LED Headlights - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-14-2019, 06:29 PM   #1 (permalink)
jsawduste's Avatar
Member # 77571
LED Headlights
GM Guy here so I don’t know how this question might fit for other makes.
Late model trucks don’t have HL’s you can simply replace. Which leaves us to a bulb replacement as the only option.
Who has tried any of the LED replacement high and low beam bulbs in the factory housings ?
Are they worth a shit ? Not looking for cool but for improved lighting.
Seen a couple at 6000K which is kinda blue.
What say PBB ?
Sent with smoke signal.
jsawduste is offline   Reply With Quote Quick reply to this message
Old 04-14-2019, 06:51 PM   #2 (permalink)
xjtony's Avatar
Member # 50866
Shit is blinding to oncoming drivers. Unless the bulbs are put into projector housings. The glare is ridiculous, or at least my experience it was. My conclusion too damn bright for my application (regular halogen housings)
Low Budget Sammy
xjtony is offline   Reply With Quote Quick reply to this message
Old 04-14-2019, 06:55 PM   #3 (permalink)
IDASHO's Avatar
Member # 83932
Good ones are simply better than halogen.
Check out bulbfacts.com
By far the best place to check for real world info.
Im running LED in both the old exploader and the new superduty.
Beam pattern is identical to halogen, just brighter.
I do have to say though, the difference for the superduty was BIG.
Not such a difference for the explorer. Probably just shitty reflectors in the OEM buckets.
Kenny B.
IDASHO is offline   Reply With Quote Quick reply to this message
Old 04-14-2019, 08:09 PM   #4 (permalink)
Member # 86582
Depends on the LED chip.
With the Philips Lumileds ZES chip it puts the LED right in the same spot as the normal light element.
See my van video where I upgraded to LEDs. You can see the beam pattern side by side. https://www.youtube.com/watch?v=wQkJ-3bCu-s&t
<---Subscribe, Please? :laughing:
BassnTruck is offline   Reply With Quote Quick reply to this message
Old 04-14-2019, 08:13 PM   #5 (permalink)
Member # 210036
I dropped a set of Phillips X-treme "something or other" ones in our 2008 Grand Cherokar's factory housings. Pattern was about the same with a really sharp cutoff line and a good spread to the sides. The light output while driving down the road was remarkably better. Had to get the Canbus adapters as well or they would start flickering and turning on when they shouldent. we have mandatory daytime running light laws here. They have now been in there for about 2 months and I got flashed 2X so I lowered the low beams a little. They have a much wider color spectrum then I was expecting making everything easy to see at night. My bitch is that part numbers is fucked up with Phillips and I don't like having cooling fans on the back of the bulbs as I'm sure the lamps will last forever, but I give the fans 6 months.
BSInc. is offline   Reply With Quote Quick reply to this message
Old 04-14-2019, 08:20 PM   #6 (permalink)
Member # 135683
On my 2004 Yukon in the time frame of maybe 2 weeks I went from stock halogen\cheap ebay led\stock halogen\sealight led. I was told that LED bulbs were no good in the stock halogen headlight housings and I need full replacements before trying them and the cheapo ebay ones made me think that was the truth. I wanted to try a better brand light and see if there was any improvement. When I put in the sealight ones it was like IDASHO said the pattern is the same but much brighter and can see in distance better due to the more pure white color.
The ebay ones had a blue tinge to them and had worse than stock beam pattern and distance, they were way brighter if looking at them from outside or pulling up to a building but on rd they sucked so bad I put stock bulbs back in (glad I kept them in garage just in case).
350TacoZilla is offline   Reply With Quote Quick reply to this message
Old 04-14-2019, 09:18 PM   #7 (permalink)
jsawduste's Avatar
Member # 77571
Good info, keep it coming.
Switching over to the YT video BassnTruck to see what ya got going on there.
Old 04-15-2019, 01:25 AM   #8 (permalink)
Member # 16468
I did mine in my M715. Much better illumination and I don't seem to be blinding others. Won't melt snow from the lenses
1969 Jeep M715 6x6 6BT/NV4500/NP202.5 D60/70/70
1963 Jeep J300, 4BT/NV4500/NP200/D60/60
Mikel is offline   Reply With Quote Quick reply to this message
Old 04-15-2019, 08:06 AM   #9 (permalink)
Member # 86724
I'm told the morimoto ones work well in regular reflector housings.
I liked the HID bulbs I got from them.
I will probably try the LED bulbs in the wife's volvo when I run out of my osram bulb stash. It eats a set of low beams yearly.
https://www.theretrofitsource.com/90...ect_restrict=1
Old 04-15-2019, 08:48 PM   #10 (permalink)
Member # 53528
heres some related threads with a little bit of info/feedback on led stuff from the electrical forum
https://www.pirate4x4.com/forum/elec...tion-leds.html
https://www.pirate4x4.com/forum/elec...fg-2019-a.html
rockyota83 is online now   Reply With Quote Quick reply to this message
Old 04-16-2019, 07:48 AM   #11 (permalink)
jsawduste's Avatar
Member # 77571
Thanks Rocky !!
Old 04-16-2019, 09:40 AM   #12 (permalink)
Member # 95763
In my 03 Silverado my lights are plenty bright enough.
My buddy gave me an "all on" circuit board. Now when you actuate the brights, the low beams stay on and it turns on the fog lights as well.
It works very nicely.
KarlVP is offline   Reply With Quote Quick reply to this message
Old 04-17-2019, 04:00 PM   #13 (permalink)
Member # 124264
all kinds of info from these guys.
https://www.youtube.com/user/HeadlightRevolution
exmod110 is offline   Reply With Quote Quick reply to this message
Old 04-17-2019, 08:55 PM   #14 (permalink)
Member # 53528
my cheapo LED 5x7 headlights in my tow/work truck keep the low beams on with the highs on
they have been awesome for a little over a year living 90% of their life on rough dirt roads
Old 04-18-2019, 09:33 AM   #15 (permalink)
Stunningly Average
wheelerfreak's Avatar
Member # 4135
This is one of my worries about switching to LED's. I see too many cars whose lights are frickin blinding to me on two lane roads.
The new SD's seem to be the worst factory lights to face in oncoming traffic. Do they have LED's now? I drive a lot of two lane rural roads and I have grown to hate facing a SD coming at me. Even in my truck they are bad and in my car I have to shade my eyes.
I just added PIAA LED lights that I can use when needed and not blind oncoming traffic. That may not work in more urban areas, but in BFE I haven't had an LEO issues with this method. I'd like to just add LED replacements to my 93 CTD though, i just don't have room on the bumper for lights
The press is a gang of cruel faggots. Journalism is not a profession or a trade. It is a cheap catch-all for fuckoffs and misfitsóa false doorway to the backside of life, a filthy piss-ridden little hole nailed off by the building inspector
wheelerfreak is online now   Reply With Quote Quick reply to this message
Old 04-18-2019, 12:13 PM   #16 (permalink)
Aggie06's Avatar
Member # 123554
Agree that the new SDs are pretty bad. They are pretty bad in your mirrors also.
I have a pair of LED fog lights wired to my stock switch on my truck. Only run them when really needed.
Aggie06 is offline   Reply With Quote Quick reply to this message
Old 04-18-2019, 12:30 PM   #17 (permalink)
Weasel's Avatar
Member # 5639
Until they figure out a way to keep the from icing up in the winter, I'm not even considering them.
Kindness doesn't condemn or condone
Just Add Lightness
Weasel is offline   Reply With Quote Quick reply to this message
Old 04-18-2019, 03:00 PM   #18 (permalink)
Aggie06's Avatar
Member # 123554
Ford has a washer for their front camera, itís only a matter of time. Will probably add $1000 to the cost of the vehicle.
Old 04-18-2019, 03:11 PM   #19 (permalink)
Member # 86724
every HID/LED car in europe is required to have headlamp washers.
so it already exists.
of course the first thing you do is disable it, because all it does is spray shit all down your clean paint.
Old 04-18-2019, 05:27 PM   #20 (permalink)
Joey D's Avatar
Member # 20053
JW speaker has the LED headlights with built in heaters.
98 K2500 SAS dynatrac pro rock 60, ORD high steer, RCV CV's, arb's front and rear, 4.56 gears
06 D Max Express
Joey D is offline   Reply With Quote Quick reply to this message
Old 04-18-2019, 05:29 PM   #21 (permalink)
jsawduste's Avatar
Member # 77571
Replacement HL`s are great but not when you have those fancy built in setups.
9005/9006 is a lot easier to deal with.
Old 04-18-2019, 06:35 PM   #22 (permalink)
IDASHO's Avatar
Member # 83932
By "new". I mean 2011-2016
They came with halogen factory.
With proper built LEDs, the output is fantastic.
Beam pattern is identical to stock, clean clear spread, and sharp cut-off.
Im running these https://www.amazon.com/TECHMAX-Headl.../dp/B07CBPV3WW
Kenny B.
Old 04-19-2019, 08:09 AM   #23 (permalink)
Weasel's Avatar
Member # 5639
I just saw an ad for them last night. Neat looking.
Just Add Lightness
Old 04-25-2019, 08:32 AM   #24 (permalink)
Member # 48233
Originally Posted by jsawduste View Post
GM Guy here so I donít know how this question might fit for other makes.
Late model trucks donít have HLís you can simply replace. Which leaves us to a bulb replacement as the only option. I'm not sure what that means
Seen a couple at 6000K which is kinda blue. 6K isn't bad. Its very clean, not very yellow
What say PBB ?
I run these in my 2015 silverado
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
i'm very happy with them.
[quote=texasblake;11194923]
they may be waving like mccain for the rest of their life, but you taught them an important life lesson and they had fun doing it.[/quote]
[QUOTE=xyjbeaker;9759686]"mexican food reminds you of my face?"[/QUOTE]
Doc Holiday13 is offline   Reply With Quote Quick reply to this message
Old 04-25-2019, 09:42 AM   #25 (permalink)
SpineTx's Avatar
Member # 1499
Rockyota, Which ones are these? do you have a link?
Pain is your Mind Failing you;
Body Damage is your driving ability failing you
SpineTx is offline   Reply With Quote Quick reply to this message
Similar Threads
J.W Speaker LED headlights 5.75" NOODLES Misc. Stuff For Sale 0 12-08-2015 04:37 PM
Installing LED Headlights, harness suggestions? RanchGX Electrical & Wiring 11 02-19-2014 09:18 AM
