200k on a 7.3 psd Anything to look for? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-19-2012, 07:14 PM   #1 (permalink)
Member # 78077
Found a crew cab 4x4 7.3 with a 6 speed manual for $7000. Base truck with manual windows and rubber mats. Anything I should be wary about?
Don't blame me, I voted against him.
#rawkon is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 07:18 PM   #2 (permalink)
Member # 94400
Year?
92 Fj80 6bt, 1tons wife mobile
70 Fj40 1ton v8 241/205 42's
03 CTD toe rig
Texas Trail Buggy
[QUOTE=Blase;15022725]what's it like to own a buggy........i'd say it's like getting a blow job on a roller coaster:D[/QUOTE]
slobuild57 is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 07:33 PM   #3 (permalink)
Bob Williams's Avatar
Member # 4421
Wiring under the vavle covers, cps (cheap fix, carry a spare). HPOP. How was the coolant maintained? Know well how the truck was used; light, heavy, abused? ZF's are ok transmissions, what kind of clutch is in it? Unit bearings on the front end are a hassle, but IIRC my '03 had manual hubs which is good. Those are the main things to look for.
Bob Williams is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 07:42 PM   #4 (permalink)
Member # 78077
Sorry its a 2000 .
Old 09-19-2012, 08:07 PM   #5 (permalink)
Member # 195181
I would start by loosening the oil cap while running and see if it stays there.
WIESEL is offline   Reply With Quote Quick reply to this message
Old 09-19-2012, 09:03 PM   #6 (permalink)
Member # 78077
I will check blow by, drivability for bearings and thansmission issues, Anything else?
Old 09-20-2012, 02:28 AM   #7 (permalink)
Member # 66769
2 piece flywheel? if so plan on replacinng it with a 1 piece, may as well do a clutch while you are in there.
http://www.cardomain.com/ride/2241565
Big Bird is offline   Reply With Quote Quick reply to this message
Old 09-20-2012, 07:40 AM   #8 (permalink)
Member # 78077
I will ask to owner about the flywheel.
Old 09-20-2012, 11:40 AM   #9 (permalink)
Member # 78077
Truck was a complete hunk of shit. Leaking oil from everywhere, Run like hell and the front end was worn the heck out, Transmission needed work, Grinding when in gear going down the road. I passed on the truck. Thanks for the advice anyhow.
