Trailer frame bent - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-13-2019, 06:45 PM   #26 (permalink)
Insurance poor
Rttoys's Avatar
Member # 140853
The one shackles rotated around when it hit the frame, it looks like. Rotate the one around and it will probably get you fairly back to level, then fix the frame.
'80 CJ7- soon to start project "always changing directions"
'84 CJ7- all stock farm rig, except a bunch of gun racks
'79 CJ5- not stock- way too much to list
Rttoys is offline   Reply With Quote Quick reply to this message
Old 08-14-2019, 02:32 AM   #27 (permalink)
Member # 85771
Fawk I looked at that pic for a few minutes and couldn't figure that out! I knew something wasn't right though. Thats why I asked about the tire being on something.
Make Forums Great Again!
ky scrambled is online now   Reply With Quote Quick reply to this message
Old 08-14-2019, 03:18 AM   #28 (permalink)
Member # 871646
Good eye! So youíre saying to basically flip that shackle over? So that the bolt holes at the bottom are now at the top? Or would it be best to just buy a new shackle?
seanflippo is offline   Reply With Quote Quick reply to this message
Old 08-14-2019, 04:06 AM   #29 (permalink)
Member # 85771
Shackle is fine. Ive done this before just jacking the trailer up in the wrong spot and the hanger inverts. Would make one tire not even touch the ground .
Just take the wheels off that side and monkey with it till it flips back to the correct way.
Old 08-14-2019, 04:10 AM   #30 (permalink)
Member # 871646
Gotcha, I see what youíre saying now. Thanks!
Old 08-14-2019, 04:38 AM   #31 (permalink)
Bo185's Avatar
Member # 48545
Look at the first picture the driveway is pretty sloped and trailer is way nose high, equalizer is were it will be like that, shackle should settle back when front axles moves level again. Place trailer on level ground it should level out before you waste time.
'73 IH Scout II Vortec 6.0L 4L65e np241
'73 IH 1210 Travelette SV392 V8, T34, 60/14bff 4.56's 35's
'01 VW Beetle TDI-50mpg or better!
Bo185 is offline   Reply With Quote Quick reply to this message
Old 08-14-2019, 06:42 AM   #32 (permalink)
Insurance poor
Rttoys's Avatar
Member # 140853
They should be like this:
Old 08-14-2019, 06:46 AM   #33 (permalink)
Member # 871646
Thanks, itís pretty obvious now that I know what Iím looking at. Iíll get that taken care of first before I work on the frame.
Old 08-14-2019, 09:12 AM   #34 (permalink)
Member # 17632
I personally wouldn't add rails. It makes it hard to tie anything down because you can't lay in under the side to hook chains/straps. If you straighten it and stiffen it up, it should be fine for a long time as long as you don't overwork it like the P.O. did. I owned my trailer for about 22 years before I bent it, and that was only because I was pushing it's capacity and had to do some severe evasive maneuvers at highway speed. Up until that point, I had hauled cars, trucks, tractors, small forklifts, firewood, and all manner of other shit that was within the capability of the trailer and never had a problem with bending it.
Travis..
Edit; seeing that shackle inverted, you can see where the frame was riding on the shackle/equalizer and it bent right behind it. Straighten/stiffen it, get the shackles sorted out, and it will be fine.
18 Ram 2500 4x4 Big C and a 6 speed
87 Blazer FOR SALE, clean, original truck, 2.5" lift
crashnzuk is offline   Reply With Quote Quick reply to this message
Old 08-14-2019, 10:01 AM   #35 (permalink)
Member # 86724
just remember.
if you wouldn't put your dick in'er, don't put your fingers in'er.
lots of force there, so don't be fucking stupid. It's gonna scare you when she flips back round.
Old 08-14-2019, 10:03 AM   #36 (permalink)
Member # 871646
Originally Posted by 87manche View Post
just remember.
Thanks for the heads up!
Old 08-14-2019, 10:13 AM   #37 (permalink)
Member # 871646
Travis..
Thanks for the advice, I plan to just haul my Jeep on it 1 or 2 times a month. It definitely wonít be overworked like it was before. Hopefully Iíll have a semi decent trailer by the time this is all done.
Old 08-24-2019, 07:06 PM   #38 (permalink)
Member # 82607
Of the three car trailers I have owned they were all made from angle iron and flimsy as fuck! Depending on where or how they were parked they all looked tweeked. Put a chain from front to back over the top, put a block and a jack over the bent spot and jack, hopefully lifting the back up, then box the inside for a couple of feet at the bend.
good luck.
dave_dj1 is online now   Reply With Quote Quick reply to this message
Old 08-25-2019, 07:27 PM   #39 (permalink)
xjtony's Avatar
Member # 50866
Flip shackle/springs back right and it should sit level and be all good. They will invert and get all wonky if you jack the trailer up empty and not flip them back before setting the trailer back down. Looks like what happened to me.
Low Budget Sammy
xjtony is offline   Reply With Quote Quick reply to this message
Old 08-26-2019, 07:34 AM   #40 (permalink)
Member # 166653
When I had a shackle flip like that I had to put some weight on it to get it to flip back. I drove my skid steer all the way forward on the trailer while it was hooked to my truck. Then I backed the trailer's front axle on a hump to further unload the rear axle. Finally I used a floor jack to lift the flipped shackle on the spring side until it popped violently back over. You definitely don't want to be under the trailer or have any body part near it when you flip it back. This includes prying with a long screwdriver ir crowbar because when it flips it will fling that screwdriver into you (or a tire).
Mine had flipped from crossing rough terrain with an uneven load. Because of this I am planning on using slipper springs on my next trailer build. But that is just because of how I use my trailers, the shackle design is fine for most applications. Sometimes they will flip when loading and unloading if you don't have something like a jack or legs under the rear of the trailer when driving on a heavy load. Most likely that is how your frame bent due to all the weight of a heavy vehicle being supported by the single point on the frame where the equalizer was hitting.
Is the upper side of the frame bent also or is it just the bottom? If the upper is not bent you might bend it using the chain and bottle jack method mentioned before. If top and bottom are bent then use the bottle jack method but anchor it closer to the jack rather than across the whole trailer. If only the bottom is bent then you should use s spreader inside the frame rail to straighten it out. But you may have to rig up a way to do it because you likely don't want the right tool for that job. If the metal is thin enough you might reverse the ends on a clamp to spread it. You could also try a piece of all thread between two thick metal plates that have been drilled and spread then with two nut and a wrench. If you need hydraulic force you can remove the deck board and put the lip of a bottle jack on the lower side and strap it in place before using the chain and jack method. Also when you anchor you chain make sure that you spread the load out or you will just dent the frame where the chain is hooked.
Once the frame is straight I would box it where the suspension mounts. You really don't want to anchor you straps there anyway but if you need one weld an anchor point on the side of the frame there. Trailers usually fail at the tongue or suspension so beef those parts up.
4seasons is offline   Reply With Quote Quick reply to this message
