Ecoboost Maintenance - Page 17 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-15-2019, 06:24 PM   #401 (permalink)
YotaAtieToo's Avatar
Member # 25632
Checking in
Got the wife a '15 2.7 right after Xmas. Had 25k when we got it and are already up to 31k. Google says the factory oil monitor is really good and to just change it when it tells you too, what does pbb say?
I normally change my own oil, but this is my first vehicle under warranty. I've heard there is a risk of denied warranty work if you change your oil yourself, any truth to this?
Old 02-15-2019, 08:32 PM   #402 (permalink)
TR
TR's Avatar
Member # 2877
Just keep receipts of your oil and filter purchases
Penn State study finds that heavy drinking is 100% easier than giving a shit
TR is offline   Reply With Quote Quick reply to this message
Old 02-17-2019, 06:58 AM   #403 (permalink)
D45
Member # 102974
The turbos are both water cooled.....IICR correctly
My last truck the turbo was oil cooled
I believe that from what I have read is that water (coolant) cooled turbos will last longer, because the bearing temps are able to be cooled off much faster after shutdown
I have not be able to find info if the Eco used bearings in these turbos and if so, how many bearings
2012 Ford F150 FX4; Long Bed; 3.5L V6 ECO; Max Tow; 3.73; Leveled; 275/65R20 Goodyear Duratracs
D45 is offline   Reply With Quote Quick reply to this message
Old 02-17-2019, 08:00 AM   #404 (permalink)
rugby's Avatar
Member # 49997
Water cooled turbos keep the bearings at a more level temperature and keeps the oil from coking up from getting to hot.
From my little bit of Google it looks like the EcoBoost uses plain ole journal bearings not the new fancy wiz bang ball bearings.
rugby is offline   Reply With Quote Quick reply to this message
Old 03-17-2019, 05:07 PM   #405 (permalink)
D45
Member # 102974
I added a drain valve to the bottom of the JLT catch can, which will make draining the can so much easier
Just drilled and tapped a hole in the bottom of the aluminum can, and screwed on a mini ball valve
Works great.......I will get some pics up soon
I did have a rattle develop under the truck and found a broken factory exhaust clamp near the tcase. More quality parts from Ford?
63,000 miles........oil change probably in 3 weeks
Old 03-17-2019, 06:59 PM   #406 (permalink)
Member # 865136
Originally Posted by YotaAtieToo View Post
Checking in
No truth to that at all. Just keep good details, receipts for oil and filters and mileage.
I've been driving my 2011 3.5 for almost 6 years. Been a wicked truck. But would never go over 5K miles on an oil change.
They run hot with turbos and are known to have a lot of fuel blow by into the oil.
Never heard nothing much bad with the 2.7s other than bad factory heads and the oil pans leaking due to being plastic and having crap sealing surfaces.
Sent from my SM-G870W using Tapatalk
winchested is offline   Reply With Quote Quick reply to this message
Old 03-18-2019, 03:11 PM   #407 (permalink)
D45
Member # 102974
Every 4 days............full
Adding a valve will make draining the junk a lot easier and faster
Drilled a hole and taped the threads........pleased to find the bottom was thick enough for some threads
Yes, I know the valve is "open"............I closed it after taking the picture
Old 03-18-2019, 04:24 PM   #408 (permalink)
Member # 865136
This is why I have a 20 Oz dual valve catch can on mine. Don't have to drain it every other day.
Old 03-19-2019, 05:50 AM   #409 (permalink)
D45
Member # 102974
How often do you fill up the 20oz can?
Old 03-19-2019, 11:42 AM   #410 (permalink)
Member # 865136
It would take all summer. Winter months I drain about a pint off every 2 fuel fill ups.
Old 03-20-2019, 09:57 AM   #411 (permalink)
lowerd96's Avatar
Member # 27011
Subscribing to this thread
"Stay Loaded!"
Morgan Hill, California
(408) 778-7800
lowerd96 is offline   Reply With Quote Quick reply to this message
Old 03-21-2019, 03:55 AM   #412 (permalink)
Member # 199790
Every 4 days............full...
Dang, I can get a whole tank out of the wife's 3.5 expy without getting that full.
Fandango is offline   Reply With Quote Quick reply to this message
Old 03-21-2019, 05:57 AM   #413 (permalink)
D45
Member # 102974
It's like this for 4-5 months of the year, when it's cold outside
The rest of the year it barely collects anything , and I have to drain it once a month
Old 03-21-2019, 05:57 AM   #414 (permalink)
D45
Member # 102974
The clunking is back and it's bad again
I can only assume it's the driveshaft splines need greasing again
I am out of warranty come May 2019
I really don't want to pay a $100 deductible and the inconvience of a dealer having my truck for 8 hours
I might do it myself........or explore a one piece driveshaft option
Old 03-22-2019, 03:04 PM   #415 (permalink)
Member # 217714
Would an after market DS fix the issue? Don't know what the factory DS are like but I am assuming a custom build shaft would be much easier to service.
Certified Web Wheeler
Mr. Smiley is offline   Reply With Quote Quick reply to this message
Old 03-22-2019, 06:38 PM   #416 (permalink)
D45
Member # 102974
An aftermarket one piece would be great, to get ride of the 2 piece with the center splines.....that dry out even with the rubber boot
I added a 1 one piece aluminum to my old one ton, best mod ever.
Not sure I want to spend $500 though
Old 03-22-2019, 07:17 PM   #417 (permalink)
Member # 5371
Send a message via MSN to rockota
Dry splines are dry splines... one piece or two piece is irrelevant
rockota is offline   Reply With Quote Quick reply to this message
Old 03-24-2019, 02:52 PM   #418 (permalink)
Member # 852732
Maybe add a grease fitting?
Thatg9659 is offline   Reply With Quote Quick reply to this message
Old 03-31-2019, 12:16 PM   #419 (permalink)
D45
Member # 102974
I just wonder if the slip yoke at the tcase is dry or the splines inside the boot? Or both maybe
I bet I will be able to reuse the boot, no need to order a new one.......right?
I will get two new clamps and some oil this week
Old 03-31-2019, 12:21 PM   #420 (permalink)
Member # 16468
Are those components not painted or plated from the factory?
1969 Jeep M715 6x6 6BT/NV4500/NP202.5 D60/70/70
1963 Jeep J300, 4BT/NV4500/NP200/D60/60
Mikel is online now   Reply With Quote Quick reply to this message
Old 03-31-2019, 03:35 PM   #421 (permalink)
D45
Member # 102974
The rear axle is solid rust also
Ford really skimped out alot on these trucks
Old 03-31-2019, 07:38 PM   #422 (permalink)
Member # 136471
No kidding, the new 10spd ones with no trans skid plate and plastic trans pans is about as dumb as could be. Boss split one with a stick before the first engine oil change.
boardbysled is offline   Reply With Quote Quick reply to this message
Old 04-02-2019, 07:39 PM   #423 (permalink)
D45
Member # 102974
Never had an issue with my the piece aluminum on my Dodge
Old 04-02-2019, 07:40 PM   #424 (permalink)
D45
Member # 102974
I decided to use Amsoil Synthetic Polymeric Off-Road Grease, NLGI #2
(NLGI #2 - 5% Moly)
Only need one clamp and I can reused the current boot
Old 04-02-2019, 08:08 PM   #425 (permalink)
Member # 25632
Did my first oil change on ours. Almost got bit by the stupid "wait 15 mins to check the oil" bull shit.
Why?
