Ecoboost Maintenance - Page 16 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-29-2018, 07:14 AM   #376 (permalink)
D45
Member # 102974
Took a long weekend road trip to Missouri.....managed 17.1 mpg highway
With the warmer temps, the catch can is nearly empty..........seems like the colder temps produce a ton a moisture in the CAC
Got back last night and drop the truck off at a local dealer to have the clunking and creaking noise looked at.......
It will be interesting to see what they find..........I have the Premium warranty till May of 2019, that has a $100 deductible
2012 Ford F150 FX4; Long Bed; 3.5L V6 ECO; Max Tow; 3.73; Leveled; 275/65R20 Goodyear Duratracs
D45 is offline   Reply With Quote Quick reply to this message
Old 05-30-2018, 06:04 AM   #377 (permalink)
D45
Member # 102974
Third dealer was a hit...……….no issues with any of my mods and found (and fixed) a few things, all for $100
The truck will be done this evening or tomorrow morning, the latest
The multi-function switch was faulty and replaced, to cure the ghost wipers
They found a bad ball joint (I believe the lower on the driver side)
They are also performing a TSB for rear pinion/rear driveshaft issue
Old 05-30-2018, 12:38 PM   #378 (permalink)
D45
Member # 102974
The dealership called back and said I need front and rear brake pads, ASAP
The truck has 51,000 miles on it?!
My one ton Dodge went 75,000 miles before the front rotors warped and there was still a decent amount of pad life left
Oh well, for $120 they are doing the rear brakes (new pads, rotors turned)
They wanted $450 for front rotors and pads...…..no thanks, I will do that myself this weekend
Old 05-30-2018, 07:14 PM   #379 (permalink)
TR
TR's Avatar
Member # 2877
I got around 60k out of my front brakes before I realized the pads brakes where metal to metal. Rears are fine so far with 70k
Penn State study finds that heavy drinking is 100% easier than giving a shit
TR is offline   Reply With Quote Quick reply to this message
Old 05-30-2018, 07:15 PM   #380 (permalink)
Member # 86724
meh.
my in laws subaru needed pads and rear rotors at 31K mile. Front pads needed replaced too.
I really think the new shit is way harder on the rear brakes for some reason.
I did the rears on my wagon and the service count was 4 for the rear and only 1 for the front. So 4 sets to 1.
I don't know if they're using the rears harder because we've got ABS to keep it from locking up or what, but it's a trend I've noticed on everything newer.
Old 05-31-2018, 03:06 PM   #381 (permalink)
D45
Member # 102974
Truck is back......and is quiet and smooth!
Replaced the driver side lower ball joint and replaced multi-function switch (for the wipers)
Also performed TSB 14-0090, lubed driveshaft splines and adjusted pinion bearing preload
9L3Z-3050-A; Joint
BL3Z-4676-A; Seal
FL3Z-7N357-A; Shim
N800594-S100; Bolt
BC3Z-13K359-BA; Switch
XY-75W140-QL; Oil
BR-1602; Kit
Old 06-03-2018, 07:09 AM   #382 (permalink)
D45
Member # 102974
I get the truck back from the dealer, with a fault code? WTF
B10F1
I know for a fact it wasn't there when it was dropped off
I cleared it out, see what happens
Here is the info on the TSB 14-0090 that was performed:
Some 2011-2014 F-150 vehicles built on 1/1/2011 and through 4/1/2014 may exhibit an intermittent click or snap-type noise from the rear axle on initial light acceleration from a stop while in drive or reverse. The noise may also occur on light acceleration after changing direction from drive to reverse, or reverse to drive.
https://ford.oemdtc.com/TSB/14-0090.pdf
Old 07-21-2018, 11:44 AM   #383 (permalink)
D45
Member # 102974
Fault code stayed away, after I cleared it...…..
Going on a 500 mile trip next Saturday...……..Lake of the Ozarks bound
MPGs have been good, a solid 17.5
Old 08-02-2018, 07:09 AM   #384 (permalink)
D45
Member # 102974
Ozarks was good, but the weather wasn't
On the trip down, used around 3/4 of a tank and averaged 19.5
This was with two adults, a kid, three full coolers and two storage totes full of food
I filled up at a Cenex gas station on 54, and averaged 17.2 on the way home
Only one full cooler...…….why such a difference? Different gas blend?
Old 08-04-2018, 07:51 AM   #385 (permalink)
D45
Member # 102974
My rear shocks are shot...…….I removed the bottom bolt on each and could collapse them with very little effort
Ford quality, again...……..shot at 55,000 miles
What are some good options?
What year Raptor rear shocks will fit?
Old 08-04-2018, 08:35 AM   #386 (permalink)
Stunningly Average
wheelerfreak's Avatar
Member # 4135
I don’t think 55k is a bad life for a factory shock
I run Fox 2.0’s on my F150 and like them so far. Have about 50k on them.
Edit, not the piggy back style., this style.
The press is a gang of cruel faggots. Journalism is not a profession or a trade. It is a cheap catch-all for fuckoffs and misfits—a false doorway to the backside of life, a filthy piss-ridden little hole nailed off by the building inspector
wheelerfreak is offline   Reply With Quote Quick reply to this message
Old 08-05-2018, 07:39 AM   #387 (permalink)
D45
Member # 102974
The FOX 2.0s do seem nice......I definitely want shocks with polyurethane bushings, nothing to rust and seize up
FOX 2.0: $279 pair
ICON 2.0; $159 each
The Icons allow for up to a 2" rear lift and the FOX are only for 1" rear lift
I was hoping to find a set of good Ford Raptor rear shocks...…...they will fit, right? Year specific or?
I thought they changed a shock bolt size in some year Raptor trucks
Old 08-05-2018, 07:19 PM   #388 (permalink)
TR
TR's Avatar
Member # 2877
I just put bilsteins all the way around and it soaks up the rail road crossings and other larger bumps in the road. I also raised the front .75" with the shocks and it sits nicely.
Old 08-11-2018, 08:46 PM   #389 (permalink)
DT75FLH's Avatar
Member # 101209
FOX 2.0: $279 pair
ICON 2.0; $159 each
I put a set of 2011 raptor take offs on my 2016. I had them rebuilt and charged to 200 instead of 250 due to the alum body on mine. I also raised the rear with 1in block...they matched very well on and especially off road with my icon 2.5 in front
[COLOR="DarkRed"]Difficulty is the excuse history never accepts.
A Nation of sheep will beget a Government of wolves.[/COLOR]
Edward Murrow
DT75FLH is offline   Reply With Quote Quick reply to this message
Old 08-11-2018, 08:47 PM   #390 (permalink)
DT75FLH's Avatar
Member # 101209
I was also running 17 in rims and not 20,s so a Lil better ride...iirc your running 20?
Edward Murrow
Old 08-12-2018, 10:36 AM   #391 (permalink)
D45
Member # 102974
Yes, I have the factory 20s'
I am also searching for some Raptor take offs
Old 11-17-2018, 07:06 AM   #392 (permalink)
D45
Member # 102974
Just knocked out another oil change and installed 6 new spark plugs
Mileage is still up......but the constant knocking in the suspension or drivetrain is back
Coming up on 58,000 miles, so the Durtracs have around 41,000 on them.
I would guess by next summer they will need to be replaced
Old 11-17-2018, 07:10 AM   #393 (permalink)
D45
Member # 102974
The truck did amazingly well with the trailer and my new big block Duster
Old 11-29-2018, 06:57 PM   #394 (permalink)
A_G
A_G's Avatar
Member # 118487
dad bought a 2013
I cant get the mother fucker to stop missing when you punch it. Plugs...coils...CACT sensor failed..replaced that..cleaned sensors. Still fucking missing
Whats the trick. Misfire primarily on #3 but sometimes 2 a little less on 4 and 5
Vagina advice number 1...never invite crazy into your home
Vacancy (daytona coupe, 66 charger, cougar eliminator)
1967 F250: Restomod
1998 f150 reg cab, swb, 4x4 5.4
2013 Yamaha fz8
2015 jetta
And 2 more
A_G is offline   Reply With Quote Quick reply to this message
Old 12-12-2018, 07:45 PM   #395 (permalink)
D45
Member # 102974
I bet it's sucking in moisture. Get a catch can
I empty 3 ounces from my truck in the cold weather, every 5 days
Old 12-13-2018, 09:43 PM   #396 (permalink)
Member # 199790
How many miles is that?
I bought a used Ecoboost expedition for the wife, and installed the jlt passenger side catch can. I'm curious to compare with what I'll find.
Fandango is offline   Reply With Quote Quick reply to this message
Old 12-14-2018, 07:26 AM   #397 (permalink)
D45
Member # 102974
Maybe 150-200 miles
Warmer temps the catch barely collects anything and I empty it once a month
Once the temps drop into the 40s and under, it fills up fast
Old 12-14-2018, 08:03 PM   #398 (permalink)
Member # 2147
Send a message via AIM to mbryson Send a message via MSN to mbryson
Not necessarily related specifically to EcoBoost but we are not getting heat in these cooler mornings. 2015 Navigator with 3.5 EcoBoost. Anyone have thermostat issues before 45k miles?
-It's a "real" Jeep TBI 350/700/D300 60/14 bolt 40" Kevlars
mbryson is offline   Reply With Quote Quick reply to this message
Old 12-15-2018, 06:34 AM   #399 (permalink)
D45
Member # 102974
That's interesting......mine is almost at 60,000 miles and it produces heat pretty fast
Old 12-17-2018, 04:24 PM   #400 (permalink)
Member # 2147
It was interesting and a quick diagnosis. Time will tell what we are dealing with. I was down a little over two quarts of coolant. No leaks that I can find. Obviously we'll be monitoring the coolant level religiously for a while.
Amazing that if you have enough coolant, you can get heat....
