Box truck to RV conversion. Crew Cab f450 - Page 47 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-04-2019, 08:52 AM   #1151 (permalink)
Member # 56256
Thoughts on the smoking?
Seems it's over fueling. I can make smoke by rolling on the throttle at any speed....
Stuck injector maybe? No CEL
Pedal is pretty dead until it drops a gear and gets over 2k.
No obvious boost leaks, torn couplers etc
Sent from my SM-G950U using Tapatalk
F450 Box Truck to RV conversion www.NWadventuretruck.com
Java is offline   Reply With Quote Quick reply to this message
Old 05-04-2019, 07:30 PM   #1152 (permalink)
Member # 147348
Stuck injector would be white smoke. My bet is exhaust or intake leak. You can build a intake leak checker pretty easily. Exhaust is a little tougher, usually soot tells the tale.
Also could be vgt is stuck? Maybe
CarterKaft is offline   Reply With Quote Quick reply to this message
Old 05-05-2019, 07:31 AM   #1153 (permalink)
Member # 56256
Ok good to know. All the up pipes are new. So hopefully it's not that. I'll try to take a peek.
No obvious boost leaks, but hard to tell just at idle.
Servo and vanes seem to move fine, just with my hand anyway.
Old 05-05-2019, 09:28 AM   #1154 (permalink)
Member # 60351
Sounds exactly like my old 6.0 when fuel pressure dropped.
Are 6.4s as sensitive to fuel pressure?
nhnissan is offline   Reply With Quote Quick reply to this message
Old 05-05-2019, 09:34 AM   #1155 (permalink)
Member # 56256
Yes, nearly the same engine.
Black means too much fuel tho isn't it? Frame rail filter was just changed, engine filter within 5k or so. I'd have to check
Old 05-05-2019, 11:25 AM   #1156 (permalink)
Member # 60351
I don't know about 6.4 because of common rail vs heui on the 6.0.
And I don't know why, but every time my filters got clogged up, and when the HFCM started to die, It would smoke real bad, have shit for power, and have trouble shifting.
Old 05-06-2019, 12:42 PM   #1157 (permalink)
Member # 56256
Googling..... Similar symptoms show a few common items:
EBP Sensor
MAP Sensor
Or the EGR valve being blown open a little due to high boost. (its turned off/closed via the tuner, but I also did blow one of the charge air boots off, maybe it was a high boost?)
Or the VGT Servo, moves freely tho key off.
Or the atmospheric turbo has shit the bed.
Thoughts? And suggestions for a code reader that can see senor values etc?
Old 05-06-2019, 01:51 PM   #1158 (permalink)
v6toy4x's Avatar
Member # 9154
I AM GOING TO SAY WHAT OTHERS WANT TO BUT WON'T
C
U
M
M
I
N
S
Good luck!
GOD MADE DIRT, MOTHER NATURE MADE THE ROCKS & HEAVEN MADE THE LAKES
THANK GOD FOR MOTHER NATURE I AM IN HEAVEN
85 4rnr,8"hp,9"det,R151,toybox,d300 4:1
98.5 dodge,EZ,TST,ex brk,Goerend,ford outers,quad bags
'05 arctic fox-880wts solar,inverter,cocktail cubes 24/7
502cu in boat EVIL SATISFACTION
v6toy4x is offline   Reply With Quote Quick reply to this message
Old 05-06-2019, 01:54 PM   #1159 (permalink)
v6toy4x's Avatar
Member # 9154
You do need to get this sorted, I need somebody to jump on the LifePo4 battery wagon with me!
Old 05-06-2019, 01:59 PM   #1160 (permalink)
Member # 56256
C
U
M
M
I
N
S
Good luck!
Old 05-06-2019, 02:02 PM   #1161 (permalink)
Member # 56256
Yeah I just need to figure out whats going on.
It did this once before and uninstalling and reinstalling the software cured it.
Wondering if it might be the EGR valve blowing open? I have some hunting to do tonight.
Old 05-06-2019, 07:27 PM   #1162 (permalink)
Member # 56256
EBP is clean, MAP was dirty, but cleaned and no different. Cleaned MAF.
I May have been wrong about the egr valve being commanded closed. I can't find that setting now. Unless it's built into the software.
VGT actuator moves upon startup. Moves freely.
Old 05-07-2019, 07:41 AM   #1163 (permalink)
GLTHFJ60's Avatar
Member # 140040
High pressure oil leak? Unplugged injector or damaged injector harness?
Pull the codes, even if the CEL isn't on. If there's a tune on the truck, the CEL might not come on even if there is a code.
1987 4BTJ60 - MoonShine - 4BT/NV4500/EcoBox/NP205/D60/14B
2004 F-550 - 6.0/ZF6 - full bulletproof
GLTHFJ60 is offline   Reply With Quote Quick reply to this message
Old 05-07-2019, 08:08 AM   #1164 (permalink)
Member # 56256
https://www.youtube.com/watch?v=ZkDel_OmmJk
No codes are able to be pulled by my scanners..... Only one that came back when going back to stock tune was the KAM error, which generally happens with a tune being installed or uninstalled.
No obvious high pressure oil leak, oil is full ( a little over actually....)
If there was an injector issue wouldn't it throw a code?
Any idea if the variable vanes can stick even if the actuator is moving fine?
Old 05-07-2019, 08:32 AM   #1165 (permalink)
GLTHFJ60's Avatar
Member # 140040
I'm not familiar with the 6.4 turbo setup other than via google images. If the actuator rod is moving freely when attached to the turbo, then the vane ring must be turning, which means the vanes can't be stuck per my understanding.
High pressure oil leaks are not visible, and leak internally if they are leaking at all. You must read the HPOP numbers with a bluetooth reader and an app like torque pro.
I'm more well versed with the 6.0, sorry I can't be of more help.
Old 05-07-2019, 08:44 AM   #1166 (permalink)
Member # 56256
No worries, appreciate any more minds thinking on it!
Agree on the turbo, actuator moves, the vanes must be moving. Unless there is a friction fit or something else inside....
The injectors are piezo on this motor, not oil driven like the 6.0's
Old 05-07-2019, 09:39 AM   #1167 (permalink)
Back Woods's Avatar
Member # 74825
Does it idle smooth with no miss through the RPMs free revving?
Back Woods is offline   Reply With Quote Quick reply to this message
Old 05-07-2019, 09:57 AM   #1168 (permalink)
Member # 56256
Correct, idle is perfect, revs freely (smokes even in neutral tho). But under load does not want to make boost from take off.
Old 05-07-2019, 10:34 AM   #1169 (permalink)
mothfuckle
fredycruger's Avatar
Member # 225557
might be boost leak
fredycruger is offline   Reply With Quote Quick reply to this message
Old 05-07-2019, 10:44 AM   #1170 (permalink)
Member # 56256
Originally Posted by fredycruger View Post
might be boost leak
Nothing obvious, building pressure tester tonight.
Old 05-07-2019, 02:49 PM   #1171 (permalink)
Member # 193950
What does your scantool say that boost pressures are?
Aaron Z
At some point you have to accept that lots of naturally-occurring substances can kill you-Solandri
aczlan is offline   Reply With Quote Quick reply to this message
Old 05-07-2019, 02:58 PM   #1172 (permalink)
Member # 56256
Aaron Z
35+ is no problem, just getting the initial 10 so is hard.
Old 05-07-2019, 03:56 PM   #1173 (permalink)
Member # 56256
Well if the egr valve wasn't the issue, it certainly is now....
Pressure tested. No leaks (big ones anyway... My compressor is small)
Pulled the plunger all the way out (closed I assume) and truck runs better! Still a little smoke, but power off the line is noticeably better.
Old 05-07-2019, 04:15 PM   #1174 (permalink)
Member # 147348
Yuck, hope that gets better. Is there a EGR delete or block off plate you can install while you are in there?
I have just cut stainless steel gaskets for Duramax's
Old 05-07-2019, 05:21 PM   #1175 (permalink)
Member # 56256
Yep, just ordered a delete kit. Removes the coolers and that valve, replaces it with a smooth elbow. (gets rid of the throttle body too?)
Luckily we don't have plans for the truck this weekend.
Now 6.0/6.4 guys, waste gate needed or not?
