2001 F350 front end alignment? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-24-2018, 03:56 PM   #1 (permalink)
Member # 687322
Just did upper and lower ball joints on my 2001 F350 4x4 dually. Should I consider a front end alignment now? Seems to go down the road fine. What can really be adjusted in the front ends of these trucks anyway? Thanks
DNL2 is offline   Reply With Quote Quick reply to this message
Old 06-24-2018, 04:47 PM   #2 (permalink)
DMG
Member # 8145
I wouldn’t bother
DMG is online now   Reply With Quote Quick reply to this message
Old 06-24-2018, 05:28 PM   #3 (permalink)
SLC97SR5's Avatar
Member # 98713
Now would be a good time to check the track bar bushings.
I had mine aligned after upper and lower ball joints to make sure I wasn't going to trash a couple tires.
SLC97SR5 is offline   Reply With Quote Quick reply to this message
Old 06-24-2018, 07:06 PM   #4 (permalink)
DMG
Member # 8145
A track bar won’t effect tire wear.
Old 06-24-2018, 11:07 PM   #5 (permalink)
El Conquistador
Valley Rock's Avatar
Member # 208306
The upper ball joints can be adjusted ever so slightly with the taper bushing they set in, but that requires removing the bushing that the upper bj sets in and replacing it with one of a different degree .
If you didn't mess with those then it should be exactly as it was, and those trucks don't run shit for toe, 0 to 1/16 .
Valley Rock is offline   Reply With Quote Quick reply to this message
Old 06-25-2018, 05:04 AM   #6 (permalink)
mj
Member # 1919
the classic set toe and let go alignment
mj is offline   Reply With Quote Quick reply to this message
Old 06-25-2018, 07:15 AM   #7 (permalink)
SLC97SR5's Avatar
Member # 98713
You're right but it did require the drag link to be reset to center the steering wheel.
Old 06-25-2018, 04:47 PM   #8 (permalink)
Member # 687322
Thanks guys.
