Rear drive shaft angle question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-12-2020, 05:55 PM   #1 (permalink)
Member # 697425
What's up. So I've been sitting on this Samurai for a while. I'm taking out the rear shaft to either remake or balance the one I have. My question is in regards to the angle of the drive shaft. Right now the bottom flange is pointed probably 1 to 2 degrees downwards.
Should the rear diff point directly at the tcase, level to the ground or down a couple degrees towards the earth? I'd post images but I'm under 10 posts. Thanks.
split141 is offline   Reply With Quote Quick reply to this message
Old 01-12-2020, 08:53 PM   #2 (permalink)
Member # 167850
Top is double cardan joint (common yota), bottom is non-cv
pilcher is offline   Reply With Quote Quick reply to this message
Old 01-13-2020, 06:01 AM   #3 (permalink)
Member # 697425
Okay so based on that I should be fine because I'm using a conventional setup. Now I'll just see if I can balance it myself or get one made.
Thanks
Old 01-15-2020, 09:42 PM   #4 (permalink)
Newbie
Member # 98705
What kind of range is the double cardon good for to 'fix' the pinion angle?
Sent from my SM-G973U using Tapatalk
jmorriss is offline   Reply With Quote Quick reply to this message
