Junk 99 F-350 PSD rebuild - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-16-2019, 05:16 AM   #51 (permalink)
today
fredycruger's Avatar
Member # 225557
no more flashing O/D, full power restored
got the new solenoid DORMAN 609-023 for 265$
when i got it i was really disappointed. it look like used old part somebody just pulled out, not reman.
it was all dirty and had some deposit on the valve body WTF
fucking dorman.. i was skeptical but it works
fredycruger is offline   Reply With Quote Quick reply to this message
Old 04-16-2019, 06:00 AM   #52 (permalink)
today
Member # 225557
F-350 SUPERDUTY parts list
Starter 200
hangers 112$
shackles 91$
fw. hanger 100$
brake lines 62$
air filter 44$
U bolts 52$
bed bolts 50$
pass repair 49$
dr side repair 92$
intake boots 88$
Glow plugs 68$
rr Shocks 110
locking hubs 116
rr rotor 50
rear caliper 58
backing plates 117
ebrake cable 33
ebrake shoes + hw. 74
brake pads rr 36
solenoid pack tranny 265
level kit 65
steering linkage 118
resistor blower 15
fuel filter 31
oil filter 16
tranny filter 18
oil 14.09*4 57
ATF 4.75*16 76
fuel pressure fitting 24
rear wheel seals 54
wipers 33
PCM 80
total 2454
with sales tax and registration im in it for about 3K
still need to do front hub and truck should be GTG to pass state inspection
Old 04-19-2019, 06:53 AM   #53 (permalink)
today
Member # 225557
truck passed inspection
and i scored pretty decent trailer
single axle 6K GVW Tilt
need new new deck tires and probably wheel bearings
frame is good and beefy
but was free which is in my price range
i can haul my mini excavator with it
Old 04-19-2019, 07:08 AM   #54 (permalink)
GLTHFJ60's Avatar
Member # 140040
Congrats on passing inspection!
Junk trailer to match the junk F350. Nice
1987 4BTJ60 - MoonShine - 4BT/NV4500/EcoBox/NP205/D60/14B
2004 F-550 - 6.0/ZF6 - full bulletproof
GLTHFJ60 is offline   Reply With Quote Quick reply to this message
Old 04-19-2019, 12:13 PM   #55 (permalink)
today
Member # 225557
HAHA matching equipment
Old 04-23-2019, 08:08 AM   #56 (permalink)
today
Member # 225557
seams like this thuck have all the ford problems
been dealing with wiring electrical issues since i got it
it would not turn off power to door , wipers would go off on their own
relays clicking etc
i pulled a pilar trim off when i wanted to add handle and one day i saw leak
the windshield leaks like craze and ive read its pretty common to leak and drip onto GEM and itll cause all kind of weird shit im experiencing
also the truck smells like swamp donkey so i pulled out the carpet
fcking nasty shit
i found about 6$ in change, pretty cool flask with shit still in it
walky talkie and shotgun shell
Old 05-01-2019, 06:17 AM   #57 (permalink)
today
Member # 225557
truck runs great,
did bunch of small stuff over past few weeks
re-sealed the windshield ,i didnt remove the glass only pulled the decorative moulding and cleaned the groove and filled it with 3m windshield adhesive
i laid down masking tape and had the adhesive overlap 1/4" on the body and on the glass .
its been raining and haven't had any leaks in the cab .now the fuse box and GEM module is safe .
random battery draining and clicking relays is also gone
got new batteries
i replaced coolant temp sensor
blower resistor along with connector as they were melted together
installed my old pioneer head unit
i swapped GEM module from my gaser f250 but have to swap it back as now my wipers don't work right only turns on on high speed and dont go off till i turn the truck off, washer works its also 2001 mine is 99
Old 05-20-2019, 02:17 PM   #58 (permalink)
today
Member # 225557
the other day i noticed clunking in front
and found bad u joint on driver side
i had bad wheel bearing on that side as well
ordered wheel hub,seals and u joint and hopefully stub shaft is still good
there was some confusion o what hub /seals to get as there is early 99 and later design of the hub one is 13mm and other 10mm flange
and need to get coresponding rotor with each hub to make up diference
i have some new rotors i had around from 2001 f250 so ill use those
i ended up getting Timken 515020 its the later model hub with abs sensor , my truck doesn't have abs in front ,but research said to get this anyway as you can use the abs sensor hole to grease up the bearing and its cheaper than old style hub
also there are 2 designs of the knuckle seals, older design fit newer axle but not the other way around so i had to find out which i need
part # for seals and u joint
Spicer 50381 Knuckle Seal
Spicer 50491 Axle Shaft Seal
Spicer SPL55-3X U-Joint Kit
Old 05-24-2019, 07:40 AM   #59 (permalink)
Newbie
Member # 861326
I dig it, nice work!
The way I look at it, you could have spend 3 grand on a running duty and had to do all the same stuff to it, I still think you're miles ahead in the beater duty world going through all these items yourself.
At least you know where it stands with maintenance.
That flask is awesome!
I found a new looking 4D Maglite under the seat of my duty after I bought it.
Gotta love bonus items like that.
Ford Guy
landen300 is offline   Reply With Quote Quick reply to this message
Old 05-24-2019, 01:01 PM   #60 (permalink)
today
Member # 225557
thanks man
you right i would have to do all the work anyways unless its been kept up and they go for 7K +
anyway truck is back on the road
ended up pulling stub shaft from my parts truck/FC project
because needle bearings took shit and worn out the spindle down
driver side got new U joint, caliper,rotor, hub,knuckle seal and dust seal
i had hard time to install knuckle seal and deformed the metal piece a little
it straightened up once i put it on the axle shaft , we'll see
Old 06-03-2019, 06:32 AM   #61 (permalink)
today
Member # 225557
fixed up the trailer little bit
put new bearings in the hubs , new rim& tires
some 2x10 planks for deck, took it behind the shop and spray painted the trailer CAT yellow
still gotta install new lights and wiring
this should haul my mini excavator no problem its 6000LB GVW
Old 06-13-2019, 07:20 AM   #62 (permalink)
today
Member # 225557
Old 06-13-2019, 07:34 AM   #63 (permalink)
GLTHFJ60's Avatar
Member # 140040
Lookin good man. That little trailer has a 6k axle under it?
Old 06-13-2019, 09:01 AM   #64 (permalink)
today
Member # 225557
thanks man,
IDK vin tag on the trailer say 6K GWR trailer being 1000LB
should be perfect for my 4500 Mini EX.
Old 06-13-2019, 09:04 AM   #65 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
Nice. I love seeing people save old stuff.
Action Fab is offline   Reply With Quote Quick reply to this message
Similar Threads
350 rebuild Drockyj Chevy 3 11-12-2012 06:18 AM
350 rebuild Drockyj General 4x4 Discussion 2 11-10-2012 09:21 AM
350 tbi rebuild cost? mvanhelden Newbie General 4x4 Discussion 2 06-06-2012 08:55 PM
chevy 350 rebuild $$$$ wheeler4life Newbie General 4x4 Discussion 12 02-14-2012 10:16 AM
