Ecoboost Maintenance - Page 18 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-03-2019, 10:24 AM   #426 (permalink)
Member # 86724
because you've got turbo oil lines and oil coolers and shit that need to drain back into the pan.
Old 04-03-2019, 04:13 PM   #427 (permalink)
D45
Member # 102974
Ecoboost turbos use coolant, not engine oil......right?
2012 Ford F150 FX4; Long Bed; 3.5L V6 ECO; Max Tow; 3.73; Leveled; 275/65R20 Goodyear Duratracs
D45 is offline   Reply With Quote Quick reply to this message
Old 04-03-2019, 04:35 PM   #428 (permalink)
Member # 86724
both.
you have to feed the bearings oil or they're gonna have a bad time. All turbos are oiled, some use coolant to cool them.
http://www.morepowertuning.com/image...Side-Turbo.pdf
the big fat corrugated line on the bottom of the turbo is the oil return line.
eventually you're probably gonna have an oil leak at the turbo.
standard turbo shit. I've done all the orings on my wife's turbo volvo @ 113K. The oil cooler ones too. They didn't leak, but I was there doing other shit and they're simple.
Old 04-03-2019, 06:10 PM   #429 (permalink)
YotaAtieToo's Avatar
Member # 25632
Ya, I realize that, it's never been an issue on my 7.3, 5.9 or any number of equipment I've ran.
I understand it take a minute to drain, but 15?
YotaAtieToo is online now   Reply With Quote Quick reply to this message
Old 04-03-2019, 09:44 PM   #430 (permalink)
Member # 83430
I just wonder if the slip yoke at the tcase is dry or the splines inside the boot? Or both maybe
I bet I will be able to reuse the boot, no need to order a new one.......right?
I will get two new clamps and some oil this week
I'm guessing that only the crew cab long bed versions got a 2 piece driveshaft? My CCSB has a one piece.
Not sure if I mentioned it in this thread or not but a few years ago I thought my truck had the driveshaft clunk as well. Brought it to the dealer and they knew all about it but ended up reprogramming my transmission control module and it got rid of it completely so might be something to think about.
I speak duck. Call me a quack, it's right on target.
InDaRed2 is offline   Reply With Quote Quick reply to this message
Old 04-13-2019, 07:08 AM   #431 (permalink)
D45
Member # 102974
Another oil change complete. Pennzoil had a $10 rebate offer on their 5qt jugs of synthetic, so this oil and filter change was much cheaper
I also completely removed the rear driveshaft from the truck, to grease the splines at the slip yoke at the tcase and also the splines inside the rubber boot near the carrier bearing
Both areas were greased by Ford last May, and both areas were completely dry
I took it out for a test drive last night and it's very smooth, and quiet again. See how this lasts and if the Amsoil grease is any better.
Old 04-17-2019, 09:03 PM   #432 (permalink)
D45
Member # 102974
More Ford quality to deal with.....
Front painted bumper is rusting, badly
Rotated the tires today and the end caps on 4 lug nuts broke right off
Quality!!!
Old 04-21-2019, 05:51 PM   #433 (permalink)
D45
Member # 102974
Old 04-21-2019, 08:11 PM   #434 (permalink)
Member # 86724
is that en electron microscope image?
I fucking hate those lug nuts with the cap. Always happens.
as much as I hate bolts on my eurotrash, at least they are high quality shit.
Old 04-21-2019, 09:25 PM   #435 (permalink)
Member # 83430
Yep those type of lug nuts suck. Pulled 4 caps off on my gf's edge last time I rotated her tires.
Mine on my fuel wheels are almost rounded off from rotating so much. Definitely getting a new set next time.
Have you guys cleaned the 3 map sensors yet? I've read they get pretty dirty and can pick up some milage if cleaned. Need to try mine as I have 163k and haven't cleaned them yet.
Old 04-22-2019, 08:35 AM   #436 (permalink)
D45
Member # 102974
I do clean the MAP every fall, some dirty does come off
Mileage had never been affected
Old 05-14-2019, 07:00 AM   #437 (permalink)
D45
Member # 102974
I am going to have a "return to stock sale" this summer
I will be taking off most everything after market and selling it
Hopefully the truck so be gone before fall, just depending when I find another truck
Debating taking the ARE cap off also and selling it, but I don't see many 6.5 foot bed trucks, in blue
Old 05-14-2019, 07:25 AM   #438 (permalink)
Member # 85771
getting a Dodge?
Make Forums Great Again!
Old 05-14-2019, 01:53 PM   #439 (permalink)
D45
Member # 102974
Yes, looking for a 2500 or 3500 with the 6.4L
Old 05-14-2019, 03:00 PM   #440 (permalink)
Member # 86724
because tired of dicking with this or because you need a won ton truck now?
Old 05-20-2019, 12:24 PM   #441 (permalink)
D45
Member # 102974
Just not impressed with the truck or enjoying the twin turbo life
I am looking for a solid front axle truck, gasser
2500 or 3500
Old 05-21-2019, 06:00 PM   #442 (permalink)
xjtony's Avatar
Member # 50866
2500 or 3500
Any advantage of going with a dodge vs Ford F-250 gasser?
Low Budget Sammy
xjtony is offline   Reply With Quote Quick reply to this message
Old 05-21-2019, 07:18 PM   #443 (permalink)
Member # 25632
I hate to break it to you, but all the brands are getting cheaper. Going to a fiat to get a more quality truck is laughable. Only guy I know with a new 6.4 2500 had to take it back to the dealer twice in the first few hundred miles.
Old 05-22-2019, 06:45 AM   #444 (permalink)
D45
Member # 102974
Ford 6.2 vs Ram 6.4
Not sure which is better, but I prefer the Ram overall
Old 05-22-2019, 06:49 AM   #445 (permalink)
D45
Member # 102974
Ram 6.4L 410 HP @ 5600 429 TQ @ 4000 Ford 6.2L 385 HP @ 5750 430 TQ @ 3800 GM 6.0L 360 HP @ 5400 380 TQ @ 4200 GM 6.2L 420 HP @ 5600 460 TQ @ 4100
Old 05-22-2019, 07:18 AM   #446 (permalink)
Member # 174963
Asking which one to get will give you opinions all over the place, and everyone has a buddy who has either had to take it to the dealer a million times or who has a million miles on it and never changed the oil. The big 3 all make a similar capable, similar quality, similar priced vehicle.
If you've always liked Fords and don't have a bad taste in your mouth over what the last one did to you get another Ford, you will like it better than the Ram. If you hate your current Ford and it did you wrong, get the Ram you'll like it better than the Ford.
lunacy is offline   Reply With Quote Quick reply to this message
Old 05-22-2019, 07:36 AM   #447 (permalink)
Member # 85771
I know three guys that went from Duramax's to the 6.4. They LOOOOVE the 6.4. Keep in mind that they LOOOOOVED the Duramax when they had them also. That's how most folks are I think.
Old 05-22-2019, 11:57 AM   #448 (permalink)
MNorby's Avatar
Member # 11448
Send a message via Yahoo to MNorby
From my friends experience get a 6.4 ram with 4.10s and not 3.73s. My 2015 Silverado 6.0 truck will out tow his 2014 6.4 Ram even though I am 50+ HP lower on paper. The GM has 4.10s and a lower 1st in the tranny though so getting the load moving is a big play there. Watch the TFL trucks or whatever they are called for the IKE gauntlet test.
MNorby is offline   Reply With Quote Quick reply to this message
Old 11-26-2019, 11:37 AM   #449 (permalink)
D45
Member # 102974
Truck might be done for........
Waiting to hear from the insurance company
Old 11-26-2019, 12:01 PM   #450 (permalink)
GLTHFJ60's Avatar
Member # 140040
You wreck it?
1987 4BTJ60 - MoonShine - 4BT/NV4500/EcoBox/NP205/D60/14B
2004 F-550 - 6.0/ZF6 - full bulletproof
GLTHFJ60 is offline   Reply With Quote Quick reply to this message
