mobile home axle lugs - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-12-2019, 05:25 AM   #1 (permalink)
ANGELO190471's Avatar
Member # 798001
when i was taking my wheels off a snapped a lug. can i just use grade 8 bolts to replace the lugs or are there certain ones that have to be used? i have new wedges already but the bolts they came with didnt fit so i reused the original
ANGELO190471 is offline   Reply With Quote Quick reply to this message
Old 08-12-2019, 07:55 AM   #2 (permalink)
Member # 355210
I think a grade 8 bolt with the appropriate shoulder would work fine. The real MH lugs are readily available though and cheap so I would just use them.
This assumes your lugs are of the straight variety. If they have tapered heads, I would say ya gotta use them.
mwilliamshs is offline   Reply With Quote Quick reply to this message
Old 08-13-2019, 05:04 AM   #3 (permalink)
Member # 187907
The ones I've used all had a larger head than a comparable grade 8 bolt, just keep that in mind.
Jason280 is offline   Reply With Quote Quick reply to this message
Old 08-13-2019, 10:42 AM   #4 (permalink)
Member # 17947
Send a message via AIM to jaluhn
Grade 8 with washer if needed, but probably better to get the right bolt. A tire shop that does heavy duty/ag stuff can likely help.
jaluhn is offline   Reply With Quote Quick reply to this message
Old 08-13-2019, 04:30 PM   #5 (permalink)
Member # 355210
If yours are breaking, I'd replace the lot rather than reuse them.
