6.4 Hemi 2500 - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-23-2019, 05:47 PM   #51 (permalink)
Harvester of Sorrow's Avatar
Member # 11615
Send a message via Yahoo to Harvester of Sorrow
Originally Posted by Ben W View Post
Look for an Ecoboost F150 with max tow package. Mine is rated for 11,200 towing.
You driving one of those now huh? Looking at all of the half ton's out there...I don't think I can really go wrong anyway. My burb only had 290hp new but 410ft/lbs of torque. All of these new motors seem to be at 383hp or more and 400ft/lbs.
Same if not more wheelbase and more gears in the tranny means it should be a smoother pull as well.
Lastly...with the 454 I get 7.5mpg towing and 9mpg around town...
Harvester of Sorrow is offline   Reply With Quote Quick reply to this message
Old 02-24-2019, 06:55 AM   #52 (permalink)
Member # 4387
My wife has a 15 ram 5,7, speed, 3.21's . The max tow rating is 7k with 3.21's, 10k with 3.73's. My wife's truck gets good mpg (16/21), but not sure I would want to tow 7k with it. It rides great and is pretty quick. I had a 3500 with 5.7 and 4.10's, with 9k-10k toy hauler it was a 6mpg dog. 7k on flat's it would have been ok but not in the rockies. If you get he 1500 ram, I would get the 3.73's and plan on sway bars for a 7k trailer. The hemi likes to pull hills at 4k-5k rpm, takes a bit to get used to.
I just picked up a 18 ram 2500 diesel, winter driving with studs and in 4x4 50% I'm getting 14-15. Hoping for 12mpg with the trailer when the snow melts. But I'm mostly towing around NW MT.
Norm is offline   Reply With Quote Quick reply to this message
Old 02-24-2019, 08:17 PM   #53 (permalink)
rugby's Avatar
Member # 49997
These are the numbers I was looking for. So no braking issues towing the 7K?
I need to buy a truck very soon to replace my 1999 454 burb. There are a lot of nice 1500 5.7l trucks out there for sale. I have been looking at the following 2012 - 2017's:
6.2l ford
6.4l hemi
5.7l hemi
My rig will mostly be a daily and tow 7k once a month. There will be some planned multi-state trips this year.
I should be but I dont use the trailer brakes with this set up and it did just fine. I have had a few dodges and like them the best.
I have had an f150 work truck and I absolutely hated it.
rugby is offline   Reply With Quote Quick reply to this message
Old 02-27-2019, 07:15 AM   #54 (permalink)
Member # 77630
So 5.7l Hemi huh...? I would be towing over to Naches, etc.
Yup 5.7. Been up over Snoqualmie over to Crashes to run Reiter and back over Stevens, and been down central OR with it a bunch so up out of Biggs and couple other nasty steep hills coming back...
"I think that was bad...?"
dickwart is offline   Reply With Quote Quick reply to this message
Old 03-03-2019, 08:50 AM   #55 (permalink)
D45
Member # 102974
What trans is bolted up to these 6.4L trucks?
6.4L is only a power wagon and a 2500/3500 motor right?
2012 Ford F150 FX4; Long Bed; 3.5L V6 ECO; Max Tow; 3.73; Leveled; 275/65R20 Goodyear Duratracs
D45 is offline   Reply With Quote Quick reply to this message
Old 03-03-2019, 09:13 AM   #56 (permalink)
D45
Member # 102974
Originally Posted by ramv View Post
You can turn off the MDS. Simply select "6" with the +/- shifters. This also shows the gear you are in. I always drive like this as the MDS was annoying. It doesn't hurt/impact anything else except the variable displacement from engaging...
You sure about this? Tried to tell my buddy about this and he said it did not work
He is averaging 7.8-8.5 in his 6.4L PW , unloaded
Old 03-03-2019, 10:57 AM   #57 (permalink)
Aggie06's Avatar
Member # 123554
Stock, or larger tires? That seems pretty bad. Hell, thatís Chevy 6.0 range.
I will have to try turning off the MDS on my truck. Havenít ever messed with it.
Aggie06 is offline   Reply With Quote Quick reply to this message
Old 03-03-2019, 11:30 AM   #58 (permalink)
Member # 133009
Works on my '16 PW. I'm running 37's and am getting like 10/14 unloaded indicated on the computer. Computer lines up with hand calculated =/- 0.5mpg. That's with a speedo that is uncorrected for tire size, so it's probably actually a little better. I don't drive it very hard.
My understanding is that there is no way to untraceably turn the MDS off permanently. So if you have a warranty, you are going to have to buy a second ECM to swap in when you take it in for anything. It's not like a GM MDS system where you can just get an OBD dongle to turn off the MDS, then remove the dongle to set everything back exactly how it was.
I think you get the 68RFE. 6 speed auto that seems pretty good in the short time I've had it. I don't know if you can get an Aisin in a 3500/6.4 combo.
86 Zook. Links are for websites.
DirtRoads is offline   Reply With Quote Quick reply to this message
Old 03-03-2019, 11:44 AM   #59 (permalink)
D45
Member # 102974
Stock, or larger tires? That seems pretty bad. Hell, that’s Chevy 6.0 range.
I will have to try turning off the MDS on my truck. Haven’t ever messed with it.
Stock 35s...... not sure on the gears
Old 03-03-2019, 11:49 AM   #60 (permalink)
D45
Member # 102974
Maybe the trans changed? Ii was thinking the 6-Speed automatic is the 66RFE
Old 03-03-2019, 12:23 PM   #61 (permalink)
Aggie06's Avatar
Member # 123554
Thatís correct.
Old 03-03-2019, 02:37 PM   #62 (permalink)
Member # 133009
Whoops. I did some reading on them just now. Seems that they are similar but different
Old 03-04-2019, 07:00 AM   #63 (permalink)
Saluki ATO's Avatar
Member # 55123
16 PW on Toyo RTs 37x12.5 and corrected with AEV ProCal here. 11-12 unloaded here. Mostly city or going above southwest interstate speeds. 8-9 with either a single rig or small camper so far. Regearing to 5.13s in the near future now that I've got a little DD.
66RFE which is some combo of 65 and 68 architecture from other reading.
Saluki ATO is offline   Reply With Quote Quick reply to this message
Old 03-04-2019, 04:28 PM   #64 (permalink)
Member # 133009
How do you like the AEV ProCal? It looks like I need one of those for my re-cal and a Range Technology disablement tool when (if) they come out.
Old 03-05-2019, 07:31 AM   #65 (permalink)
Saluki ATO's Avatar
Member # 55123
It does what it's advertised to do. I tweaked the speedo a few times the first day and haven't touched it since. It's too bad the TPMS requires a dealer visit (or full scan tool) BCM reset.
I'm hearing that AlfaOBD is the way to go now though. More functionality than the ProCal which is just dipswitch uploads.
Old 03-05-2019, 01:02 PM   #66 (permalink)
Member # 4406
I actually just reset my TMPS threshold on my 2015 a week or so ago with AlfaOBD. No more orange light on constantly, plus the EVIC display stays on wherever I left it now instead of going back to the tire pressure screen every time I start it. I haven't messed with the speedo yet, but it sounds pretty easy to do.
Pete
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways , beer in hand, body thoroughly used up, totally worn out and screaming "WOW, what a ride."
pcorssmit is offline   Reply With Quote Quick reply to this message
Old 03-07-2019, 09:33 AM   #67 (permalink)
Member # 133009
Android only is a bit of a drag. Search led me to RamForum. There's actually some decent tech there and a good bit of traffic.
Old 03-07-2019, 12:47 PM   #68 (permalink)
Member # 4406
I first looked at getting the windows version (since we didn't have any Android devices), but ended up getting a $50 Fire 7 tablet to run it. I haven't used it a lot, but so far so good. As a bonus, I can use it to stream music in the garage instead of having to use my phone.
Pete
Old 03-08-2019, 06:46 AM   #69 (permalink)
D45
Member # 102974
What year did the 6.4L first appear in the 2500/3500 trucks?
Old 03-08-2019, 08:07 AM   #70 (permalink)
Aggie06's Avatar
Member # 123554
2014
Old 03-08-2019, 10:36 AM   #71 (permalink)
Member # 4387
Pete
looking into that, the tire warning bullshit is annoying. I run my winter studs at 45psi unless I'm hauling.
Old 03-08-2019, 11:14 AM   #72 (permalink)
Aggie06's Avatar
Member # 123554
Apparently theyíve made it harder for 2018+ models. Iím sure someone will come up with a solution eventually. Going to keep watching it as I like running mine around 65 if not towing.
Old 03-09-2019, 07:19 AM   #73 (permalink)
silveranger93's Avatar
Member # 98992
You can still do it with alfaobd, you just need a bypass harness due to the security. Look at the thread on ram forum or Cummins forum, it's all there.
Sent from my Pixel 2 using Tapatalk
silveranger93 is offline   Reply With Quote Quick reply to this message
Old 03-09-2019, 08:48 AM   #74 (permalink)
Aggie06's Avatar
Member # 123554
Cool, thanks. Missed that when I was looking.
Old 03-11-2019, 06:53 AM   #75 (permalink)
D45
Member # 102974
Originally Posted by lunacy View Post
5.7 is the only v8 available in the Ram 1500. I hear they are going to put the 6.4 in it, but that's rumors been going around for a few years.
You can get a 6.2L V8 in some F150 trucks and GMC/Chevy offers their 6.2L V8 in the Silverado/Sierra 1500s........but only one V8 is available in the Ram 1500?!
What's the power specs of the current 5.7L Hemi?
