PM   #2 (permalink)
xjtony's Avatar
Member # 50866
Options:
1. Add some leaves to stock samurai front spring packs.
2. Jeep yj leafs. They come in 4 and 5 leaf packs.
3. I’m sure there are other springs to use but I’m fond of the rubicon express 1.5” YJ leafs. $150 each new and they work well.
Low Budget Sammy
xjtony is offline   Reply With Quote Quick reply to this message
Old 06-09-2019, 07:22 PM   #3 (permalink)
Member # 166653
We need more information.
Are you on stock axles?
Are you planning on swapping to stronger axles with the spring?
Are you running spring over?
Also how much fab work are you willing to do? Lots of springs will work, but a long wide spring will take more fab work.
4seasons is offline   Reply With Quote Quick reply to this message
Old 06-11-2019, 04:30 AM   #4 (permalink)
2big bronco's Avatar
Member # 66684
5 spring yj pack. I think the guy that makes the most complete best kit goes by dr. Z
Here ya go
http://www.drzfab.com/product/samura...onversion-kit/
if you didnt grow up riding, crashing, and fixing 3 wheelers you had a shitty childhood
Old 06-12-2019, 12:34 PM   #5 (permalink)
Member # 572266
If using YJ springs, Old Man Emu sells a soft, medium and heavy load version. I would think that the Jeep 4.0 and the Chevy 4.3 are somewhat close in weight. The Jeep guys use 5.7 and 6.0 engines pretty often with leaf springs. If it works under the heavier Jeep, you should be able to find a setup that works for you.
samuraidave is offline   Reply With Quote Quick reply to this message
Old 06-12-2019, 01:07 PM   #6 (permalink)
xjtony's Avatar
Member # 50866
A Chevy v8 probably weighs less than the 4.0 in-line six so holding up the 4.3 would be no problem. I remember v8 swapping my old xj and gaining height up front from weight difference.
Low Budget Sammy
Old 06-18-2019, 03:36 PM   #7 (permalink)
nbk9nbk's Avatar
Member # 230672
Here ya go
Who makes the cheapest kit ?
Sent from my SM-G930T using Tapatalk
nbk9nbk is online now   Reply With Quote Quick reply to this message
