Gooseneck with utility body - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-22-2017, 05:33 AM   #1 (permalink)
Member # 219275
Anyone ever do it or seen it done? I have to replace the floor in the utility bodoy I got for my towpig, and though about grafting a flipball into it. I already figured I would need to get a custom tounge on the trailer since the truck sits tall, but curious if anyone does it. The boxes of the body sit 4 inches taller than the factory bedsides. And it does have tall boxes at the front so I would have to watch with tight turns. Planning on a deck over trailer, but getting a standard trailers neck put on it to raise it the 10 inches or so. Just curious on opinions. I am fine with bumper pull but just thinking ahead.
Truck in question is an 85 crewcab dually ford on full air ride and eventually will be on 35's
1986 F350 6.9 diesel, np435, 203/205, hp60,10.25 welded up. caged, shortened, narrowed, and on 42's
DieselCrawler is offline   Reply With Quote Quick reply to this message
Old 06-22-2017, 06:03 AM   #2 (permalink)
Member # 506089
My flatbed has fold away gooseneck welded to the floor as well as rails for fifth wheel weld to it. Works great and have pulled some really heavy stuff with no issues. Only thing I would have done differently if I had installed them is to lower the rails into deck so when fifth wheel isn't on deck is flat
Sent from my STV100-3 using Tapatalk
tow_driver is offline   Reply With Quote Quick reply to this message
Old 06-22-2017, 06:09 AM   #3 (permalink)
Member # 219275
That's not really my concern, the ball will be same height away from the frame as originally designed. Biggest concern is the tounge hitting the boxes in off camber stuff when turning, like if s tire drops into a ditch so to say
Old 06-22-2017, 08:21 AM   #4 (permalink)
Member # 92543
Send a message via AIM to Mark13
A farm I used to work for had a PJ deck over with an extra tall neck to pull with service trucks.
12 Ford F550
Mark13 is offline   Reply With Quote Quick reply to this message
Old 06-22-2017, 09:23 AM   #5 (permalink)
Member # 219275
Pretty much like I figured, just need a tall neck and watch the swing with my taller front boxes. Guess I will keep on the lookout for a flip ball setup
Old 06-22-2017, 10:09 AM   #6 (permalink)
Member # 92543
The white F350 in the pics had a B&W setup in it. It was some type of universal kit for situations just like that, it wasn't the typical style in a pickup because the bed sat up off the frame so far.
12 Ford F550
