What 7.3 mods would you make with the trans out? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-06-2019, 10:26 PM   #1 (permalink)
Member # 355210
2002 F-350 7.3 4R100 2WD DRW
Totally stock. Totally. 120k miles. Developed a leak that we're pretty sure is the front pump seal on the transmission. If that's true, (gonna look closer/cleaner/better in the morning) the trans has to come out. While it's out, what else should be done? I know there's an upgraded front seal and I'll replace the bushing too, plus probably pull the pump and replace the seal behind it. Anything else?
This truck is literally a grandpa rig that moves a moderate sized 5th wheel trailer a couple times a year so not looking for billet input shafts or triple disc converters. I'm sure the up-pipes are leaking by now but don't think having the trans out will make that job much easier, if at all?
The truck has the optional OE transmission temperature guage and it's never been hot. I think age and low mileage caused the leak.
Thanks in advance for any info
mwilliamshs is offline   Reply With Quote Quick reply to this message
Old 09-06-2019, 10:46 PM   #2 (permalink)
Member # 188835
Check the flex plate good for cracks and do the up pipes
rodslinger is offline   Reply With Quote Quick reply to this message
Old 09-06-2019, 11:28 PM   #3 (permalink)
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
If the trans temp guage on the 7.3 trucks is anything like the one on my 04 6.0 truck, it is pretty much useless. My trans got so hot before it died it was puking black fluid out the dipstick and the thing smelled like burnt atf and clutch(same smell as you would get with a stuck caliper) for a month afterward before I got to changing the trans. Temp guage still said it was perfect...
I suggest throwing in a rear main seal as well, might as well if you are in there.
96 F350 XL CC PSD/5 speed 4x4... Family hauler in the making
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk...
82F100SWB is offline   Reply With Quote Quick reply to this message
Old 09-07-2019, 06:36 AM   #4 (permalink)
Member # 84339
Rear main and uppipes.
Maybe do the pan if it's leaking. They're supposed to be a bitch though.
Add in an external cooler and a good temp gage.
Lugnut4x4.com
And i don't want to give Canadiens any more money, so my sig is broke.
Pt_Ranger_V8 is offline   Reply With Quote Quick reply to this message
Old 09-07-2019, 07:32 AM   #5 (permalink)
Member # 192237
do the engine oil pan if it is rusty, they rust through pretty often up here
Old 09-07-2019, 07:44 AM   #6 (permalink)
clb 017's Avatar
Member # 166307
Put a zf in it or spend the +-5k on the slushbox to make it last!
Rear mainseal ,new mounts if required.
If its made in china IT WILL FAIL!
Phawk photofukkit.
clb 017 is offline   Reply With Quote Quick reply to this message
Old 09-07-2019, 09:33 AM   #7 (permalink)
Member # 355210
Does the trans being gone actually make the uppipes easier?
Old 09-07-2019, 10:07 AM   #8 (permalink)
Member # 355210
Rear main is a good idea. Thanks
Old 09-07-2019, 10:39 AM   #9 (permalink)
Member # 161331
About a million times easier.
bdkw1 is offline   Reply With Quote Quick reply to this message
Old 09-07-2019, 12:36 PM   #10 (permalink)
jones518's Avatar
Member # 152143
Yes.
This is how I did my bellowed up-pipes from Riff Raff a few years ago. They make such a nice product, I wouldn't even mess around with re-sealing the factory pipes.
jones518 is offline   Reply With Quote Quick reply to this message
Old 09-07-2019, 03:46 PM   #11 (permalink)
Broke Bastard
Benny's Avatar
Member # 1129
I would do a zf swap. And definitely a cummins swap
Every day is better than the next.
Benny is offline   Reply With Quote Quick reply to this message
Old 09-07-2019, 06:43 PM   #12 (permalink)
Member # 157768
This x2.
speed bump is offline   Reply With Quote Quick reply to this message
Old 09-07-2019, 08:11 PM   #13 (permalink)
2big bronco's Avatar
Member # 66684
Ceramic coated bellowed up pipes. One of the best things I've done to my 7.3
Old 09-07-2019, 10:05 PM   #14 (permalink)
Member # 691314
Might not be a terrible idea to take a stab at the engine dipstick o-ring.
Gunwalls_Buckthorne is offline   Reply With Quote Quick reply to this message
Old 09-07-2019, 11:42 PM   #15 (permalink)
Member # 67823
Absolutely. Even with the trans out, my arms still looked like I'd been milking weasels by the time I was done.
Big diesel Ford, a stable of white toyotas from '84-08, and a bw200. They all need work.
squamch is offline   Reply With Quote Quick reply to this message
Old 09-08-2019, 12:32 PM   #16 (permalink)
Member # 4176
Is it actually transmission fluid leaking? Fuel from the engine valley runs down the backside of the block and leaks out the inspection port weep hole and people thing its engine oil from rear main or trans fluid.
If it is trans fluid, Do any tow alot? Ive read a good quality torque converter, mechanical shift kit and bigger trans cooler fixes a good majority of the major weaknesses in the 4R100. I put the 6.0 cooler in my SD.
StoopidMonkey is offline   Reply With Quote Quick reply to this message
Old 09-08-2019, 03:38 PM   #17 (permalink)
Back Woods's Avatar
Member # 74825
T4 turbo swap, Hydra tuning, bigger transmission cooler.
Back Woods is offline   Reply With Quote Quick reply to this message
