F800 Toy Hauler - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-01-2016, 08:12 PM   #26 (permalink)
Member # 84464
Seems like you may as well just leave the buggy home and wheel this
God Bless America
mike_belben is offline   Reply With Quote Quick reply to this message
Old 11-02-2016, 05:34 AM   #27 (permalink)
Dinkerdoodledoo
Member # 10448
Send a message via Yahoo to Grendel
Originally Posted by kayjef View Post
I thought the 15.5r20 Michelin's were a 48/49" tire? I may be wrong though. The numbers/sizes do seem different with different manufacturers.
I also thing 46's, especially if you got overdrive with that axle ratio would work good.
I am in for this build either way!
I didn't know they made a 15R20.
I have 14R20 and 16R20s. I may go with 16R21's on a project.
The 14R20 Michelin XL is smaller than the XML/XZL variant.
Youre the only person on earth who knows all the details of your life, and thus, you are the most qualified captain of your own ship. Dont worry about justifying your course for pirate's sake. There's always someone here to tell you that you did it wrong.
Grendel is offline   Reply With Quote Quick reply to this message
Old 11-02-2016, 10:29 AM   #28 (permalink)
Member # 192711
Michelin 15.5-R20 XL 46" tall tires 95%+ | C&C Equipment
15.5r20 XL = 46"
google tells me the 14r20 Michelin XZL's are 49's.
Funny how even in one company they can't be consistent on sizes.
[SIZE="3"]https://www.facebook.com/dr.k.motorsports/[/SIZE]
kayjef is offline   Reply With Quote Quick reply to this message
Old 11-13-2016, 10:10 PM   #29 (permalink)
CDN Rockwell dist
680oscar's Avatar
Member # 168676
Looking forward to seeing this come together, if you need any driveline adaptors I have a bunch of different options that will work with those waffle flanges on the narrow axles.
2.5 / 5 ton Rockwell, Meritor and Axletech parts and axles for sale in Canada.
680oscar is offline   Reply With Quote Quick reply to this message
Old 11-15-2016, 07:35 AM   #30 (permalink)
Member # 74407
I doubt we'll see any more updates.
https://www.pirate4x4.com/forum/38826018-post1418.html
TireFryerSS is offline   Reply With Quote Quick reply to this message
Old 12-08-2016, 09:09 PM   #31 (permalink)
Newbie
MiniMonster's Avatar
Member # 114593
Sorry guys, the password update got me. My email was not up to date and it took a while to get back on here.
Not a whole lot of progress, other than mounting the 16R20s on the stock rear axle. Since the 9spd Roadranger does not have an OD ratio and the axle is 4.33 I needed a taller tire to end up with a good road speed. Once I get the Techs in I will have to replace the range box on the Roadranger, add a brownie box or find a 10spd double OD trans. I'm loving the current setup with 4.33/53s.
Thanks to Poorboy I have an air ride suspension off a Freightliner for the rear axle. Hopefully it will be a mostly bolt-in swap once I adapt from round to square axle tubes.
09 tube buggy. Propane SBC350/TH350/NP203/NP205, 1410s, 3linked/locked D70s f/r, 44 TSLs
MiniMonster is offline   Reply With Quote Quick reply to this message
Old 12-09-2016, 08:31 AM   #32 (permalink)
old school idiot
wilez5150's Avatar
Member # 86194
when I installed the FL70 air ride in my 93 F800 none of the holes lined up. it was easy to do just time consuming drilling all the holes. it helps if you can remove the bed for better access. a mag drill will be your best friend
USN 2x Viet Nam Vet.
life member Victor Valley 4 Wheelers
82 Yota with some stuff
F Toy #20
86 CUCV with some stuff
F 800 toter ho
retired wheeler
if you don't roll it over once in a while you aren't trying hard enough
wilez5150 is offline   Reply With Quote Quick reply to this message
Old 12-09-2016, 09:01 AM   #33 (permalink)
Member # 74407
Of course you love the 4.33s and 53's. Now imagine if you put set of 3.23-3.55ish gears and normal tires on that truck.
I dont understand the want to put some huge tires on a tow rig.
Old 12-09-2016, 09:15 AM   #34 (permalink)
Member # 83301
Brah......
'79 chevy k30 vortec 350/sm465/205/205/5.13's 40" NITTO trail grapplers on dirtylife beadlocks.
Old 12-09-2016, 10:59 AM   #35 (permalink)
Member # 74407
Originally Posted by pennsylvaniaboy View Post
Brah......
You're right brah, my bad.
Roll coal and keep your sunglasses white.
Old 12-09-2016, 04:54 PM   #36 (permalink)
Back Woods's Avatar
Member # 74825
What are your cruising rpms?
Back Woods is offline   Reply With Quote Quick reply to this message
Old 12-17-2016, 10:09 PM   #37 (permalink)
Newbie
Member # 114593
The 53s are to help offset the Axletech gears, and to get around on the farm. I need to drive through mud half the year and stock 11R22.5 road tires do not fare well. I agree the flatbed is higher than I would like. I've thought about adding heavy drive-over fenders to clear the 53s without lifting the chassis.
Cruising RPM is 1500-1700 on the highway. I had it up to 70mph a few times but normally cruise at 60-63
Old 12-22-2016, 07:02 PM   #38 (permalink)
Member # 723569
how much did the truck cost
TJRUSSELL is offline   Reply With Quote Quick reply to this message
Old 01-01-2017, 01:59 PM   #39 (permalink)
Newbie
Member # 114593
I traded my 98 Dodge Cummins for it, valued at about $9,500. These trucks are much more common and less expensive with a standard cab. Now that I know the F600/700/800 comes with a standard Ford pickup cab, if I was to do it again I would buy a cheap standard cab truck and swap on a crew cab off a worn out F250/350. As far as I can tell only the front clip and cowl are different and look like they would bolt up easily.
I'm still looking for an appropriate T-case, as the Rockwell 226 case I have is to rusty to rebuild.
Old 01-01-2017, 09:12 PM   #40 (permalink)
jones518's Avatar
Member # 152143
I have a 97 F250 and the F800 https://www.pirate4x4.com/forum/tow-r...cab-build.html the firewalls are a bit different and the f800 has a large removable doghouse. That being said, Backwoods did exactly what you are referring too. He just had to cut some "donor" metal off of old cab to graft into f250/350 crew cab.
jones518 is offline   Reply With Quote Quick reply to this message
Old 01-02-2017, 06:07 AM   #41 (permalink)
Dinkerdoodledoo
Member # 10448
I have an M939A2 t-case here.
Old 01-07-2017, 11:48 PM   #42 (permalink)
Newbie
Member # 114593
How much for the case and how much to get it to 97374? Or possibly OK?
Is that the T1138 with 0.73 high range? That ratio would be perfect for my final highway gear.
Old 03-23-2017, 08:48 PM   #43 (permalink)
Newbie
Member # 114593
Progress!! I've been collecting parts and pieces for almost a year now, so it is pretty cool to see things coming together.
I've been lucky enough to have use of the LBCC Heavy Equipment shop and all of the big tools in it. The truck still has a long way to go, but at least its sitting on a full set of 53s now.
Freightliner tie rod custom machined to fit the 38mm x 1.5 thread of the drag link end. I'll sleeve it before it goes on the road. I had to get the rig out of the shop for spring break so there are several things to clean up before driving.
Old 03-23-2017, 08:57 PM   #44 (permalink)
Member # 56256
God damn thats huge and awesome!
Java is offline   Reply With Quote Quick reply to this message
Old 03-24-2017, 08:39 AM   #45 (permalink)
GLTHFJ60's Avatar
Member # 140040
Bad ass!!!!
1987 4BTJ60 - MoonShine - 4BT/NV4500/EcoBox/NP205/D60/14B
2004 F-550 - 6.0/ZF6 - full bulletproof
GLTHFJ60 is offline   Reply With Quote Quick reply to this message
Old 03-24-2017, 10:01 AM   #46 (permalink)
perfection in plasma
carslut's Avatar
Member # 25823
Send a message via ICQ to carslut
holy WOW!
carslut is offline   Reply With Quote Quick reply to this message
Old 03-26-2017, 12:02 AM   #47 (permalink)
Newbie
Member # 114593
Who has yokes for a Rockwell 1138? I need to fit 1710 drivelines to this case, at least for the intermediate and rear.
I also need bushings for the frame mounts. I could build some but maybe you guys have a lead on stock bushings?
Old 03-27-2017, 10:52 PM   #48 (permalink)
Cotton Farmer
Member # 167491
Send a message via ICQ to jd8420
I think I have some new 1610 driveshafts for the round flanges if that will do you any good. What is the measurement of the bolt pattern of the flange?
jd8420 is offline   Reply With Quote Quick reply to this message
Old 04-06-2017, 06:46 AM   #49 (permalink)
Member # 547146
FYI the pictures aren't working.
In for what seems to be an Awesome build.
khess3217 is offline   Reply With Quote Quick reply to this message
Old 05-22-2017, 10:21 PM   #50 (permalink)
Newbie
Member # 114593
I need the 8" flange with 7-1/4" 8-bolt circle. How much for the shaft you have?
I also need a Tech 4000 yoke for the rear axle, as large as possible. I'm ok with the stock waffle pattern flange in the front but don't trust it in the back. Stock is 1710 and I want to stay as close to that as possible.
Sorry about the pics, my Photobucket acct is messed up. I'll try and load them again when I get a minute.
