Dodge WC53 Tow Rig and Restomod - Page 54 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-21-2019, 06:04 AM   #1326 (permalink)
E-Locker or Bust!
DMANbluesfreak's Avatar
Member # 163019
Originally Posted by AlxJ64 View Post
And another one bites the dust...
Allison is roaring and chattering now, just like the last one.
I give up.
WTF!?! That's insane. I wish I had the knowledge or knew someone knowledgeable about those transmissions but everyone I know who's had one built had a shop do it.
2001 Z71 Silverado, Ext. Cab, 5.3L V8 -
Shortened 17" w/Bed, AAM 14B FF / Grizzly, Dana 60 HP / Chromos, Anti-Wrap Bar
4L80e, EcoBox/205 Doubler, 40" Mickey's, Rock Sliders, Hidden Winch, Hydro Assist
DMANbluesfreak is offline   Reply With Quote Quick reply to this message
Old 05-21-2019, 06:13 AM   #1327 (permalink)
Dinkerdoodledoo
Member # 10448
Send a message via Yahoo to Grendel
Like I said on Facebook. Most people don't have problems with these transmissions in 100k increments... meaning they go a while before the need work.
The two you started with are suspect. The first one wasn't built right and the second one was used with 125K (if really 125K on it) and came out of a truck that was parted for some reason?
Get someone to build it right. They're not rocket science. There are upgrades available for them.
If you want to ship me a trans via Fastenal, I will have my guy go through it.
Grendel is offline   Reply With Quote Quick reply to this message
Old 05-21-2019, 07:05 AM   #1328 (permalink)
Not a Wenzelite
MT4Runner's Avatar
Member # 44480
I give up.
FUUUUUUUCCCCKKK!!
I don't get on here much, but have been reading this thread in my email.
Only logged in to say: "DON'T GIVE UP!"
Originally Posted by Grendel View Post
Time for an RTO610
Yeah, this. Or an ESO66-7B, it's synchro
In all seriousness, this.
You built this rig wanting the Allison. Get an Allison that works.
If Grendel can get a reliable one built, do it.
It's only money, and you've already put a ton of it and even more time into the truck. Get a reliable transmission so you can enjoy that beautiful truck.
MT4Runner is offline   Reply With Quote Quick reply to this message
Old 05-21-2019, 11:28 AM   #1329 (permalink)
Member # 108302
Oh CRAP!
wawii.com - 1946 & 1949 Dodge Power Wagon, 1953 Dodge M37 & Jeeps
W_A_Watson_II is online now   Reply With Quote Quick reply to this message
Old 05-22-2019, 05:07 AM   #1330 (permalink)
Member # 130031
Thanks guys. I am just really bummed at this point, and more tapped for cash than I've ever been with all this other stuff going on.
I talked with some friends, and despite how cool a big manual box would be, I think I will try my cards at the "3rd times the charm" theory on this fawking Allison.
Evidently, most of the '01 to '03 versions of these bastards have a KNOWN issue with the hardness and durability of the torrington bearings, mainly T3 and T5... As in the races weren't hardened. In both installs of these transmissions (both 2001 year models) I at first over-filled the damn things enough that I was getting some foam in the fluid. I drained the fluid level down and even added a sight tube for the second one so that I could keep track of the levels.
The sight tube doesn't show any aeration or cavitation, however, there is possibly a chance that I trashed those soft bearings enough in the first few miles that they have just been slowly wearing and allowing the chatter of a set of planetary gears. The noise is only evident in 4th and 5th. I think it is the rear most planetary set due to the way the clutch sets work on these things.
The first transmssion was assisted in its failure with the obvious bad converter, I mean that thing was trashed from the get go. Maybe that contamination triggered the bearing failure.
I cleaned out the cooler and lines and all before each time between the installs. This time around I am just replacing it all.
A rebuilt transmission is looking like $3500 from a shop.
I bought the book, am going to study, and a few gear head friends are all about digging into this thing. We plan on tearing down the first failed one to see what all went down. Then use that to compare damaged inside of this second one.
It appears that the hard parts for these trash cans aren't that expensive and that a DIY rebuild is actually somewhat affordable, if you do it right. I'm going to try my hand at it I guess and throw about another $1k at it in this "learning process".
If this fails... I am going to sell a kidney, buy a G56, and be done with this automatic bullshit.
AlxJ64 is offline   Reply With Quote Quick reply to this message
Old 05-22-2019, 05:32 AM   #1331 (permalink)
Member # 147348
Fwiw... A dope head buddy of my dad has successfully built two Allisons in his work trucks, he is not near as talented as you are.
CarterKaft is offline   Reply With Quote Quick reply to this message
Old 05-22-2019, 06:09 AM   #1332 (permalink)
Dinkerdoodledoo
Member # 10448
No, you're not
Old 05-22-2019, 06:18 AM   #1333 (permalink)
Member # 130031
No, you're not
Do you ever get tired of being right?
I'll have the pallet together next week.
Thanks again man.
Old 05-22-2019, 06:22 AM   #1334 (permalink)
E-Locker or Bust!
Member # 163019
Glad to see the tenacity is back. Never met you in person, but based solely on this build thread - you've never been one to give up. Keep at it and keep learning. Eventually you'll have a bulletproof automatic and keep something nice and unique that matches your original vision.
Old 05-22-2019, 07:30 AM   #1335 (permalink)
Elwenil's Avatar
Member # 41063
Tearing down both and comparing them is a smart move. If they both have similar failures, it could indicate something else is causing them, or a weak point in the design as you mentioned before.
1988 Dodge AW450 Ramcharger-318TBI-NP435-NP205-D60s
Odin Owns Ye All
Elwenil is offline   Reply With Quote Quick reply to this message
Old 05-22-2019, 04:07 PM   #1336 (permalink)
WHEEEEEEEEEE!
gavan's Avatar
Member # 22597
Send a message via AIM to gavan
Yeah yeah build the Allison...
But as a die hard manual fan and with some friends in the medical profession we can probably get good money for one of those pee-makers and I would love to see your fabricated clutch pedal.
Just sayin’, there are options.
gavan is offline   Reply With Quote Quick reply to this message
Old 05-28-2019, 07:54 AM   #1337 (permalink)
Member # 130031
Just sayiní, there are options.
Yea... I kinda dream of a manual in this thing now after driving the Allison and having the problems with the Allison.. etc etc. The G56 would be a nice unit for sure. It'll stay on the shelf of ideas for now though.
Its hard to turn down the offer on this next rebuild and I am pretty sure that my issues mostly all stem from the stupid early models not having the hardened thrust bearings as this particular failure seems to be the primary mode of death for the early 5 speeds. In the first one, the bearings were not addressed and now running a stock one, of the same year model, I'm not surprised... Whats that definition of Insanity... same thing over and over again expecting different results... well, at least this time it'll be a full rebuild and address the non-hardened bearing problems.
I hauled it up to my parents place for the weekend and made a short drive with it just so that they, my brother and his wife, etc could see it.
Had some quick video footage snagged on the brief little drive.
I know I know... stupid instagram.
https://www.instagram.com/p/Bx8RvCrnZcX/
Old 05-28-2019, 04:38 PM   #1338 (permalink)
Member # 147348
Loosing confidence in a transmission is allot like a girl find around on you, it's always in the back of your mind.
However there really is no reason that trans can't be built to handle what you're doing with 💯% reliability.
It's not a bad transmission you're just getting a education on them 😉.
Old 06-11-2019, 10:49 AM   #1339 (permalink)
Member # 130031
Haven't touched my truck... But I did touch a ton of others.
Went to the Power Wagon Rally in Iowa last work... BEST TIME EVER! Hung out with W_A_Watson_II and Matt Brown (forget your user name) and it was awesome!
Great trucks! Great food! Great Wheeling! It was awesome!
The Allison comes out this week and gets sent out to the guru who is helping me out. Stoked to get this thing finished and it WILL BE AT THE RALLY NEXT YEAR!
So.. the 4 door truck, was driven to Iowa from California. Has a Cummins Clone 4bt (China clone he says) and was converted to 4 doors. Running an NV4500.
Silver truck has a stock 230 flat head and just had a synchro 420 swapped in and boosted brake kit.
The school bus... yea... Hellcat Hemi, plus some cam work, plus some tuning... She NASTY.
Old 06-11-2019, 01:21 PM   #1340 (permalink)
Member # 108302
Good news on the trans, and Alex it was great spending time with you and all the other PW Family.
Old 06-11-2019, 01:41 PM   #1341 (permalink)
Dinkerdoodledoo
Member # 10448
I still want one.
Can't believe that jerk is taking your second one, to be his third, when I don't have one ...
Old 06-12-2019, 02:19 PM   #1342 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Nothing like looking at other rigs to get some motivation to keep pushing forward.
guidolyons is offline   Reply With Quote Quick reply to this message
Old 06-12-2019, 03:53 PM   #1343 (permalink)
Member # 108006
I was great meeting and hanging out with you last week at Rally. It is a fun time and can't wait to see your marvelous fab work in person at Rally next year. I will make sure to stock up on artichoke hearts for the deep fryer for next year.
JunkCJ6 is offline   Reply With Quote Quick reply to this message
Old 09-23-2019, 05:45 PM   #1344 (permalink)
Member # 222190
I hope all is well. Just wondering if everything is still moving or if has stalled out for now. Hope you are doing as well as possible.
Ckjeseth is offline   Reply With Quote Quick reply to this message
Old 12-04-2019, 07:38 PM   #1345 (permalink)
Member # 875260
This has been a wild thread to read and for sure one of my favorites. I read your jeep build and then clicked your signature link because it looked interesting. very pleased to see you followed through with it over all the years. it really is stupid that people would give you hate over building this. its got a great to the roots vibe and using part of the decking from an older destroyer was fantastic. could we get some shots of the flooring? lastly its always exciting to see a local build. Va beach here. keep up the good work.
CSpeade51 is offline   Reply With Quote Quick reply to this message
Old 02-12-2020, 05:12 PM   #1346 (permalink)
nice roach.
jhama78's Avatar
Member # 3377
Bump for updates Allehandro @AlxJ64
When ya gonna tow the Atvs over to the house with the WC53? That'd get some looks for sure.
jhama78 is offline   Reply With Quote Quick reply to this message
Old 02-13-2020, 05:06 AM   #1347 (permalink)
Member # 79188
Beautiful!
gman
gman1322 is offline   Reply With Quote Quick reply to this message
Old 02-13-2020, 07:38 AM   #1348 (permalink)
backchat's Avatar
Member # 109999
Damn, got excited for updates.
hope all is well.
backchat is offline   Reply With Quote Quick reply to this message
Old 02-14-2020, 06:31 AM   #1349 (permalink)
Member # 220494
hope all is well.
I frequently check in on him on Instagram. He hasnít done much with it recently. I know he is getting divorced (I believe he mentioned it in this thread too) and it looks like heís just taking some time to dick off with four wheelers and party with his friends. Iím sure heíll get back at it after a while, but we can all understand getting a little burnt out on a years long project like this. Especially after nuking a second transmission that is not at all cheap to build. Saying fuck it for a year or so and getting your personal affairs back in order before continuing on with the build might just be what the doctor ordered to help get over the frustrations of trying to make every last thing in this truck perfect.
He did engineer and build the least ghetto gooseneck to bumper pull adapter Iíve ever seen in order to pull a car trailer loaded down with quads with a party ex-school bus. We will have to see if my retarded ass can remember how to post pictures
broncokyle88 is offline   Reply With Quote Quick reply to this message
Old 02-14-2020, 08:51 AM   #1350 (permalink)
backchat's Avatar
Member # 109999
Glad to hear he is still around and hasn't sold this. Can't blame him for taking a break for a while.
For those of us that have decided against twitterinstagramfacebook, I hope he tosses us an update once in a while!
