Cummins swap parts thread - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-19-2014, 09:05 AM   #1 (permalink)
CDN Rockwell dist
680oscar's Avatar
Member # 168676
with the growing number of Cummins engines being swapped into offroad rigs I thought I would try to build a collection of parts that will aid with the install of the 6 cyl Diesel engine in less than "normal" applications
there have been many different pieces of equipment that the 5.9 cummins have been use in and therefore a lot of different cummins factory parts are available
here's what I've collected so far, if you have anything to add please try to post up photos and and much info as possible about the part (PN, application, engine SN)
also if anyone thinks this thread would be better in another section let me know and ill have it moved.
I found this particular engine in a tree mulcher
Engine Model QSB5.9
SN 46684123
here is a list of some of the parts I found
Upright drivers side AC unit
Compressor sits aprox 9" above mounting the surface on the front of the head
CF9093 Refrigerant Compressor
1 3043477 Washer, Plain 2 3/8 in
2 3902662 Nut, Hexagon Flange 2 M10 X 1.50
3 3906621 Screw, Hexagon Head Cap 3 M10 X 1.50 X 40
4 3912685 Spacer, Mounting 2
5 3916518 Screw, Hex Flange Head Cap 2 M10 X 1.50 X 125
6 3925962 Support, Ref Compressor 1
7 3930815 Bracket, Ref Compressor 2
Belt PN is 25-9476
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
2.5 / 5 ton Rockwell, Meritor and Axletech parts and axles for sale in Canada.
680oscar is offline   Reply With Quote Quick reply to this message
Old 03-19-2014, 09:16 AM   #2 (permalink)
CDN Rockwell dist
680oscar's Avatar
Member # 168676
vertical T-stat housing/ upper hose connection
1 3903757 Bracket, Lifting 1
2 3900632 Screw, Hex Flange Head Cap 1 M8 X 1.25 X 35
3 3926972 Screw, Hex Flange Head Cap 2M8 X 1.25 X 70.
4 3285102 Housing, Thermostat 1
5 3923331 Gasket, Thm Housing Cover 1
themostat PN 3917324
upper rad hose is 1-3/4 ID
[IMG][/IMG]
Old 03-19-2014, 09:29 AM   #3 (permalink)
CDN Rockwell dist
680oscar's Avatar
Member # 168676
Big 8 groove Alternator
Unfortunately for some reason I think it only puts out 100amp
1 3052061 Screw, Hexagon Head Cap 1 1/2 - 13 X 1 in
2 3900631 Screw, Hex Flange Head Cap 3 M8 X 1.25 X 25
3 3903210 Nut, Hexagon Flange 1 M12 X 1.75
4 3902460 Screw, Hex Flange Head Cap 1 M10 X 1.50 X 25
5 3939905 Brace, Alternator 1
6 3903105 Screw, Hex Flange Head Cap 1 M12 X 1.75 X 150
7 3921737 Support, Alternator 1
Alt part number 5282836
Belt part number 3289268
[IMG][/IMG]
[IMG][/IMG]
Belt tensioner
1 3282081 Screw, Hex Flange Head Cap 1 M10 x 1.50 x 75.
2 3976831 Tensioner, Belt 1
[IMG][/IMG]
[IMG][/IMG]
Old 03-19-2014, 09:34 AM   #4 (permalink)
CDN Rockwell dist
680oscar's Avatar
Member # 168676
HX 35 turbo 90 deg. exh outlet
1 S 910 B Plug, Pipe 1 1/4 NPT
2 3902460 Screw, Hex Flange Head Cap 4 M10 X 1.50 X 25
3 3903652 Clamp, V Band 1
4 3910991 Pipe, Exhaust Outlet 1
5 3930717 Brace, Exh Out Connection 1
exh 90 outlet is 3" OD
[IMG][/IMG]
Old 03-19-2014, 09:23 PM   #5 (permalink)
CDN Rockwell dist
680oscar's Avatar
Member # 168676
Upright exhaust manifold
PN 3091683
[IMG][/IMG]
Turbo HX35W
PN 3599727
Turbocharger Oil Plumbing
1 3412320 Clamp, Hose 2
2 3900630 Screw, Hex Flange Head Cap 2 M8 X 1.25 X 20
3 3931973 Tube, Tur Oil Drain 1
4 3286499 Hose, Plain 1
5 3937706 Gasket, Oil Drain 1 Replace With 5264569
6 3934093 Connection, Tur Oil Drain 1
7 3037236 Seal, O Ring 1
8 3284244 Connector, Female 1 Replace With 3919687
9 3918562 Hose, Flexible 1
10 3924389 Washer, Sealing 2 7.2 mm
11 3931824 Seal, O Ring 1
3920706 Plug, Expansion
Old 03-19-2014, 09:31 PM   #6 (permalink)
CDN Rockwell dist
680oscar's Avatar
Member # 168676
Air Crossover Connection
1 3008469 Plug, Pipe 1 3/4 NPT
2 3026396 Clamp, Hose 2 2 1/16 - 3 in
3 3970409 Hose, Plain 1
4 3918109 Screw, Hex Flange Head Cap 3 M8 X 1.25 X 25
5 3919995 Screw, Hex Flange Head Cap 4 M8 X 1.25 X 90
6 3929085 Connection, Air Crossover 1
7 3938152 Gasket, Int Manifold Cover 1
8 3969988 Gasket, Connection 1
9 3991819 Cover, Intake Manifold 1
[IMG][/IMG]
[IMG][/IMG]
Old 03-19-2014, 09:39 PM   #7 (permalink)
CDN Rockwell dist
680oscar's Avatar
Member # 168676
vertical water inlet
1 3008468 Plug, Pipe 1 1/2 NPT
2 3008469 Plug, Pipe 2 3/4 NPT
3 3900679 Screw, Hex Flange Head Cap 3 M10 X 1.50 X 80
4 3906697 Seal, Rectangular Ring 2
5 3943149 Connection, Water Inlet 1
3943549 Connection,
6 131584 Pin, Roll 2
7 3943550 Connection, Water Inlet 1
lower rad hose is 2" ID
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 03-21-2014, 06:39 AM   #8 (permalink)
Moderator
NECKSTER's Avatar
Member # 2645
Great info. I'm moving to the tow rig section though, as it sees way more diesel talk than the dodge forum.
NECKSTER is offline   Reply With Quote Quick reply to this message
Old 03-21-2014, 08:45 AM   #9 (permalink)
CDN Rockwell dist
680oscar's Avatar
Member # 168676
Sounds good, thanks
Old 03-21-2014, 01:45 PM   #10 (permalink)
D45
Member # 102974
Not to hijack, but some do like Common Rails for swaps
Here is some pertinent fuel system and injection related information:
2003/2004: Holset HE341 Turbo; 54/58/9
2004.5-2007: Holset HE351 Turbo; 60/60/9
04.5-07 HE351:
7 blade 60mm/60/9
19mm wastegate hole non divided
2012 Ford F150 FX4; Long Bed; 3.5L V6 ECO; Max Tow; 3.73; Leveled; 275/65R20 Goodyear Duratracs
D45 is offline   Reply With Quote Quick reply to this message
Old 03-21-2014, 01:46 PM   #11 (permalink)
D45
Member # 102974
2003-2004 trucks have an 8 hole nozzle
2004.5+ trucks have a 5 hole nozzle
Both trucks use a different piston bowl design also
555 5.9 and 6.7 injector nozzles have a wide spray angle due to a reentrant bowl design.
600/610 5.9 injector nozzles have a narrow spray angle due to the open non-reentrant bowl design.
555 motor: 143* injector spray impacts annular region of 113* piston bowl, concentrating combustion towards the piston dome. 8 hole nozzles with two injection events
600/610-series: 124* injector spray impacts central region of 140* piston dome, propagating combustion towards the cylinder wall. 5 hole nozzles with three injection events
Additionally...........if you need/want a tad more fuel:
I have been running the 6.7L tubes for over a year, without any issues
The 5.9 tube outlet is .075" and the 6.7 tubes have a .120" outlet.
Cummins now supercedes the 5.9 tube P/N to the 6.7 crossover tube, although Bosch still offers the 5.9 P/N......
Most shops now list all 2003-2011 5.9L and 6.7L motors to use the same PN!
Bowl volumes are only .7cc different (~1.5%), so the choice doesn't significantly impact compression ratio - every .005" of compressed gasket thickness or piston protrusion is just over 1cc.
Re-entrant combustion is more efficient, reduces thermal flux into the block & head, and allows better piston geometry - especially regarding the top ring land - to handle the heat & pressure
Old 03-21-2014, 08:00 PM   #12 (permalink)
Member # 150595
Great info. Glad it got moved here to the tow rig section. I don't follow the dodge section.
Nat
Nat_sters Haul All
nat_ster is offline   Reply With Quote Quick reply to this message
Old 03-21-2014, 09:50 PM   #13 (permalink)
Member # 52361
Cummins to Ford, use a ps hose from 88 e150 with 5.8
And a 1st gen fan mount will save about an inch of clearance front to back over a 2nd gen truck
PROJECTJUNKIE is offline   Reply With Quote Quick reply to this message
Old 03-26-2014, 06:30 PM   #14 (permalink)
Banned
Member # 91791
Send a message via AIM to g-wizz
this is a good thread. this is way better than finding the threads on 4bt swaps.
g-wizz is offline   Reply With Quote Quick reply to this message
Old 03-26-2014, 09:31 PM   #15 (permalink)
Member # 150595
4988751 new pump
The fist gen dodge 5.9 Cummins from 89 to 93 used a inferior lift pump. This is the mechanical pump that replaces it, and prevents injection pump failure due to low fuel pressure. This is not the same pump as the P pump Cummins engine used. The P pumped engine used a higher pressure lift pump that will alter your timing, due to the way the VE pump works. If trying to use a P pumped engine's lift pump on a VE engine It will need a regulator.
http://www.dieselbombers.com/5-9l-ro...lift-pump.html
First pic is the stock lift pump. When this one fails, it fills the crankcase full of diesel fuel.
Second and third pic are the manual replacement pump that eliminates the inferior pump. This mechanical pump pulls it's power from the camshaft lobe. When it fails, it simply starts leaking.
Parts needed.
Installed.
Nat
Nat_sters Haul All
Old 03-26-2014, 09:34 PM   #16 (permalink)
Member # 150595
For the sake of simple, we should almost keep this 12 valve only.
If we add all the new electric stuff, things will get overwhelming.
Nat
Nat_sters Haul All
Old 03-31-2014, 07:52 AM   #17 (permalink)
Member # 210638
Incase it hasn't been stated, on the 12v piston style lift pump, the fuel inlet threads are 1/2" NPT and outlet threads are M14 x 1.5 straight cut.
ghostman is offline   Reply With Quote Quick reply to this message
Old 03-31-2014, 04:16 PM   #18 (permalink)
Member # 59241
on That lower mechanical lift pump, it REALLY makes the install easier if you make some studs for it in stead of bolting it down.
Be advised the holes in the block are metric thread.
99TJ DD/Trails the usual stuff 94 F-700 RV convesion 5.9L Cummins/6sp 24 foor U-haul box
nitecop is offline   Reply With Quote Quick reply to this message
Old 04-01-2014, 09:33 AM   #19 (permalink)
Member # 28898
Any idea what size the vertical water inlet is?
mattmey is offline   Reply With Quote Quick reply to this message
Old 04-03-2014, 07:05 PM   #20 (permalink)
Member # 150595
Many 12 valves had the engine oil fill tube coming off the front of the timing cover. Sometimes in cramped installs You need to delete this, and move the fill to the valve cover.
Valve cover with fill hole, plug, and seal.
Plug to fill the stock fill tube hole.
Nat
Nat_sters Haul All
Old 04-03-2014, 08:40 PM   #21 (permalink)
Member # 17632
That exhaust manifold above appears to just be a low mount manifold turned upside down. If a guy uses one of the valve covers with the fill hole, be warned that you can only put in about a quart at a time or it will overflow
Travis..
'18 Ram 2500 4x4 Big C and a 6 speed
FOR SALE '15 Ram 2500 4x4 cummins 6 speed manual trans
crashnzuk is offline   Reply With Quote Quick reply to this message
Old 04-03-2014, 09:07 PM   #22 (permalink)
CDN Rockwell dist
680oscar's Avatar
Member # 168676
Lots of great info showing up in this thread!
Nat
I was hoping to keep this thread mostly external "bolt on parts" I agree that this thread could get very overwhelming with all the technical info available for the cummins engines.
I updated my posts to include the hose size
i thought the same thing at first, its hard to tell from the pics but the turbo mounting flange is on an angle compared to the head mounting surface, the low mount common rail manifolds are at a 90deg compared to the head mounting surface.
Old 04-03-2014, 09:28 PM   #23 (permalink)
Member # 380714
s-10 shift boots from the 90's + are great universal boot for nv4500 swaps, they have a large flat base that is screw down not push clip or lock ring retained.
S&H 4wd is offline   Reply With Quote Quick reply to this message
Old 04-03-2014, 09:55 PM   #24 (permalink)
Member # 53528
THANKS i just did a nv4500 swap and for the time being im using a hat with a hole cut in the middle of it
Old 04-05-2014, 07:22 PM   #25 (permalink)
Member # 150595
1992 Ford B700 chassis school bus, same as a F700 truck
Flywheel housing, 12 valve Cummins 5.9 to SAE 3 (Engine adapter.) This is the adapter to use any of the SAE 3 transmissions. (MDT trans) This one came with a 5 speed Eaton FS 5005A trans.
Starter is on the drivers side, turbo is on the passenger side. This is my favorite SAE 3 adapter so far, due to the 4 hole side mounts, and the starter being on the opposite side of the turbo\ downpipe.
Engine serial Number (ESN) 44796046
Nat
Nat_sters Haul All
