Leaf spring eye touches frame? - Pirate4x4.Com : 4x4 and Off-Road Forum
Register Blogs FAQ Community Calendar Premium Memberships
Old 09-13-2019, 01:26 PM   #1 (permalink)
Member # 871646
Any ideas as to why the eye of my leaf spring is touching the frame of my trailer?
Trailer is level and unloaded
All new equalizer, straps, and leaf springs.
I was trying to fix the problem by replacing all the suspension, but it is still there.
seanflippo is offline   Reply With Quote Quick reply to this message
Old 09-13-2019, 01:45 PM   #2 (permalink)
Member # 154867
I'm super excited for someone to answer this. I have to pull my trailer way nose down to get the front eye of the rear spring off the frame. So, exact same problem.
OHV Wildcat is offline   Reply With Quote Quick reply to this message
Old 09-13-2019, 01:52 PM   #3 (permalink)
Member # 871646
Do you have a problem with the leaf spring touching the frame when you tow?
Old 09-13-2019, 01:57 PM   #4 (permalink)
Member # 871646
Loaded with my Jeep
Old 09-13-2019, 02:07 PM   #5 (permalink)
backchat's Avatar
Member # 109999
Are the frame side spring mounts equidistant from the center pivot mount?
(just spit-balling here)
backchat is offline   Reply With Quote Quick reply to this message
Old 09-13-2019, 02:23 PM   #6 (permalink)
Member # 871646
Yes, with in 1/8”
Old 09-13-2019, 02:41 PM   #7 (permalink)
Member # 13786
My first answer would be that the center pivot mount got welded in the wrong place.
KWTMECH is offline   Reply With Quote Quick reply to this message
Old 09-13-2019, 03:20 PM   #8 (permalink)
Member # 871646
I think I figured out the problem. Any input would be appreciated. My spring perches on the front axle aren’t welded in place. So when I drove up onto the trailer they rotated and shifted the equalizer causing the rear to touch the frame
Old 09-13-2019, 04:40 PM   #9 (permalink)
coyote's Avatar
Member # 170
My understanding is the axle has to rotate to pivot the center equalizer, now it could have been it didn't get set up properly the first time and slipped...
I would on level ground loosen the front spring plate, rotate the equalizer to a neutral position and tighten things down on both sides. You could tack weld the spring plate to the axle to monitor movement but you could also see this at the equalizer.
Red Racer I
Toyota Prerunner
coyote is offline   Reply With Quote Quick reply to this message
Old 09-14-2019, 07:32 AM   #10 (permalink)
Member # 355210
Shackles look too long relative to the equalizer hanger bracket. Said another way: springs too long or shackles too long or hanger too short.
mwilliamshs is offline   Reply With Quote Quick reply to this message
Old 09-14-2019, 08:41 AM   #11 (permalink)
DMG
Member # 8145
That shouldn’t cause your problems. I bet those are welded on the inside.
DMG is offline   Reply With Quote Quick reply to this message
Old 09-14-2019, 08:46 AM   #12 (permalink)
Member # 871646
I just replaced the leaf spring and the perches definitely aren’t welded in place. I can get everything lined up perfect, but as soon as I drive away or load my Jeep the perches rotate and cause the equalizer to shift.
Old 09-14-2019, 09:00 AM   #13 (permalink)
Dinkerdoodledoo
Member # 10448
Send a message via Yahoo to Grendel
Shackles are too long, as someone else said.
Youre the only person on earth who knows all the details of your life, and thus, you are the most qualified captain of your own ship. Dont worry about justifying your course for pirate's sake. There's always someone here to tell you that you did it wrong.
Grendel is offline   Reply With Quote Quick reply to this message
Old 09-14-2019, 09:01 AM   #14 (permalink)
Member # 871646
They are 3 1/8” from hole center to center. Would 2 5/8” be a better fit then?
Old 09-14-2019, 01:08 PM   #15 (permalink)
gumboot cloggeroo
Muckin_Slusher's Avatar
Member # 467233
They make tall and short mounts for those suspensions.
The middle part can be a short welded thingy with a tall triangle, or a tall welded thingy and a short triangle. Looks like you got the short thingy and the short triangle.
Tall ones look like this:
Muckin_Slusher is offline   Reply With Quote Quick reply to this message
Old 09-14-2019, 02:09 PM   #16 (permalink)
Member # 56430
In this picture, it sure looks like the springs have a 'clamp' on only ONE end of the leaf pack. That leads me to believe the springs are directional, and each spring pack should have the 'clamp' on the centered edge, and the 'loose' end on the outer edge. Try swapping the direction of the spring around, and see.
TTC 1994, TTCC 2012, Trail Tours '05-'10, '12-'13
Member Eldorado Dust Devils, a PNW4WDA member
Treeclimber is offline   Reply With Quote Quick reply to this message
Old 09-14-2019, 04:26 PM   #17 (permalink)
Member # 871646
The clamps on the leaf springs should all be facing each other then? Pointed in towards the equalizer?
Old 09-14-2019, 04:27 PM   #18 (permalink)
Member # 871646
I welded the perches on, and there was no change. Back to square one.
Old 09-14-2019, 04:49 PM   #19 (permalink)
Member # 200478
The distances represented by the thin lines should be equal.
isbj60 is offline   Reply With Quote Quick reply to this message
Old 09-14-2019, 07:28 PM   #20 (permalink)
Member # 56430
If you're asking for ideas, then that's what I'd try.
Old Yesterday, 02:27 PM   #21 (permalink)
Member # 213860
I may have missed it but is the trailer level as your addressing the issue
K9Kodi is offline   Reply With Quote Quick reply to this message
Old Yesterday, 07:24 PM   #22 (permalink)
v30crewcab's Avatar
Member # 687834
something isn't equal. doesn't look level in the first pic. one axle is way closer to the trailer frame. check your distance between all three fixed mounting points. should be equal front to back.
88 chevy crewcab 6bt nv4500
72 scout 60/14b 40's
v30crewcab is offline   Reply With Quote Quick reply to this message
Old Yesterday, 07:26 PM   #23 (permalink)
v30crewcab's Avatar
Member # 687834
https://www.pirate4x4.com/forum/tow-...xle-setup.html
Old Yesterday, 07:38 PM   #24 (permalink)
Member # 53528
Attachment 2944870
this is the obvious answer to his problem, im not sure why its even being discussed anymore
Old Yesterday, 07:46 PM   #25 (permalink)
Member # 53528
the clamps should all be facing forward so when the brakes are applied the clamp keeps the axle from wanting to roll forward
