Zuki 2.0 build mod stock - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-09-2019, 05:25 PM   #1 (permalink)
Member # 27286
Send a message via AIM to toyotanuts
So I built and still building a samurai for mod stock class on east coast and also be something my twin girls (13 years old) can drive while on the trails. My regular trail zuk is tons, 6.0, atlas, 39 stickies so to much power I feel for them to learn.
I started out with a rusted samurai!
Iíll try to post as many in order. I donít usually do builds on forums at all but a lot of people keep asking me to do it so here we go!
Started out 2.0 but blew that up and went 2.3
Auto trans 03-72L. Not LE!!
Dana 300
Toyota axles with low pinion e lockers
What I end up with and still building
Jeremy
87 samurai, 39's, d60, 14b, 6.0, atlas
ready to rock.
toyotanuts is offline   Reply With Quote Quick reply to this message
Old 10-09-2019, 05:28 PM   #2 (permalink)
Member # 172738
Interested in the adapter you used to put the Dana 300 in there
lwb86 is offline   Reply With Quote Quick reply to this message
Old 10-09-2019, 05:31 PM   #3 (permalink)
Member # 27286
Cut housing to get springs under but not hang down a mile. Also moved them in a 1/2Ē more than stock Toyota on each side more steering(which is a lot)
Cut the front housing out to fit electric low pinion lockers. Iím sure everyone seen that before.
Jeremy
ready to rock.
Old 10-09-2019, 05:32 PM   #4 (permalink)
Member # 27286
Shaved both axles.
Jeremy
ready to rock.
Old 10-09-2019, 05:33 PM   #5 (permalink)
Member # 27286
Braced knuckles (but I think I bent them anyways)
Jeremy
ready to rock.
Old 10-09-2019, 05:35 PM   #6 (permalink)
Member # 27286
What spring ends up looking like on passenger side.
Love it so far.
Jeremy
ready to rock.
Old 10-09-2019, 05:36 PM   #7 (permalink)
Member # 27286
Front spring mount!
Jeremy
ready to rock.
Old 10-09-2019, 05:49 PM   #8 (permalink)
Member # 27286
So I decided to go with a Montero trans.
03-72L. I did this so I could have small, short drivetrain! This trans has 23 spline rear output stock. I remove the bell housing, dip stick, flex plate, line fittings, torque converter, front input, from a 2wd (Iím told 4wd is same) 4 speed 03-72LE that came behind 2.0 engine Iím putting in the zuki.
Jeremy
ready to rock.
Old 10-09-2019, 05:50 PM   #9 (permalink)
Member # 27286
Ok
Iíll post that soon.
Jeremy
ready to rock.
Old 10-09-2019, 06:05 PM   #10 (permalink)
Member # 27286
Bell housing off the 03-72LE Iím putting on the 03-72L.
Jeremy
ready to rock.
Old 10-09-2019, 06:07 PM   #11 (permalink)
Member # 27286
Had to leave a sensor in and cut off the end of it so fluid didnít leak out. Blue sensor on the bell housing.
Rebuilt transmission while I had it apart. Had friend do it and itís working great. Still havenít wired up the overdrive yet. Like I said. I used this trans cause I wanted to be small, short, lite and front dig!!
Jeremy
ready to rock.
Old 10-09-2019, 06:09 PM   #12 (permalink)
Member # 27286
I had to use a 3/8Ē thick clocking ring so seal would work in the rear tail housing!!
It sits a flat with trans pan.
Jeremy
ready to rock.
Old 10-09-2019, 06:11 PM   #13 (permalink)
Member # 27286
Added 4.1 gear
Still stock front and rear outputs, might upgrade rear soon.
Jeremy
ready to rock.
Old 10-09-2019, 06:12 PM   #14 (permalink)
Member # 27286
Added sight glass cause I hate getting to these cases to check the fluid.
Jeremy
ready to rock.
Old 10-09-2019, 06:12 PM   #15 (permalink)
Member # 27286
Ready to go in.
Jeremy
ready to rock.
Old 10-09-2019, 06:13 PM   #16 (permalink)
Member # 27286
Made some shifters for it!!
Jeremy
ready to rock.
Old 10-09-2019, 06:15 PM   #17 (permalink)
Member # 27286
Rear housing of 03-72L
Had to drill one hole (arrow) to bolt it up and cut some off (arrow) to clock it where I wanted it.
Jeremy
ready to rock.
Old 10-09-2019, 06:16 PM   #18 (permalink)
Member # 27286
Seal is missing from this photo but you can see where it goes. Used same one as Dana 300 input!! Fir right in
Jeremy
ready to rock.
Old 10-09-2019, 06:18 PM   #19 (permalink)
Member # 27286
Added temp port to trans pan so I could keep eye on it.
Jeremy
ready to rock.
Old 10-09-2019, 06:23 PM   #20 (permalink)
Member # 27286
Got motor where I wanted it. Steering box off a fj80 (which is awesome so far! A lot better than ifs!!) moved motor against frame. Heated header and bent towards block a least 1 1/2. ď I really wanted motor towards driver side as much as I could so drive shaft and 3rd would have room for up travel. Itís things like this I feel a lot of people donít take the time to do and make a huge difference!!
Jeremy
ready to rock.
Old 10-09-2019, 06:25 PM   #21 (permalink)
Member # 27286
Replaced front tube with 1 3/4 dom! It pressing right inside of stock thin wall tubing. Made it air tight for air tank. Also winch mount.
Also used angle for radiator mount with two hole in the bottom to fit stock 2.0 radiator. Angle is flush with bottom of the frame. I used 1/4Ē so I could tie winch mount into it later. Also front suck down winch rope may pull against it.
Jeremy
ready to rock.
Old 10-09-2019, 06:26 PM   #22 (permalink)
Member # 27286
Made motor mounts out of stock mount and some aluminum tube I had. Iím not the best at aluminum welding but itís worked great!
Jeremy
ready to rock.
Old 10-09-2019, 06:33 PM   #23 (permalink)
Member # 27286
Used a 22r water neck. Cut off Toyota flange and and made a 2.0 flange. Yes I suck at welding aluminum. But it donít leak!!
Jeremy
ready to rock.
Old 10-09-2019, 06:35 PM   #24 (permalink)
Member # 27286
Took a whole to get this right but this is my winch mount. Didnít want a huge jay leno bumper like most samurai have catching everything.
Jeremy
ready to rock.
Old 10-09-2019, 06:37 PM   #25 (permalink)
Member # 27286
What winch it looks like when Iím done!!
Jeremy
ready to rock.
