Box truck to RV conversion. Crew Cab f450 - Page 54 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-19-2019, 04:32 PM   #1326 (permalink)
Member # 406202
Originally Posted by Java View Post
Thanks!
One thing to remember though, I have no springs other than the airbags. Adding a large Port could probably be done, but would not be easy.
Sent from my SM-G973U using Tapatalk
When was the last time "not being easy" scared you off?
FirstRam is offline   Reply With Quote Quick reply to this message
Old 08-19-2019, 04:33 PM   #1327 (permalink)
Member # 56256
Occasionally I don't have a tig welder.....
F450 Box Truck to RV conversion www.NWadventuretruck.com
Java is offline   Reply With Quote Quick reply to this message
Old 08-19-2019, 04:35 PM   #1328 (permalink)
Member # 161331
Won't they keep the spring rate from rising as quick?
You will just be bouncing off the internal bump in the bag that much sooner. I usually run a little antifreeze in the bags to increase the rising rate.
Talk to Ryan at Acutune. He builds lots of shocks for lots of different vehicles.
bdkw1 is offline   Reply With Quote Quick reply to this message
Old 08-19-2019, 06:01 PM   #1329 (permalink)
Member # 56256
Thanks will do!
Old 08-20-2019, 07:39 AM   #1330 (permalink)
Member # 56256
Got to thinking. If I disconnect the shocks and drive it, that should take them out of the equation for harshness. I will get bounce, but it should help nail things down perhaps?
Old 08-20-2019, 07:44 AM   #1331 (permalink)
GLTHFJ60's Avatar
Member # 140040
Yes.
Shocks will only make bumps/potholes harsh if they're too stiff. I don't think that's your issue.
1987 4BTJ60 - MoonShine - 4BT/NV4500/EcoBox/NP205/D60/14B
2004 F-550 - 6.0/ZF6 - full bulletproof
GLTHFJ60 is offline   Reply With Quote Quick reply to this message
Old 08-20-2019, 08:10 AM   #1332 (permalink)
Member # 56256
Originally Posted by GLTHFJ60 View Post
Yes.
And what do you think the issue is?
Old 08-20-2019, 08:20 AM   #1333 (permalink)
GLTHFJ60's Avatar
Member # 140040
Spring rate too high in the bags. bdkw1's theory is easy to test, but I'm skeptical that your shocks are so stiff that it's causing the jarring you describe. If that were the case, the shock bushings would be destroyed in a hurry with that heavy of a rig over that kind of terrain.
Old 08-20-2019, 08:45 AM   #1334 (permalink)
Member # 56256
My only concern is the digressive valving. Did some reading and definately goes with what I feel on the washboard etc.
Old 08-20-2019, 11:34 AM   #1335 (permalink)
Member # 147348
That's what I was thinking. I don't have any shocks at all on the rear of my service truck, too heavy to need them I guess.
CarterKaft is offline   Reply With Quote Quick reply to this message
Old 08-20-2019, 12:16 PM   #1336 (permalink)
Member # 56256
Unfortunately the fronts are a bitch to get in and out!
Old 09-03-2019, 10:30 AM   #1337 (permalink)
Member # 56256
Well this happened! Only highway driving so far.
Fit well and the resi's tucked in nicely. Im at 4 clicks (12 total) up from full soft on the high speed compression, and full soft on the low speed.
Old 09-03-2019, 11:38 AM   #1338 (permalink)
107
christyle's Avatar
Member # 39660
Nice! I've got accutune on both my trucks, love it.
christyle is offline   Reply With Quote Quick reply to this message
Old 09-03-2019, 12:10 PM   #1339 (permalink)
GLTHFJ60's Avatar
Member # 140040
Did it seem to help or no?
Old 09-03-2019, 12:59 PM   #1340 (permalink)
Member # 56256
Only done freeway for the most part. So far its a big "Meh" A little improvement, but not a ton.... FS roads this weekend I think. Pretty sure they are way long too Gotta take some more measurements....
Old 09-03-2019, 02:00 PM   #1341 (permalink)
Member # 135683
Yeah I hate to agree but they look like shock will bottom out before bump stop. cheap fix would be space the bump stops down at cost of up travel.
350TacoZilla is offline   Reply With Quote Quick reply to this message
Old 09-03-2019, 03:18 PM   #1342 (permalink)
Member # 161331
Bilstiens ride pretty nice on the street, so I wouldn't expect much of an improvement there. If your all ready at full soft on the low speed clicker and it doesn't feel like a boat, you my not have enough bleed on the piston.
Old 09-03-2019, 03:21 PM   #1343 (permalink)
Member # 56256
Does not feel like a boat anymore than the bilstein's did. As in not at all really. The rear end does feel bouncy now compared to the front . The sharp impacts are high wheel speed correct?
Old 09-03-2019, 03:34 PM   #1344 (permalink)
Member # 161331
Yes. The clicker in the resi works off shaft displacement. While it does have an effect, it does not have as much effect as changing the shims on the piston. You have way more flow through the piston.
Old 09-03-2019, 03:38 PM   #1345 (permalink)
Member # 56256
Ok that was my understanding.
Only 3.5" from the bumpstop to the shock body but it doesn't look like it's bottomed out yet, but I haven't don't any dirt either....
Old 09-04-2019, 08:12 AM   #1346 (permalink)
GLTHFJ60's Avatar
Member # 140040
Is that a bump on the bottom of the fox shaft?
Usually shock warranties are voided if the shocks bottom out.
Old 09-04-2019, 08:17 AM   #1347 (permalink)
Member # 56256
Yep, rubber bumpstop
Old 09-04-2019, 03:55 PM   #1348 (permalink)
Member # 161331
Your bag doesn't look like it has that much travel either. It might bottom before the bumpstop too.
Have you ever cycled it without any pressure in it?
Old 09-04-2019, 05:52 PM   #1349 (permalink)
Member # 56256
Boom, zero bag pressure.
Old 09-04-2019, 06:11 PM   #1350 (permalink)
Member # 161331
So is it sitting on the bumpstop or the bag? Whichever, at least it's not the shock.
