Idasho's IdaCamper2.0 - Page 34 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-15-2019, 04:04 PM   #826 (permalink)
IDASHO's Avatar
Member # 83932
A simple spring bolt latch will do it.
Ive used them in the past for compartment door latches, inverted so just the handle is exposed.
Stupid simple and clean enough.
Paint is whatever the painter is using. I didnt get specifics, but it is an industrial 2-part epoxy primer + 2-part industrial top coat. The shop routinely does heavy equipment, and is well known for doing very good work.
That paint job will simply seal up the steel. The visible frame, and all aluminum skins, once finished up will be top coated with U-Pol Raptor Liner.
Once done it should be a lifetime bed. At least thats what Im telling myself
Kenny B.
IDASHO is offline   Reply With Quote Quick reply to this message
Old 04-15-2019, 07:32 PM   #827 (permalink)
Member # 136471
http://a.co/d/0hihYVn
These kinda latches are neat and pretty cheap. Amazon has a ton of different kinds.
boardbysled is offline   Reply With Quote Quick reply to this message
Old 04-15-2019, 09:19 PM   #828 (permalink)
IDASHO's Avatar
Member # 83932
Thanks, but I dont want any thing exposed that might catch on something.
Kenny B.
Old 04-16-2019, 07:31 AM   #829 (permalink)
GLTHFJ60's Avatar
Member # 140040
Love it. $3 or $4 a latch is perfect for something that doesn't need to be sealed from the elements.
1987 4BTJ60 - MoonShine - 4BT/NV4500/EcoBox/NP205/D60/14B
2004 F-550 - 6.0/ZF6 - full bulletproof
GLTHFJ60 is offline   Reply With Quote Quick reply to this message
Old 05-05-2019, 06:47 PM   #830 (permalink)
IDASHO's Avatar
Member # 83932
Not much to report, but I did get the bed back from the painter.
And he did a top notch job, and loaded it down with paint at my request.
All finished, it was blasted, epoxy primed, and received 3 solid coats of top coat.
I told him to do it right, and just bill me. He certainly did, but the extra coin will be worth it in the long run Im sure. Nice candy coating on the steel now.
Also have been pulling various items together to start assembly.
SEM seam sealer for all the steel seams that were not fully welded.
SEM panel bond for the critical (structural) panel installation
SEM gun for both
Sika 252 for the remainder of the aluminum panels
Upol Acid #8 for priming the aluminum
And finally, a 4-pack of Upol Raptor liner.
I figure Ill need more than 4 jugs, but its a start to see just how far the stuff goes. Always difficult to judge.
Paint has had a few days to dry, so Ive already started the sand/prep for seam sealer. Load of hand sanding....
Also have to pick up all the aluminum Ill need. The fit-out will be a combination of thickness' and flat or diamond tread.
Kenny B.
Old 05-18-2019, 12:21 PM   #831 (permalink)
IDASHO's Avatar
Member # 83932
I might actually get this bed out of the shop
Ive been slaving away, hand sanding this thing in preparation for the U-Pol Raptor liner coating.
And have the cross body box skinned.
Had a bit of a hickup with the skins, as the solvent based panel adhesive I chose decided to not cooperate with the paint the painter used.
I had planned on just panel adhesive, but due to the error the skins for the cross body box were riveted on. I was hoping to eliminate any and all aluminum to steel contact for corrosion reasons... but it just didnt happen that way. Oh well.
Anyhow...
Completely prepped for Raptor.
Epoxy seam sealer to all joints, Aluminum primed 3/ acid etc primer.
Entire thing was sanded w/ 180 grit then de-greased with grease and wax remover.
Kenny B.
Old 05-18-2019, 12:28 PM   #832 (permalink)
IDASHO's Avatar
Member # 83932
And on to Raptor.
Tell you what... the over-spray on plastic is STICKY
Stuff went on real well, but I spent more time unsticking my boots from the plastic than anything!
Some teaser pics... So far, Im real impressed with this stuff.
Also, 4 jugs didnt quite do it. I had enough to do 2 coats on the forward portion of the bed (enough to reinstall the bed on the truck) but I will need some more to get a solid second coat on the rear.
Kenny B.
Old 05-21-2019, 08:01 AM   #833 (permalink)
GLTHFJ60's Avatar
Member # 140040
Super sexy.
Old 05-21-2019, 08:17 AM   #834 (permalink)
mothfuckle
fredycruger's Avatar
Member # 225557
that came out very nice
i like the raptor liner. i learned if you spray further away and bump up the air pressure. texture will look much better
fredycruger is offline   Reply With Quote Quick reply to this message
Old 05-21-2019, 08:37 AM   #835 (permalink)
Member # 37016
Nice results. I picked up 4 kits of raptor liner when amazon had them for $20 a kit a while back. Haven't used it yet but looking forward to getting to that point in my truck project.
65Chevy4x4 is offline   Reply With Quote Quick reply to this message
Old 06-09-2019, 08:23 AM   #836 (permalink)
IDASHO's Avatar
Member # 83932
Another teaser shot.
Been crazy busy. Ill update with some proper photos later.
Certainly starting to look the part though.
All aluminum panels installed, lighting in, and currently working on final wiring and fuel fillers.
Dont mind the unpainted/lighter portion of the box. An aluminum bang-board is to be installed there.
Kenny B.
Old 06-09-2019, 09:34 AM   #837 (permalink)
Member # 84339
That is sexy.
Lugnut4x4.com
And i don't want to give Canadiens any more money, so my sig is broke.
Pt_Ranger_V8 is offline   Reply With Quote Quick reply to this message
Old 06-09-2019, 09:46 AM   #838 (permalink)
IDASHO's Avatar
Member # 83932
I know....
Sometimes I even surprise myself... this is one of those times.
Project has really come together.
Kenny B.
Old 06-09-2019, 10:13 AM   #839 (permalink)
Back Woods's Avatar
Member # 74825
Looks great.
Back Woods is offline   Reply With Quote Quick reply to this message
Old 06-09-2019, 12:45 PM   #840 (permalink)
v6toy4x's Avatar
Member # 9154
what about your parents house, was that a different thread??
GOD MADE DIRT, MOTHER NATURE MADE THE ROCKS & HEAVEN MADE THE LAKES
THANK GOD FOR MOTHER NATURE I AM IN HEAVEN
85 4rnr,8"hp,9"det,R151,toybox,d300 4:1
98.5 dodge,EZ,TST,ex brk,Goerend,ford outers,quad bags
'05 arctic fox-880wts solar,inverter,cocktail cubes 24/7
502cu in boat EVIL SATISFACTION
v6toy4x is offline   Reply With Quote Quick reply to this message
Old 06-09-2019, 01:10 PM   #841 (permalink)
IDASHO's Avatar
Member # 83932
Same thread.
Still in the picture, but not looking like any progress will happen this year.
They will more than likely make a trip to visit, but I dont expect any major work to happen. Mom is fighting health issues.
FUCK CANCER
Kenny B.
Old 06-09-2019, 02:42 PM   #842 (permalink)
v6toy4x's Avatar
Member # 9154
Open mouth insert foot
SO SORRY
Old 06-09-2019, 02:53 PM   #843 (permalink)
Member # 56256
So sorry to hear....
Sent from my SM-G973U using Tapatalk
F450 Box Truck to RV conversion www.NWadventuretruck.com
Java is offline   Reply With Quote Quick reply to this message
Old 06-09-2019, 04:08 PM   #844 (permalink)
IDASHO's Avatar
Member # 83932
Thanks guys. It is what it is.
She has high hopes, and the prognosis is good.
It looks to be about as "good" as it could get for cancer.
Chances are high she wont even need chemo or radiation.
Still.... things on hold for the moment.
Kenny B.
Old 06-16-2019, 03:51 PM   #845 (permalink)
IDASHO's Avatar
Member # 83932
So... I like the old vintage bikes.
And in a desperate attempt to break up this project a bit, even being so near
the finish, I snagged another little moto.
Ive been riding the little 125ccswapped honda trail for a couple of years now,
and while it is a ridiculously fun little in town bike, it is anything but a
highway rig, and running 2-up for any length of time is beyond silly.
So Ive been casually watching old Honda Scramblers on Craigslist, and I
snagged up a clean 1973 CL175. A "basement" find, as it would be.
Quite literally at in a guys basement for 25 years. So no rust,
rubbers are all good, 140# of compression in both cylinders,
hell even the factory seat is nearly 100%.
But its not without its problems.
Just 3" longer wheel base than the Honda trail (IE, will fit in the flatbed
cross-body box), weighs roughly 80# more, but is considerably more bike.
Easily traveling highway speeds if necessary, and handles 2-up without problem.
2-weeks of vinegar in the tank cleaned out the rust, 20 minutes and a can of
brake clean cleaned out he carbs, $100 in tires, tubes, chain,
and a bit of fuel line... But still needs cables, and a bit of exhaust work.
Thats next.
Anyhow.... a teaser shot for you...
More flatbed progress soon.... I promise
Kenny B.
Old 06-16-2019, 05:11 PM   #846 (permalink)
Member # 193950
Nice, just sold a CL77, but it was no where near as nice looking as that bike...
Aaron Z
At some point you have to accept that lots of naturally-occurring substances can kill you-Solandri
aczlan is offline   Reply With Quote Quick reply to this message
Old 06-16-2019, 08:26 PM   #847 (permalink)
IDASHO's Avatar
Member # 83932
It did clean up nicely, and I'm into it less than $1000, so if I decide I dont like it (unlikely) I could easily flip it. When these pop up for sale, they are typically in the $2500-$3500 range, and the value of them (similarly to older CB's) just keeps on going up.
The original muffler was the only bit I couldnt salvage. So I lopped it off in favor of some simple 1.5" stainless pipes with packing and baffle/inserts.
Sounds japanese But better than nothing. Might do something else later, after I have some miles on it.
I did run it around town this evening. Needs a front brake cable and throttle cables bad. So those are on order. Also looks like I didnt get all the black nasty out of the tank.... so carbs are getting gummed up.
Should be a fun little runner once done though. And looks pretty sharp.
Kenny B.
Old 06-16-2019, 09:25 PM   #848 (permalink)
Member # 95025
Looking good!
ΜΟΛΩΝ ΛΑΒΕ
President Trump on building the wall:
"THIS IS WHERE WE HOLD THEM!!! THIS IS WHERE WE FIGHT!!! THIS IS WHERE THEY'RE DEPORTED!!!"
V.P.Pence:
BUILD THIS WALL, BOYS!!!
Fearless Indians:
Awe-Ooo!!!
CDA 455 is offline   Reply With Quote Quick reply to this message
