YJ spua 33", build thread - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-13-2010, 09:06 AM   #26 (permalink)
Member # 89104
That's what i was noticing. I really like the way your rig is setup, low stable and capable.
I love the YJ's but I am wanting a better approach. I don't have much of an issue as long as I pay attention to the fact my springs are out there an inch or two in front of the tire, but a good approach is always better
I may try to move the the exl forward on the perch to gain an inch. What did you have to do with drive shafts to make them work in your rig?
I like
skyman6529 is offline   Reply With Quote Quick reply to this message
Old 05-14-2010, 02:55 PM   #27 (permalink)
Member # 30288
you should never got hindered by the approach angle, but they got a lot of rock rash. As you say it is much about knowing your rig and driving it right
There seems to be a trend with more people staying spua than before, I think this is cool. minimum lift is what I believe to be the right thing to do. it is a lot more work than just lifting to clear the tires so I can see why this is more popular
Front drive shaft is stock right now and have surprisingly not separated. I have a lengthened drive shaft in the rear and a front going in. the skid needs a notch to clear the drive shaft with the added drop
how I did the drive shafts is here: https://www.pirate4x4.com/forum/showthread.php?t=872959
Not done much, tires are over a week late. But I made new shock mounts and got them mounted. moved the upper mount inward 10mm and up 10mm with some hammering to the fender, and the bottom mount 25mm to the rear. The clearance is 2mm from the frame when flexing, thats the best I can do to keep the 13.5" from rubbing the shocks
ShuDuck is offline   Reply With Quote Quick reply to this message
Old 05-14-2010, 03:35 PM   #28 (permalink)
Member # 89104
Thanks for the link ShuDuck. I posted my response in the other thread. So i wouldn't hi-jack this one.
As for spring under, you are right.If I could fit my 33's on YJ;s without toomuch cuttign I would go back to Spring under in a second.
Old 05-17-2010, 04:49 AM   #29 (permalink)
Member # 30288
I will prove that you can do just that
Needed a spacer to the rear mounts as the springs are backwards, 1.4mm bigger. Dont have access to a lathe, but this worked just fine. 0.7mm wall and 6mm high
Name:  SAM_0845 (Medium).JPG
Name:  SAM_0848 (Medium).JPG
cross member was bent and cracked so it came off, need to make new shock mounts too.
Name:  SAM_0860 (Medium).JPG
welded shut the vent
Name:  SAM_0862 (Medium).JPG
and beefed up the rear axle, not so pretty welds, I think I was kind of drunk last night
Name:  SAM_0873 (Medium).JPG
Old 05-19-2010, 03:27 PM   #30 (permalink)
Member # 30288
it sits 2" higher than stock and clears 33x13.5"
Trimmed what I needed, clears the head lights and keep enough sheet metal to make it look good
mounted front YJ OME 2", and they are soft and flexy. so flexy that I got a lot of rear steer. needs to be dropped 2" + on the frame mounts
Name:  SAM_0887 (Medium).JPG
Name:  SAM_0901 (Medium).JPG
Old 05-20-2010, 08:59 AM   #31 (permalink)
Member # 89104
No there's the ground clearance you have bee looking for.
How about uptravel..are you going to have much room to stuff the tires over big bumps etc? I ma sure you have apan, i am just wondering what it is
Old 05-21-2010, 02:48 AM   #32 (permalink)
Member # 30288
1" to the bump stops and 1 1/2" when the stops are compresses. This is very close to what I had and worked very well. Also my tie rod do not hit the pitman arm at full stuff, so with only 2" lift I think i will leave the steering alone. bump steer wont be a problem as I had 2" OME(suzuki) + 3/4" shackles (taller) before with no real problems
Old 05-21-2010, 05:04 PM   #33 (permalink)
Member # 68367
That is sweet. Always like what you do with your rig ShuDuck.
I'm waiting to find out how to flip a Sky Manufacturing high steer arm, so the taper points down and run the drag link to it from below, so low lifts like 2-3.5" can run a parallel drag link to tie rod.
Rubiconwheeler (IIRC) from another board runs a flipped sky arm on his 3" lift, for his steering solution. This would be a nice way to go, since getting nice strong drag link and new tie rod ends (no slop), just have to get more info on it.
[I]Believe me when I say this...Oh, what was I saying?[/I]
WALES is offline   Reply With Quote Quick reply to this message
Old 05-23-2010, 11:17 AM   #34 (permalink)
Member # 30288
thanks, please let me know what you find out, sounds very interesting. got a link or pic?
with trackick steering arm I have 3" of drag link drop.
Name:  SAM_0971 (Medium).JPG
making room for the rear. need to reroute the fuel filler somehow.
Name:  SAM_0976 (Medium).JPG
new inner fenders mocked up
Name:  SAM_0960 (Medium).JPG
front fenders done, removed some of the front body mount to clear the tires.
just barely keeping the front of the grille
The biggest lugs rubs the springs a bit, but not a big problem
Name:  SAM_0962 (Medium).JPG
Old 05-23-2010, 11:26 AM   #35 (permalink)
Member # 30288
dropped the rear about 4"... moved the front hangers up as high the bolts would let me. didn't feel like frenching them into the frame. removed bottom leaf, not sure how axle wrap will be, just gotta test and see
Name:  SAM_0965 (Medium).JPG
rear shackle hangers are moved back and up. 4" long shackles front and rear. also added a diff breather thingy
Name:  SAM_0967 (Medium).JPG
very happy with the stance, sits 1/2 taller in the rear without spare wheel and gear. 16" to the belly
Name:  SAM_0963 (Medium).JPG
Old 05-23-2010, 11:27 AM   #36 (permalink)
Member # 89104
Me too
A member on another board called sky manufacturing and had them flip the arm before the drilled the taper. He didn't mention having any problems with them doing it this way. I guess they did the arm normally, but for him turned it upside down before they ran the reamer through it.
This isn't the first time I have heard of Sky-manufacturing modifying one of their products for a customer. i would give them a call I am pretty sure they wouldn't mind drilling the arm to accept the TRE upside for you.
HTH
--Sky
Old 05-23-2010, 11:35 AM   #37 (permalink)
Member # 30288
sky: good info, need to check that out later
last pic to see the overall stance
Name:  SAM_0964 (Medium).JPG
Old 05-23-2010, 12:03 PM   #38 (permalink)
Member # 89104
I know I have said it before, but IMHO this is the killer setup. It sit's low, longer than normal and has the tires needed for clearance, not to mention SPUA.
I like how my samurai handles now, and how well it does off road, but as usually we always look for better. sooner or later I'll have the guys to swap mine back to SPUA and make the YJ's work.
It's hard to want to tear apart and re-work your suspension just to get it 2-3 inches lower..but i have a feeling this is where I am headed.
FWIW
The previous owner mauled the stock stuff including frame mounts, so the best quickest most cost effective way to get it on the road was the YJ M/L setup.
Don;t get me wrong it's a great setup, and will go about anywhere. I would just be a little more comfortable ,and be able to take obstacles with a little more speed if I was a tad lower.
great work ShuDuck
Your thread has become a good reference in the Zook world for a good performing suspension spring under.
Old 05-24-2010, 07:12 AM   #39 (permalink)
Member # 693689
I like the way you remade and raised the rear spring hangers at the frame end. Mine are the typical homemade relocation plate, and they hang down too low and catch on crap. Good work man.
DannyK is offline   Reply With Quote Quick reply to this message
Old 05-24-2010, 11:44 AM   #40 (permalink)
Member # 30288
Thanks guys I appreciate the kind comments
Old 05-29-2010, 03:39 PM   #41 (permalink)
Member # 30288
not much going on, got the shocks mounted. Since the shock mounts need to be so high to avoid tilting them I figured Id lift the floor and tank.also made bumpstops of spoa perches and stock bumpstops
Name:  SAM_0989 (Medium).JPG
Name:  SAM_0991 (Medium).JPG
Name:  SAM_0993 (Medium).JPG
Old 05-30-2010, 12:43 PM   #42 (permalink)
Member # 89104
So what do you have planned for the drear deck now? I've thought about cutting through the bed to fit the longer shocks (more uptravel) but haven't had the guts to break out the grinder yet.
Old 05-30-2010, 02:21 PM   #43 (permalink)
Member # 30288
Welding in a new raised one, the old had some rust. my GFs old body(zuk body that is) have a good floor. I have to take off the rockers and switch to her new body as well
Old 06-07-2010, 01:02 PM   #44 (permalink)
Member # 30288
old body hacked up
Name:  SAM_0998 (Medium).JPG
Raised floor and new wheel wells.
Name:  SAM_1016 (Medium).JPG
Name:  SAM_1031 (Medium).JPG
was a pain to get the fuel filler to work.
Name:  SAM_1033 (Medium).JPG
Gave the beaten up tanks skid some paint and mounted it back on. The tanks is lifted as well
Name:  SAM_1022 (Medium).JPG
Old 06-07-2010, 01:08 PM   #45 (permalink)
Member # 30288
and I got a problems with the springs, I can raise the height 1" in the front by just lifting it by hand and it will sit there. All bushings are well lubed and all bolts loose. Hope they will settle after some use, it is truly pissing me off, been trying a lot of different spring pack combos, but ended up with the first pack.
problem is that it will sit crooked after I exit it. push passenger side down and it sits level
Old 06-07-2010, 01:30 PM   #46 (permalink)
Member # 38563
what type of diffs do you have? A spool won't help the vehicle sitting level if you just pulled into a spot turning
84' M1031 CUCV 35's
84' Suburban 2wd to 4wd on tons, 8.1 4L80e NP205, 35's
Pietro is offline   Reply With Quote Quick reply to this message
Old 06-07-2010, 01:44 PM   #47 (permalink)
Member # 89104
that rear deck is looking pretty good, heck the whole thing is. Nice job.
As for the springs, I am having the same issue in the right rear. If Anyone rides in it, or I put anything with any weight to it, on the passenger side it sags when the weight is gone.
Pull it up with your hands and it stays. It's starting to piss me off too. Like you I loosened everything up, so it should return to ride height if there is any spring pressure.
Sometimes it sags in the right rear when you are driving down the road too. For some reason the passenger rear has been a problem that follows all my different spring packs and shocks too.
Old 06-10-2010, 03:26 AM   #48 (permalink)
Member # 30288
got lockright front and rear. but I have checked it and measured a hundred times. tried different spring packs, but still the same problem.
Did the sagging problem get better over time? Im going to wheel it some before I try anything else, maybe they will settle in. It is just like it is 1kg to light to compress the springs properly
Old 06-10-2010, 06:25 AM   #49 (permalink)
Member # 89104
The ride height isn't sticking as much anymore, it's returning to ride height better now, but the passenger rear is still noticeably lower.
Old 06-11-2010, 01:17 PM   #50 (permalink)
Member # 30288
Changed the oil on the 6.5 tcase. quite a lot shavings on the magnet. the oil where pretty ghey as well (glitter).
took it apart and inspected, seems fine. Shimmed the input so it sits level 0.1mm gap. lowrange says it is supposed to be 0.35-0.45mm gap. need more shims. Hope this will take care of things, some of the insane gear whine too
Ill get a pic of the gear teeth, not so sure about these
