Box truck to RV conversion. Crew Cab f450 - Page 52 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-20-2019, 07:44 AM   #1276 (permalink)
107
christyle's Avatar
Member # 39660
Originally Posted by Java View Post
I dont have room for a two gallon tank..... Maybe not even the small accumulator....
If you're going to the overland rally thing, do like the overlanders, and make your own out of ABS bro!
christyle is offline   Reply With Quote Quick reply to this message
Old 06-20-2019, 07:51 AM   #1277 (permalink)
Member # 79578
No idea on sizing them, but the expansion tank just makes the pump not needed for the first 1.75 gallons or whatever till the pressure drops. What pressure are you running on the air side of it? FWIW its supposed to match the delivery pressure.
Right. It just increases the time between the low pressure "on" and high pressure "off" set points. The pump is positive displacement. With only the pipes for capacitance in the system, the pump can bang between the set points while trying to put out more flow than your faucet is taking. The accumulator just takes the extra flow and stores it.
The instructions said to set the bladder within 2 psi of the delivery pressure. My pump is supposed to make 50 psi, according to the specs sheet. In reality, it's more like 35 or 40 psi. I set the bladder based off the high shut off pressure. Guys say you can play with the bladder pressure to get the most capacity possible. I kind of set it and forgot about it. lol
Please, Try My Product
sb406 is offline   Reply With Quote Quick reply to this message
Old 06-20-2019, 07:54 AM   #1278 (permalink)
Member # 56256
I have a real outdoor shower..... With a hot water heater!
Originally Posted by sb406 View Post
Right. It just increases the time between the low pressure "on" and high pressure "off" set points. With only the pipes for capacitance in the system, the pump can bang between the set points while trying to put out more flow than your faucet is taking. The accumulator just takes the extra flow and stores it.
Good, just dont leave them at the factory 2 psi or whatever they put in them, they wear out quick if the pressure isnt close to delivery pressure.
F450 Box Truck to RV conversion www.NWadventuretruck.com
Java is offline   Reply With Quote Quick reply to this message
Old 06-20-2019, 08:25 AM   #1279 (permalink)
Member # 56256
Passthrough trim done!
Attempted to bathe truck. Its marginally cleaner....
Old 06-20-2019, 10:52 AM   #1280 (permalink)
Member # 147348
You saved that pass through upholstery job, it had me scratching my head with the trim-less picture. I was thinking this guy does super clean work on all the other stuff he does then throws this curtain around the hole with staples and shit everywhere....
I should have known better.
CarterKaft is offline   Reply With Quote Quick reply to this message
Old 06-20-2019, 11:10 AM   #1281 (permalink)
Member # 56256
Ha I guess I should have added a disclaimer in there that it wasn't done yet
Old 06-20-2019, 11:13 AM   #1282 (permalink)
Member # 95025
Dumb question:
Does the tube get pressurized somehow or is the water just gravity-fed?
ΜΟΛΩΝ ΛΑΒΕ
President Trump on building the wall:
"THIS IS WHERE WE HOLD THEM!!! THIS IS WHERE WE FIGHT!!! THIS IS WHERE THEY'RE DEPORTED!!!"
V.P.Pence:
BUILD THIS WALL, BOYS!!!
Fearless Indians:
Awe-Ooo!!!
CDA 455 is offline   Reply With Quote Quick reply to this message
Old 06-20-2019, 11:27 AM   #1283 (permalink)
107
christyle's Avatar
Member # 39660
They usually put a schraeder on it to pressurize it.
Old 06-20-2019, 12:13 PM   #1284 (permalink)
Member # 95025
That's what I thought.
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 06-24-2019, 09:38 AM   #1285 (permalink)
DT75FLH's Avatar
Member # 101209
i put a small bicycle air pump in my tool box to pressure it up in beween fills...couple of pumps works and it is so nice to have pressurized water.
[COLOR="DarkRed"]Difficulty is the excuse history never accepts.
A Nation of sheep will beget a Government of wolves.[/COLOR]
Edward Murrow
DT75FLH is offline   Reply With Quote Quick reply to this message
Old 06-25-2019, 07:51 AM   #1286 (permalink)
Member # 56256
Good times as always at the NWOR! Weather was great, got to see lots of old friends I don't get to see to often. Lots of drool worthy trucks and thanks to all the vendors!
Nightly raffle is always fun!
Snuck out and climbed Peshastin one morning.
Entered the cooking competition and won!
Old 06-25-2019, 06:59 PM   #1287 (permalink)
v6toy4x's Avatar
Member # 9154
Pineapple brown sugar cake??
That looks good
GOD MADE DIRT, MOTHER NATURE MADE THE ROCKS & HEAVEN MADE THE LAKES
THANK GOD FOR MOTHER NATURE I AM IN HEAVEN
85 4rnr,8"hp,9"det,R151,toybox,d300 4:1
98.5 dodge,EZ,TST,ex brk,Goerend,ford outers,quad bags
'05 arctic fox-880wts solar,inverter,cocktail cubes 24/7
502cu in boat EVIL SATISFACTION
v6toy4x is offline   Reply With Quote Quick reply to this message
Old 06-25-2019, 07:09 PM   #1288 (permalink)
Member # 56256
That looks good
Pineapple upside down cake! With brown sugar and blueberries! And marshmallows frosting. Marshmallows were the ingredient we had to use in both dishes.
Sent from my SM-G973U using Tapatalk
Old 06-25-2019, 07:33 PM   #1289 (permalink)
v6toy4x's Avatar
Member # 9154
AND MARSHMALLOWS!
I just gained 5 lbs looking at that thing
Old 06-25-2019, 07:35 PM   #1290 (permalink)
Member # 56256
AND MARSHMALLOWS!
It was goooooood, she made an almost cream cheese kind of frosting..... And I didn't burn the cake! Had to use marshmallows in beef stroganoff to oh, that was entertaining....
Old 06-26-2019, 06:02 PM   #1291 (permalink)
Member # 174683
How’d the kegerator run?
tab2 is offline   Reply With Quote Quick reply to this message
Old 06-26-2019, 06:03 PM   #1292 (permalink)
Member # 56256
Fan fawking tastic! Ran a while keg thru it. Plus kept other groceries in it too!
Old 06-29-2019, 10:35 AM   #1293 (permalink)
107
christyle's Avatar
Member # 39660
Foam stayed down on it? How you handle the keg? Did you put any water to submerge the plate or no? I hear people swear you have to submerge the plate to get some good conduction, but that's with ice and a cooler
Old 06-29-2019, 10:58 AM   #1294 (permalink)
Member # 56256
It worked great! Minimal foam once the keg settled. Keg was stashed under the truck out of the sun ambient was 75ish.
Had a couple zip locks of ice on the plate (that I was just using for other drinks). It was definately less cold and slightly foamier if you poured 3 or 4 pints in a row.
Old 06-30-2019, 10:36 AM   #1295 (permalink)
Member # 1515
Send a message via AIM to Po' riggity Send a message via Yahoo to Po' riggity
I just read through all 26 pages of this build, and this is seriously awesome. I have nothing of substance to add, except this. If you haven't replaced your leveling blocks yet, Take a look at the Anderson leveling system. I use it on my travel trailer, and it's made leveling SOOOO easy. Its $$ but its worth every penny.
https://www.amazon.com/Andersen-Leve...gateway&sr=8-8
Great build!!
Black Star Status!
Po' riggity is offline   Reply With Quote Quick reply to this message
Old 07-08-2019, 07:52 AM   #1296 (permalink)
Member # 56256
Great build!!
Thanks for reading through, its become a bit of a novel at this point
I had someone else suggest those as well, how do they do in gravel or softer dirt?
Foot powered weekend. Spent a few days far far away. It was nice. 15-18ish miles each way though, we powered through it in a day, kiddo did awesome!
Old 07-08-2019, 08:04 AM   #1297 (permalink)
Member # 1515
I have had those anderson levelers in soft sand and gravel, with no issues.
Black Star Status!
Old 07-08-2019, 08:08 AM   #1298 (permalink)
Member # 56256
Awesome, I may have to try them then.
Old 07-08-2019, 09:00 AM   #1299 (permalink)
Member # 355210
I've seen them in use by happy campers and unhappy slide-in campers. They don't seem to work as well under the driving axle. I've seen them twist sidewise and I've seen one spit out completely.
Been happy with Lynx Levelers under the drw F350 with the Lance in it.
mwilliamshs is offline   Reply With Quote Quick reply to this message
Old 07-08-2019, 09:25 AM   #1300 (permalink)
Member # 56256
I could see them spitting out....
I have the lynx levelers now.... They are in many pieces. I think I am just too heavy for them on soft ground. They flex and break.
