Full Floater Axle housing Jig - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor's Marketplace > Tools and Supplies
Old 10-31-2013, 06:52 AM   #76 (permalink)
Member # 72152
Originally Posted by sayb2 View Post
Cajun, I understand that it will do sixty fronts. I'm asking about 9 inch centers on a front axle.
The 1.5" bar will do any center section. But the 1.5" bar will only fit in 60/70/14B spindles. So if you're building a 609 you are golden.
Ford 9" inner 3rd jigs (there are 2 oem bearing sizes, 4 if you count aftermarket so you need to know what you got) + the threaded FF jigs for the outside.
cajuntaco is offline   Reply With Quote Quick reply to this message
Old 03-18-2014, 05:39 PM   #77 (permalink)
Member # 940
I do two different 9" carrier jigs. 1 has the D44 on one side and the 3.250 large ford 9" on the other. The second jig set does the 3.062 on one and the 2.8 whatever on the other.
Dean
Deep Cryogenic Tempering Service
[b][SIZE="5"]Find all my products at[/SIZE][/b]
[b][SIZE="4"]916-434-6978
Custom Sway Bars and Axles built to order. [/SIZE][/b]
[b][SIZE="5"]Got 40 spline? I have the hubs, spindles, and axles you need to kickass![/SIZE][/b]
Custom Hummer wheels and centers
Axle Resplining
66CJdean is offline   Reply With Quote Quick reply to this message
Old 04-07-2014, 11:59 AM   #78 (permalink)
pcoplin's Avatar
Member # 17986
Do you offer outer pucks for a Sterling 10.5? Also, would they screw on, or use the bearing surface? Thanks!
98 TJ LQ4/TH400
FullStack MotorSports
pcoplin is offline   Reply With Quote Quick reply to this message
Old 04-29-2014, 03:46 PM   #79 (permalink)
sasfrontier's Avatar
Member # 123210
We talked on the phone about a week ago about doing a unit bearing setup with 9" pucks. When you get it figured out let me know and you can just shoot me a PM on here.
Thanks,
Matt
sasfrontier is offline   Reply With Quote Quick reply to this message
Old 05-01-2014, 10:05 AM   #80 (permalink)
Member # 940
I am going to do some and funny thing was as soon as we hung up the phone the next call was for that exact thing!
I have not done the sterling ones yet but they are coming up soon.
Axle Resplining
Old 05-04-2014, 09:50 PM   #81 (permalink)
pcoplin's Avatar
Member # 17986
Definitely let me know if and when you are able to do so. I'll need order some inner 4.125 pucks for now.
98 TJ LQ4/TH400
Old 05-22-2014, 07:57 PM   #82 (permalink)
Member # 123210
Have u been able to make any progress on the unit bearing jig?
Old 05-28-2014, 05:46 PM   #83 (permalink)
Member # 940
Sterling Left handed jigs are now in stock
Unit bearing jigs are also in stock. The unit bearing ones I did from 7" x 1.75 aluminum so this way you can bolt them to the cup and they use the register to align them.
I also now carry the pucks for the AAM 11.5 that use the 4.437 carrier bearing.
Axle Resplining
Old 08-09-2014, 07:04 AM   #84 (permalink)
Member # 75335
Do you have any jigs to do a toyota 9.5 center? I want to center an older land cruiser diff with 3.5" tube, so I think I only need a semi float kit. How much shipped to 98116? Thanks.
ChaseHeadrick is offline   Reply With Quote Quick reply to this message
Old 08-17-2014, 08:09 PM   #85 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
Took it a while! Hope you like and feel free to post up a photo of your project you are doing with it.
Dean
Well it only took me 3 years
Widening an Eaton using your bar and FF end bushings. I machined the pucks to fit the Eaton housing. Working great so far!
Azzy2000 is offline   Reply With Quote Quick reply to this message
Old 08-20-2014, 04:37 PM   #86 (permalink)
Member # 123210
I'll post up some pictures soon of the Unit bearing set up that I purchased from you. Just finalizing all of the suspension mounts before everything is welded up.
Old 08-29-2014, 10:56 AM   #87 (permalink)
Member # 940
That would be great. I have yet to take any photos to Pimp them out. Were they what you thought they were going to be?
Axle Resplining
Old 08-30-2014, 07:11 PM   #88 (permalink)
Member # 123210
They are exactly what I wanted. I like that I can actually bolt the pucks to the unit bearing cups. I noticed a slight difference in the machining tolerance of my unit bearing knuckles from spidertrax and the unit bearing cups for the rear axle from spidertrax. I believe it is due to the welding that spidertrax does on the knuckles. The factory Ford knuckle has a tighter tolerance than spidertrax. Your pucks allow a good fit into both factory and aftermarket knuckles.
Old 09-18-2014, 11:16 PM   #89 (permalink)
pcoplin's Avatar
Member # 17986
These work well. Thanks for getting these done.
98 TJ LQ4/TH400
Old 09-30-2014, 07:03 PM   #90 (permalink)
Member # 198783
Would like a quote an a kit shipped to 37421 and probably need a few different pucks building a 609
Thanks in advance
krackem is offline   Reply With Quote Quick reply to this message
Old 10-31-2014, 07:46 AM   #91 (permalink)
Member # 68555
PM sent.
xj² is offline   Reply With Quote Quick reply to this message
Old 12-11-2014, 03:39 PM   #92 (permalink)
Member # 940
We have the pucks for the Unit bearing set-ups too.
Axle Resplining
Old 02-01-2015, 12:46 PM   #93 (permalink)
Member # 537674
Dana 70 HD, with 4.125 bearings...
Do you have a kit for this? I checked your website, but couldnt find what I am looking for. What does the kit come with?
Nick
The Bull is offline   Reply With Quote Quick reply to this message
Old 03-04-2015, 03:04 PM   #94 (permalink)
Member # 940
Yes I do. A few years back I changed my D60/70/14 bolt kit to include the 70HD/D80 carrier so it is all one kit. The kit doesn't do the 80 spindles though.
Dean
Axle Resplining
Old 04-14-2015, 05:44 AM   #95 (permalink)
Devinfox's Avatar
Member # 197839
can I get a quote for a complete setup for dana 60/14b plz?
1984 CJ7 LY6 TH350 DANA 300, SOA 37's
Devinfox is offline   Reply With Quote Quick reply to this message
Old 04-28-2015, 03:02 PM   #96 (permalink)
Member # 940
$450 + shipping. It will do 60/70/14B front or rear spindles. The carrier pucks will also do 70HD and D80.
Dean
Axle Resplining
Old 09-13-2015, 04:53 PM   #97 (permalink)
Member # 215784
Jig bar alignment kit.
Just putting this out there for where credit is due, credit should be given.
Thanks Dean for your AWESOME service and honesty in your dealings with me here in far off Aussie land.
The Jig bar kit and workmanship of the pucks are 2nd to none and as said, your business ethics are unmatched. I wish I could find more businesses like yours.
Blessings to ya. Pete.
okapete is offline   Reply With Quote Quick reply to this message
Old 10-04-2015, 09:43 PM   #98 (permalink)
Jorge Meza's Avatar
Member # 70340
Would you do a Jig complete set for Jeep Dana 30 / Dana 44 axles? They bend real easy and have lot of customers with Rubicon Dana 44 bent axles that could use a straighten.
Jorge Meza is offline   Reply With Quote Quick reply to this message
Old 10-28-2015, 04:42 AM   #99 (permalink)
Member # 70665
I'm building a FF rear for my FJ40 and am in need of a set of inner and outer full floater alignment jigs.
The center holes for the alignment bar would need to be 1.25".
Can you do stepped carrier jigs with 80mm and 83mm diameters?
Thanks!
Stump
-Stump
TLCA #6451, CAPITAL LAND CRUISER CLUB
stumpalama is offline   Reply With Quote Quick reply to this message
Old 11-04-2015, 11:22 AM   #100 (permalink)
fordnut's Avatar
Member # 50971
How much for the left hand sterling spindle jig, thanks
I dont remember what gears I had, but they barely fit in..
fordnut is offline   Reply With Quote Quick reply to this message
