Ecoboost Maintenance - Page 7 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-30-2016, 01:50 PM   #151 (permalink)
D45
Member # 102974
Filters, stock vs Banks dry flow
2012 Ford F150 FX4; Long Bed; 3.5L V6 ECO; Max Tow; 3.73; Leveled; 275/65R20 Goodyear Duratracs
D45 is offline   Reply With Quote Quick reply to this message
Old 07-30-2016, 01:51 PM   #152 (permalink)
D45
Member # 102974
Noise wasn't really increased, just a tad.......pulls alot harder and stronger on the highway
Power? Definitely increased.......I can now easily break the rear tires loose
Next week, the AFE Charge Pipe goes on
This was the only odd part of the instructions........10A and 10B.........I did not see the need for the hose barb and used the NPT plug
My truck is a 2012!?
Old 08-02-2016, 07:57 AM   #153 (permalink)
Member # 693905
Is that a "tornado" intake pipe insert?
Ferder is offline   Reply With Quote Quick reply to this message
Old 08-02-2016, 10:57 AM   #154 (permalink)
D45
Member # 102974
Yeah definitely looks like it....... factory vortex
Old 08-02-2016, 12:06 PM   #155 (permalink)
xo_jeep's Avatar
Member # 112255
Ya it comes from the factory like that. I thought it was kinda bizarre the first time I saw it in there.
You boys make me proud. You took my inner thoughts and feelings then expand on them in such colorful and creative ways filled with hate.
xo_jeep is offline   Reply With Quote Quick reply to this message
Old 08-02-2016, 12:43 PM   #156 (permalink)
xo_jeep's Avatar
Member # 112255
Originally Posted by D45 View Post
After this, I will look into tuning..........and MORE
I like that the Banks intake is sealed, draw air using the bottom stock mount and also has an additional inlet, which is front mounted
I was glad to find a kit that came with a dry filter
I went with the S&B dry filter. I hate oiled filters.
I'll also add, get tuning sooner than later. I was running an intake and catless DP (stock muffler) on a canned SCT tune. When I went to a custom tune from 5star it dropped my coolant temps 10 deg and the truck ran a lot smoother. The computer just can't adjust properly for the extra air unless it's programmed correctly. You'll run into a lean condition which is no good for anything.
Look into companies who will update the tune for free for future mods if the parts are bought through them. I know 5 star does. I've been very impressed with their customer service.
Old 08-02-2016, 09:02 PM   #157 (permalink)
D45
Member # 102974
Alot of people are also claiming very good results from swapping in a 170° tstat, to keep temps down
I would love a tuned truck , but I also worry about warranty
Old 08-06-2016, 06:39 PM   #158 (permalink)
D45
Member # 102974
I just bought a Timbren FR1504D SES for $115
New, just needs a bolt kit....which shouldn't be much at all, from a local hardware store
With my truck's 3" tall rear blocks, the factory rear bumpstop is right around 6" away from the axle
This might put the Timbren 2" away from the away axle, but I am ok with that gap.......Timbren says that there should be a ½” to 1 ½” gap between rubber spring and axle to ensure unloaded ride quality
Old 08-10-2016, 02:30 PM   #159 (permalink)
D45
Member # 102974
I found a used tailgate access panel, so I can finally remove the plastic tailgate liner and the stripper pole
The cap will come off the bed soon, along with the factory bedliner...........so that everything can be sprayed with a bedliner.
I love LineX, but hate the price.....I am currently exploring other options and prices
Old 08-10-2016, 06:37 PM   #160 (permalink)
D45
Member # 102974
Subtle front end change........from the bright blue oval grill emblem to a grey and black emblem
Subtle, but nice
Old 08-10-2016, 06:42 PM   #161 (permalink)
D45
Member # 102974
The "parts missing" Timbren kit arrived today.......just needs some bolts, easy and cheap
Old 08-10-2016, 08:17 PM   #162 (permalink)
Insurance poor
Rttoys's Avatar
Member # 140853
You will hate life after these are installed. Hope you have a back brace.
I installed these on one work truck. Biggest. Mistake. Ever. Very very harsh when they hit.
'80 CJ7- soon to start project "always changing directions"
'84 CJ7- all stock farm rig, except a bunch of gun racks
'79 CJ5- not stock- way too much to list
Rttoys is offline   Reply With Quote Quick reply to this message
Old 08-10-2016, 08:21 PM   #163 (permalink)
D45
Member # 102974
I'll see how they do....... if they are this bad, I'll remove and sell them then......I bought them for a steal deal
Old 08-11-2016, 04:36 PM   #164 (permalink)
Insurance poor
Rttoys's Avatar
Member # 140853
I love the concept and was looking forward to installing them on all 60 of my fleet, but after the first one went on, I knew I made a mistake.
Hopefully they won't touch when running unloaded, you will know when they do though.
Old 08-11-2016, 06:49 PM   #165 (permalink)
D45
Member # 102974
Hopefully with the 2" taller than stock rear blocks, they will only touch when needed
I could see it being an issue with stock rear suspension setup
Old 08-12-2016, 10:05 AM   #166 (permalink)
Member # 171191
2013 with 33k... going in on Tuesday for a timing chain.. Rattles like a mofo on a cold start. Anyone else had this yet? TSB 14-0194
bweezy is offline   Reply With Quote Quick reply to this message
Old 08-12-2016, 11:58 AM   #167 (permalink)
D45
Member # 102974
TSB 14-0194
FORD:
2011-2014 F-150
ISSUE
Some 2011-2014 F-150 vehicles equipped with a 3.5L Gasoline Turbocharged Direct Injection (GTDI) engine and built on or before 10/10/2014 may exhibit a malfunction indicator lamp (MIL) illuminated with diagnostic trouble code (DTC) P0016. Other DTCs and driveability concerns may also be present. This concern may be due to a worn primary timing chain.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1. Is the vehicle build date on or before 10/10/2014?
a. Yes - proceed to Step 2.
b. No - this procedure does not apply. Refer to Powertrain Control/Emissions Diagnosis (PC/ED) manual for normal diagnosis.
2. Using Integrated Diagnostic System (IDS), with key on and engine running (KOER), select the VCT_INT_ACT1 Parameter Identification Data (PID) in the Datalogger.
a. If VCT_INT_ACT1 PID reads +6 degrees or greater, proceed to Step 3.
b. If VCT_INT_ACT1 PID reads +5 degrees or less - this procedure does not apply. Refer to Powertrain Control/Emissions Diagnosis (PC/ED) manual for normal diagnostics.
3. Replace the primary timing chain. Refer to Workshop Manual (WSM), Section 303-01.
PART NUMBER/PART NAME
AT4Z-6268-C Primary Timing Chain
AA5Z-9439-A Intake Gasket
BL3Z-6584-A Cam Cover Gasket - Left Hand
BR3Z-6584-B Cam Cover Gasket - Right Hand (2011-2012)
DL3Z-6584-B Cam Cover Gasket- Right Hand (2013-2014)
BL3Z-9E583-B High Pressure Pump O-ring
BR3Z-8507-C Pump Gasket
BR3Z-8527-A Pump O-ring
7T4Z-8590-A Coolant Inlet Seal
XW4Z-6700-AA Crankshaft Seal
BR3Z-6020-A Front Cover Radial Seal
F5RZ-6A340-B Damper Bolt
TA-357 Motorcraft® High Performance Engine RTV Silicone
VC-30-A Motorcraft® Silicone Gasket Remover
VC-31-B Motorcraft® Metal Surface Prep Wipes
VC-3-B Motorcraft® Orange Antifreeze/Coolant Concentrated
XO-5W30-QFS Motorcraft® SAE 5W-30 Full Synthetic Motor Oil
TA-25-B Motorcraft® Threadlock and Sealer
TA-24-B Motorcraft® Thread Sealant with PTFE
My truck is still very, very quiet........31,000 miles
Old 08-13-2016, 04:44 AM   #168 (permalink)
TR
TR's Avatar
Member # 2877
Damn, the dealership told me that rattle on cold start was due to my aftermarket exhaust. Looks like it's going to the dealer
Penn State study finds that heavy drinking is 100% easier than giving a shit
TR is offline   Reply With Quote Quick reply to this message
Old 08-15-2016, 08:06 PM   #169 (permalink)
D45
Member # 102974
550 miles (one way) trip to Lake of the Ozarks....... three adults, bed fully loaded and packed, pulled a travel trailer
Had horrible timing chain rattle "type" noise twice, had to let off the throttle and ease back into it
Not sure it was timing chain rattle or slapping, but it killed power and sounded bad
Misfire from moisture maybe?
See what happens on the trip home in two days
Old 08-16-2016, 09:37 AM   #170 (permalink)
Member # 171191
that sounds like something different then what my truck is doing. My only rattles on a cold start. It will rattle for a 1-2 seconds until the hydraulic tensioner catches up and takes the slack out of the stretched chain. i took it in, inspected it, and said it was covered under warranty. *cough* running MPT tunes *cough*
Old 08-16-2016, 12:14 PM   #171 (permalink)
Member # 141351
just took our '13SCREW XLT max tow on 8,000km (4300kms towing) round trip tour of our east coast, 24'TT 3kids wife dog & I.
doubt it's related, but when towing heavy loads this truck likes premium fuel. added cost was offset by better mileage, not a lot but every bit helps. I use tow mode UNLESS coasting/downhill, as it gears down un-neccessarily.
never experienced any engine issues since day 1, and just over 91,000kms on it now
insert something witty here...
beakie is offline   Reply With Quote Quick reply to this message
Old 08-18-2016, 06:41 PM   #172 (permalink)
D45
Member # 102974
Trip back home today was perfect, no hiccups or noises
Old 08-18-2016, 09:06 PM   #173 (permalink)
Member # 106178
That sounds more like pinging to me.
takotruckin is offline   Reply With Quote Quick reply to this message
Old 08-19-2016, 08:02 AM   #174 (permalink)
D45
Member # 102974
I like the tailgate step, but the handle gets in the way, ALL the time
I found this cool delete project.........that I will do before the bed gets sprayed this summer
Looks to be around $50
9L3Z9943121A -$44.26
W710734-S439 - $1.08 ea
From what I have found, I will need 13 bolts, that are 6mm x10mm ........I will just try to buy them local, rather than $1.08 each
Remove the plastic tailgate liner, remove the pole and brackets..........and install this patch panel
Removing Tail Gate Pole - Ford F150 Forum - Community of Ford Truck Fans
Picked up this used panel
Going to take everything off the tailgate and see how it fits......then off to LineX
Old 08-19-2016, 07:33 PM   #175 (permalink)
D45
Member # 102974
