Transmission temps - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-29-2018, 04:59 PM   #1 (permalink)
Mac7's Avatar
Member # 423458
Transmission temps
Whatís the average trans temp while towing in town.
Iíve got a 2005 2500 Dodge with the 4 speed. Towing 6000 pounds or so Iíve seen temps up to 225.
Mac7 is offline   Reply With Quote Quick reply to this message
Old 11-29-2018, 05:38 PM   #2 (permalink)
acm05's Avatar
Member # 169176
My rule of thumb is ambient outside temp. +100 degrees more than max temp of transmission. I was taught that if your cooler can’t keep up with that formula you need more cooling capacity.
All that said it really depends on the fluid your running. I run Amsoil’s version of TES-295 in my Allisons and it has a pretty high max temp before it starts to break down. Seeing 225* on occasion wouldn’t concern me if I’m pulling hills and then it comes back down, but I wouldn’t want that to be my running temp in stop and go traffic.
Just my opinion here, I’m sure others will chime in.
acm05 is offline   Reply With Quote Quick reply to this message
Old 11-29-2018, 05:55 PM   #3 (permalink)
yozsi's Avatar
Member # 91857
Send a message via AIM to yozsi
225 in town with the converter unlocked is about right. I would not be concerned. If you start creeping on 240 I would be worried. I like to run hytran on stuff with loose converters. Keeps temps down and lowers the stall a couple hundred rpms.
92 Nissan Pathfinder- 3 Link SAS, 4 link rear
02 Dodge 2500 QC LB 4x4, CTD daily.
Foreign Car Center
Vallejo, CA
yozsi is offline   Reply With Quote Quick reply to this message
Old 11-29-2018, 06:01 PM   #4 (permalink)
Mac7's Avatar
Member # 423458
Thanks for the input, Iíve replaced both coolers in the last year and filter. Havenít thought about a torque converter.
Old 11-29-2018, 06:20 PM   #5 (permalink)
Member # 104517
I like to stay below 200, preferably 150-160 range. I've been trained by GM 1/2 ton transmissions to keep them cool or replace clutches.
Mostly fluid dependant, keep it below the fluid burning temp and I doubt you have problems.
R.I.P. Jason Payne
chevy_man is online now   Reply With Quote Quick reply to this message
Old 11-30-2018, 08:21 AM   #6 (permalink)
welndmn's Avatar
Member # 398
IT really depends on where you are measuring the temp at.
Mark
Old 11-30-2018, 09:03 AM   #7 (permalink)
Member # 121053
This for sure. Where are you measuring? Pan or lines?
Hunt is offline   Reply With Quote Quick reply to this message
Old 11-30-2018, 09:10 AM   #8 (permalink)
Member # 101265
04 here - sensor in the pan (Derale deep pan), never hit above 180 towing 5K in the summer.
Kunker is offline   Reply With Quote Quick reply to this message
Old 11-30-2018, 09:33 AM   #9 (permalink)
Mac7's Avatar
Member # 423458
Transmission temps
Iím getting the temp from a Edge Tuner and monitor. So Iím not really sure where itís getting the temp from. Iíll have to look. The thing has a torque convertor cooler thatís liquid cooled. So if Iím right it should be at least the temp of the oil. I never seen either one below 180, during the cold months I let it warm up to 180 before we go anywhere.
Old 11-30-2018, 09:53 AM   #10 (permalink)
yozsi's Avatar
Member # 91857
that sensor is on the valve body so its pan temp. heat exchanger is coolant cooled/heated.
Foreign Car Center
Vallejo, CA
Old 11-30-2018, 10:25 AM   #11 (permalink)
welndmn's Avatar
Member # 398
Sounds goofy to me, something in wrong.
I have my sensor on the HOT OUT line of the transmission, IT gets to 200-220 when towing up long grades where the converter is not locked.(2005 RAM).
I drive about 50 miles to work, it's only 50 degrees out, and with no load, that temp never really goes above 120.
All I have is a deep pan.
Mark
Old 12-02-2018, 06:04 PM   #12 (permalink)
Fuck Veriscope!
wheelin66bronco's Avatar
Member # 44308
I’m getting the temp from a Edge Tuner and monitor. So I’m not really sure where it’s getting the temp from. I’ll have to look. The thing has a torque convertor cooler that’s liquid cooled. So if I’m right it should be at least the temp of the oil. I never seen either one below 180, during the cold months I let it warm up to 180 before we go anywhere.
That's reading off the transducer in the valve body, it's known for not being accurate. I just rebuilt my 48re, my transducer runs about 20-25* hot.
When you've had a stable temp outside overnight, turn your key on and wait for the edge to tell you trans temp, compare that to the outside temperature.
It was 10* since yesterday and overnight last night, when I started my truck at 10am this morning my smarty read 35*.
Get a heat gun to verify pan temp, then just know the temp you're off.
My truck runs down the highway at 165-185, so really 145-165.
ΜΟΛΩΝ ΛΑβΕ
wheelin66bronco is offline   Reply With Quote Quick reply to this message
Old 12-02-2018, 08:35 PM   #13 (permalink)
Mac7's Avatar
Member # 423458
This is what Iíve been looking for. Thank you for the info.
Also Iíve spoke to a few folks around here with the same trucks and they arenít worried at 220 especially if the truck isnít throwing a code.
Old 12-04-2018, 06:52 PM   #14 (permalink)
Mac7's Avatar
Member # 423458
This advice was spot on. Thanks again!
Old 12-04-2018, 08:33 PM   #15 (permalink)
Member # 192237
is the fluid brown and burnt smelling?
Yes? change it
No? it's fine
If you're changing it more than every 20k miles, you might want a better cooler.
deep pan doesn't really gain you anything, the thermal mass of a gallon of extra fluid is nothing compared to the mass of the trans case and everything
[486] is online now   Reply With Quote Quick reply to this message
