Ecoboost Maintenance - Page 11 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-18-2016, 11:17 AM   #251 (permalink)
Member # 84885
What are you using for the strip lighting in the shell? Had thoughts of something similar under bed rails under my tonneau cover
Lanery is offline   Reply With Quote Quick reply to this message
Old 11-18-2016, 02:52 PM   #252 (permalink)
D45
Member # 102974
Whatever the ARE cap came with.......its almost like a Velcro design that sticks to the interior carpeting very very well
Does not hang down at all and does an good job lighting up the inside
2012 Ford F150 FX4; Long Bed; 3.5L V6 ECO; Max Tow; 3.73; Leveled; 275/65R20 Goodyear Duratracs
D45 is offline   Reply With Quote Quick reply to this message
Old 11-18-2016, 03:29 PM   #253 (permalink)
Member # 684337
Originally Posted by 87manche View Post
gas v8's have had 100 years of evolution and improvements.
this is essentially first gen.
For who? Buick did this almost 40 years ago with great success. Production turbo cars have been available since early 60s.
Voale Zwetzak is offline   Reply With Quote Quick reply to this message
Old 11-23-2016, 01:56 PM   #254 (permalink)
Orville's Avatar
Member # 41858
Since my 16 expedition has the 3.5l ecoboost, I'm posting in this thread. We've been known to tow with it a fair amount. Probably 4000 miles out of a total of 18000. Trailer weights from 5k to 8k. No crazy high speed towing or abuse.
Rear diff is leaking at the output seals. Not a lot, but definitely unexpected at 18000 miles. I'm wondering if Ford didn't upgrade diff to deal with new ecoboost.
Anyone seen this before?
Edit: 3.31 ratio
Orville is offline   Reply With Quote Quick reply to this message
Old 11-25-2016, 06:02 AM   #255 (permalink)
D45
Member # 102974
2016 Expedition with the Ecoboost still has the same 365 hp / 420 tq rated motor.......my understanding is that all Ecoboost SUVs and F150s came with the Ford 9.75 rear axle
What do you mean "I'm wondering if Ford didn't upgrade diff to deal with new ecoboost"
The 9.75 is a pretty damn good stock rear axle........some claim it gets hot fast, but I have yet to experience this.
Big axle shafts and a stout housing.
Some quick stolen info:
In torque capacity, it's ahead of the Dana 60, though it's a bit shy of the average semi-floating D60 in load-carrying ability.
Other notable comparisons to the Dana 60 are that the 9.75 axle has about the same-size carrier bearings and larger pinion bearings.
The 34-spline 9.75 may have one spline less and 0.070-inch less axle shaft diameter than the D60 (35/1.50"), but it makes up for it by having quality material. Ford uses a high-carbon SAE 1050 carbon steel in its axles instead of 1040. As a result, the Ford holds a significant edge over the Dana in short-term maximum output torque rating, and it's dead even in the maximum continuous rating.
Old 11-25-2016, 06:45 AM   #256 (permalink)
Joey D's Avatar
Member # 20053
Maybe it heats up quicker because it has less oil when used in the expedition because it's IRS design , no tubes to add oil capacity.
Trump 2020
Joey D is offline   Reply With Quote Quick reply to this message
Old 11-25-2016, 07:39 AM   #257 (permalink)
D45
Member # 102974
Very possible, a quick check revealed this about rear diff fluid capacity:
2012 F150 FX4
FRONT: 3.8 Pints
REAR (Open/LSD): 5.5 Pints
REAR (Electric Locker): 5.9 Pints
2016 Expedition
FRONT: 3.6 Pints
REAR (Open): 4.4 Pints
REAR (LSD): 4.2 Pints
Old 11-25-2016, 09:46 AM   #258 (permalink)
Orville's Avatar
Member # 41858
Thanks for the replies. The dealer said it was not a oil leak. The factory installation lubricant seeps out. They cleaned it off and the plan is to watch it.
Old 11-25-2016, 12:46 PM   #259 (permalink)
D45
Member # 102974
Well today I decided to finally inspect the undercarriage to try to locate a "thud" noise that I have been hearing for the last 3-4 months
It really only happens on acceleration and seems to be on the driver side floorboards areas
I know there are numerous complaints about the rear driveshaft slip yoke, but the only real way to tell this is to take off the driveshaft, pull the boot and see if its dry.......something I will let the dealership do under warranty
I checked the rear axle u-bolts, and they are tight
I jacked each from tire up off the ground and checked the ball joints, tie rod ends, and the sway bar end links..........all were tight
Any other ideas ?
Old 11-25-2016, 01:04 PM   #260 (permalink)
Member # 86724
did they have direct injection, make 360hp and be expected to live while towing 12K lbs?
Old 11-25-2016, 01:06 PM   #261 (permalink)
Member # 86724
Any other ideas ?
wasted trans/motor mounts?
Old 11-25-2016, 02:01 PM   #262 (permalink)
D45
Member # 102974
That is what it sounds like actually
When my Dakota's trans mount when, it sounded similar......
I would hope mine would not be shot at 35k
Old 11-27-2016, 05:53 PM   #263 (permalink)
Member # 24709
Send a message via AIM to CartsXJ Send a message via Yahoo to CartsXJ
Any other ideas ?
Is it under hard acceleration, or just general driving?
My 14 does it sometimes on hard acceleration on slippery surfaces when the traction control kicks in and apply the brakes. Sometimes it sounds like the driveshaft is gonna come up thru the floor, lol!!!
"Being a man take years of fightin, screwin, drinkin, and whorin. Then more drinkin and then more whorin...if there's time" -Trippin the Rift
CartsXJ is offline   Reply With Quote Quick reply to this message
Old 11-27-2016, 06:21 PM   #264 (permalink)
Member # 5371
Send a message via MSN to rockota
Any other ideas ?
Carrier bearing?
rockota is offline   Reply With Quote Quick reply to this message
Old 11-28-2016, 06:10 AM   #265 (permalink)
Member # 47783
Any other ideas ?
I just took my 2011 in to the dealer for the same noise. They had to re-shim the rear axle pinion, install a new oil seal, and add more gear oil. There is a TSB for it. That fixed my noise.
2a in the works.
*xj-man* is offline   Reply With Quote Quick reply to this message
Old 11-28-2016, 05:43 PM   #266 (permalink)
D45
Member # 102974
The noise happens under mild and hard acceleration.......not all the time, but enough to be annoying
What about the CVs on the front axle?
I will check the carried bearing........and maybe look into a one piece aluminum alternative
If I ran a one piece in my 8 foot bed truck, and I certain I can get one for this 6.5 footer
Old 11-29-2016, 07:41 AM   #267 (permalink)
Member # 44231
IIRC, there is a mod out there to replace the OEM trans mount with one from a Raptor that is supposed to eliminate this issue. Mine had that as well but I never got around to swapping mounts. Lots of spooky EweToob videos out there with the camera focused on the drivertrain during launches
Happiness is low range and carne asada...
tobyw is offline   Reply With Quote Quick reply to this message
Old 12-06-2016, 07:57 PM   #268 (permalink)
Member # 85158
Has anyone added a catch can yet? I just bought a 2012 and while doing some reading it seems mixed on whether they are needed. What is the general consensus?
lottery_loser is offline   Reply With Quote Quick reply to this message
Old 12-08-2016, 06:37 PM   #269 (permalink)
D45
Member # 102974
Remove any one of the intercooler or turbo piping........you will be amazed how much oil residue is in there, coating everything
Old 12-08-2016, 06:38 PM   #270 (permalink)
D45
Member # 102974
Interesting, I will have to see how my trans mount looks this weekend
It is getting rather obnoxious
Old 12-08-2016, 06:46 PM   #271 (permalink)
D45
Member # 102974
AL3Z6068B looks to be the Raptor trans mount P/N?
I think this might be fore 2015+
Around $85
Old 12-08-2016, 08:11 PM   #272 (permalink)
OkLaHoMaYJ's Avatar
Member # 17969
Send a message via AIM to OkLaHoMaYJ
I drilled the weep hole in my intercooler and a lot of oil came out of mine too!
12 F150 FX4, EB, 2'' level, Toyo, SCT, AFE / 05 LJ Rubicon, 4''Currie, MTRs, Built 44's, Savvy
OkLaHoMaYJ is offline   Reply With Quote Quick reply to this message
Old 12-09-2016, 10:05 AM   #273 (permalink)
xo_jeep's Avatar
Member # 112255
I did the same research and eventually decided that it really can't hurt. Yeah, it's $300 but after you see the crud that comes out of it, you'll be glad you did it. The only way it can hurt is if you forget to empty it and it starts pumping the sludge back into the motor.
You boys make me proud. You took my inner thoughts and feelings then expand on them in such colorful and creative ways filled with hate.
xo_jeep is offline   Reply With Quote Quick reply to this message
Old 12-12-2016, 12:45 PM   #274 (permalink)
89eliminator's Avatar
Member # 121870
anyone notice there MPG go down with cold weather (below freezing)? I was getting 18-19mpg during the warmer days, but now that winter is upon us (i live in WI), i am getting 15-16mpg.
89 MJ
Brew City Crawlers
89eliminator is offline   Reply With Quote Quick reply to this message
Old 12-12-2016, 01:17 PM   #275 (permalink)
Member # 86724
winter fuel blows.
it seems to suck even harder with forced induction. the wagon loses 2-3 mpg. I spent a month trying to figure it out last winter, gave up, and in the spring it went back to 26-28mpg on the highway.
