F800 Toy Hauler - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-23-2017, 10:31 AM   #51 (permalink)
Cotton Farmer
Member # 167491
Send a message via ICQ to jd8420
Originally Posted by MiniMonster View Post
I need the 8" flange with 7-1/4" 8-bolt circle. How much for the shaft you have?
I also need a Tech 4000 yoke for the rear axle, as large as possible. I'm ok with the stock waffle pattern flange in the front but don't trust it in the back. Stock is 1710 and I want to stay as close to that as possible.
The 8" flange with a 8 on 7.25" bolt pattern is what I have. $100 each. Shipping might be high if you want the whole shaft or I could cut the tubing out and send it pretty easy. Fastenal has not been shipping to the western states for the last few months.
A few axletechs have a large round flange that looks like the 5 ton flange. Might be worth sending the axletech guy on here a pm.
jd8420 is offline   Reply With Quote Quick reply to this message
Old 05-23-2017, 10:35 PM   #52 (permalink)
Newbie
MiniMonster's Avatar
Member # 114593
How would I find said Axletech guy? A large flange would be a good start towards mating up a 1710. I've seen one Tech shaft on EBay that had two different flanges on it.
09 tube buggy. Propane SBC350/TH350/NP203/NP205, 1410s, 3linked/locked D70s f/r, 44 TSLs
MiniMonster is offline   Reply With Quote Quick reply to this message
Old 05-23-2017, 10:55 PM   #53 (permalink)
Cotton Farmer
Member # 167491
His screen name on here is 02rexwi
Old 08-23-2017, 11:55 PM   #54 (permalink)
Newbie
Member # 114593
Air suspension progress. I built a sub-frame of 3"x4"x0.375" tube to make the rear ride height closer to the front. It's still 2" lower in the rear but close enough for now. I thought about going spring over, but that would lift it about 4" higher than the front.
Old 08-24-2017, 03:52 PM   #55 (permalink)
Newbie
Member # 114593
Couple more pics of the truck at stock height.
Old 08-31-2017, 10:38 PM   #56 (permalink)
Newbie
Member # 114593
All my pictures are out of order because of Photobucket charging now and moving all my pics to Pirate. Anyway, I'll try and keep pics together.
3"x4"x0.375" Sub-frame tabs to main frame.
Shortening the Freightliner track bar by 4" to clear the frame. Sleeve was slid over and welded in after this pic.
Of course the track bar bracket had to land right on top of the axle breather, so now I have a breather out the side of my bracket.
Old 08-31-2017, 10:46 PM   #57 (permalink)
Newbie
Member # 114593
New air brake lines. Side note, parking and service brake chambers appear to be the same on both sides, not mirror image. That means lines have to be crossed on one side to have correct function. Some puzzlement went into figuring that out.
Finally got to drive it home from school. Slow drive, going from 4.33 stock ratio to 5.65 in the AT4000. I didn't have time at school to switch the 53s from Bud wheels to Axletech, so I threw 46s on it to save time.
Rockwell T1138 transfer case lowered into the frame, ready for mounts.
Old 08-31-2017, 10:54 PM   #58 (permalink)
Newbie
Member # 114593
Lots of parts had to be moved to make room for the case, including air drier, tanks, exhaust, battery box and some drain fittings.
Rear driveline shortened from 46" to 27"
8" diameter 1710 series driveline flange.
Old 09-01-2017, 02:37 AM   #59 (permalink)
Back Woods's Avatar
Member # 74825
Nice work, I like the stance.
Back Woods is offline   Reply With Quote Quick reply to this message
Old 09-01-2017, 07:33 AM   #60 (permalink)
Member # 687322
Very cool, thanks for the updates.
DNL2 is offline   Reply With Quote Quick reply to this message
Old 09-01-2017, 09:19 PM   #61 (permalink)
Newbie
Member # 114593
A 36" jackshaft puts the case just about center of the wheelbase, and leaves space for air tanks, unlike the 24" shaft I could have used.
2"x6"x0.250" tube skid plate.
Mock up of skid plate.
Old 09-19-2017, 10:33 AM   #62 (permalink)
02rexwi's Avatar
Member # 230201
Very cool build! Keep those pictures coming.
02rexwi is offline   Reply With Quote Quick reply to this message
Old 12-01-2017, 07:45 PM   #63 (permalink)
Member # 811266
Update? I so want to do this same thing!
StayAtHomeDad is offline   Reply With Quote Quick reply to this message
Old 08-05-2019, 08:56 PM   #64 (permalink)
Dinkerdoodledoo
Member # 10448
Send a message via Yahoo to Grendel
What's up with this?
Sorry I missed your question on the t-case, looks like you found one.
I plan to build a 1941 Chevy G506 on a MDT chassis with AT4K's.
What u bolts did you use in the front? Do you have specs?
Youre the only person on earth who knows all the details of your life, and thus, you are the most qualified captain of your own ship. Dont worry about justifying your course for pirate's sake. There's always someone here to tell you that you did it wrong.
Grendel is offline   Reply With Quote Quick reply to this message
