Wal-Mart battery tech - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-20-2019, 06:25 PM   #26 (permalink)
Member # 17947
Send a message via AIM to jaluhn
Lots of variables that would impact lifespan without showing up in a simple capacity check or weight. Weight just tells you how much lead - I'd bet most all the same group size batteries use the same size and design plates, which means weight will be pretty close to the same. What it doesn't tell you is the actual active material, porosity, purity, additives, etc etc. CCA is somewhat more useful, but still doesn't tell you all that much.
Point being there may very well be significant difference that make the price worth it.
jaluhn is offline   Reply With Quote Quick reply to this message
Old 11-21-2019, 02:25 PM   #27 (permalink)
Member # 55560
Put a Duralast Platinum H8 AGM in my land cruiser and under the Duralast logo was a Made in Germany sticker.
Why did I go H8? Easier to get warrantied than a Group 31 AGM and 80% of the capacity. Close enough for me.
A bunch of old crap
Mattafact is offline   Reply With Quote Quick reply to this message
Old 11-22-2019, 09:10 AM   #28 (permalink)
Member # 52361
While I agree with some of this, I disagree with some
I'm not a battery engineer, or claim to be, but more lead is very likely to mean more capacity.
The main purpose of weighing the batteries was to measure what I couldn't see.
But between an identical weight, plastic case, country of origin, matching cca, which was about 20% bigger than rated, I'm certain this $50 battery is identical to the $100 battery, so I'm pretty sure it's worth the price.
PROJECTJUNKIE is offline   Reply With Quote Quick reply to this message
Old 11-22-2019, 09:15 AM   #29 (permalink)
Member # 86724
put the $50 walmart battery in a buddy's explorer a few days ago.
seems good.
Old 11-22-2019, 03:12 PM   #30 (permalink)
Member # 53528
i agree and the price difference is due to different warranties between the two
rockyota83 is online now   Reply With Quote Quick reply to this message
Old 11-22-2019, 03:25 PM   #31 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
It would be a fun experiment to put the $100 battery with the better warranty in one vehicle and the $50 battery with the shit warranty in the other.
Then see which one costs you more in the long run.
The way I see it, you have just as much chance of the $50 battery lasting the same amount of time as the $100 battery. The part of the equation that's unknown is whether the $100 battery would last past its warranty terms. Theoretically, you could get two batteries for the cost of your one warranty that might never do you any good.
Action Fab is online now   Reply With Quote Quick reply to this message
Old 11-23-2019, 01:42 PM   #32 (permalink)
Member # 52361
I took my cores back today, and it looks like they are now selling the shitty Korean batteries as the premium
Caveat Emptor
Old 12-17-2019, 03:23 PM   #33 (permalink)
Member # 52361
Bump this up, I hauled in a used and abused $93 group 65 for warranty, it may or may not have been bad, that's not the point here
The data
The replacement was rated at 700cca and tested at 835cca
I bought 2 made in Mexico $50 batts, each rated at 650cca
One tested at 892 and the other at 865cca
All 3 cases were identical and had the exact same numbers melted into them
These are going in a clean 97 12 valve Cummins 2wd 5 speed extra cab that's for sale, hint hint
Old 01-14-2020, 07:07 PM   #34 (permalink)
Member # 52361
Update
Sent the 7.3 down the road, lots of sitting, lots of test drives, lots of being fired up cold and moved around the yard. Truck also had an intermittent charging issue, bad pigtail on alternator, batteries never missed a beat.
The 2nd pair I bought have been moved all over, used to start this, jump that, then used it to fire anther 7.3psd that had been sitting for months, cranked like mad and fired off, I'm real happy with these
Old 01-14-2020, 07:45 PM   #35 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
that's solid to know. I've been putting off buying a battery for my truck for a little over a year.
i'm about over hooking it up to the charger if it sits for more than 3 days
Provience is online now   Reply With Quote Quick reply to this message
Old 01-15-2020, 02:50 PM   #36 (permalink)
Rednek
billybob_81067's Avatar
Member # 52387
Send a message via AIM to billybob_81067 Send a message via MSN to billybob_81067 Send a message via Yahoo to billybob_81067
Good to know. I should have bought a couple Group 65 batteries from wal-mart for my 7.3IDI but I needed them right then and there to get some shit done, so I went to Napa and got some at like $125 a piece... OUCH!
Went to start it one morning and it was cranking real slow. Batteries were like 7 years old so i figured it was about time. Put new ones in and it cranked like a mofo. That is when I noticed the dome light was left on. Oh well I took some real old shit batteries in for cores, charged up the two that I pulled and one of them actually was bad. The other one got thrown in my folks 2011 F-150 that the original battery shit the bed on a week later, so it all worked out fine in the end.
Still coulda saved like half the cost if I got the value batteries at wally world!
The one, the only, the Dane.
billybob_81067 is online now   Reply With Quote Quick reply to this message
Old 01-15-2020, 03:04 PM   #37 (permalink)
Member # 79509
Originally Posted by [486] View Post
swap them out with god's intended lead and grease them up good with silicone grease
also, on the terminals, get the "milspec" ones that are huge and square. They have a 3/8-16 load terminal bolt rather than the dinky 1/4-20 that the cheap ones give you, crimp on eyelet terminals to your cables, again with dielectric in the crimped end (hydraulic cable crimper is $30 from china)
all my trucks have lead (molded) terminals. Need to cut them down, put on eyelets, and run those milspec terminals though.
AGMs still doing just fine, no corrosion like the others.
Black Sheep is online now   Reply With Quote Quick reply to this message
Old 01-17-2020, 09:46 AM   #38 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
Update after 3 weeks with these in my 7.3.
I put these in with a new gear reduction starter and 240amp alternator from DB electric. Engine is new, glow plug system works perfectly. I installed new battery cables at the same time.
I get one shot after the glow plugs cycle to start the truck. Usually that's plenty. However, if it doesn't fire off after about 5 rotations, the cranking amps fall on their face and the starter begins to slow substantially, to the point that I end up having to jump the truck.
These were the $50 650 CCA batteries. Granted, I do understand these trucks are better off with 950-1200cca. But it's remarkably hard to find CCA ratings that high anymore.
I give these a "1 star, do not buy for a diesel" rating.
Old 01-17-2020, 02:58 PM   #39 (permalink)
2big bronco's Avatar
Member # 66684
Hmm I just bought a pair of the $100 last night in prep for the trip out to your house... I'm wondering if i should return them and get the $50s now before I install them
Well I popped my hood to have a look and I already had the $100 walmart batteries with a date of 10/15. 4years plus is longer then the previous Deka batteries went so I just threw the new ones in. The take outs are still more then good enough for any of my beaters so now I need to go through the barn and find a couple to get my $26 core back
2big bronco is online now   Reply With Quote Quick reply to this message
Old 01-17-2020, 03:58 PM   #40 (permalink)
Member # 86724
it's not hard to find 1000CCA batteries with a high reserve capacity (which is a shit metric for measuring batery performance BTW, like PMPO wattage), they just cost money.
I just put a 900CCA battery in my wife's volvo, and a 1100CCA battery in my BMW.
both with hefty reserve capacity/AH numbers.
but they're also $150+ dollar batteries.
Old 01-17-2020, 05:06 PM   #41 (permalink)
Member # 192237
just get group 31s
they fit the ford trays perfectly, just gotta space them down a couple inches so the terminals aren't in the hood
oh and make a different holddown because the wedge won't hold a 31
[486] is online now   Reply With Quote Quick reply to this message
Old 01-18-2020, 08:23 AM   #42 (permalink)
Member # 17947
Wbut more lead is very likely to mean more capacity.
Not true. That's about as accurate as saying that an engine that weights more likely makes more power without paying any attention to displacement, gas vs diesel, year, etc. The plate design, active material formulation and formation process are what really control battery capacity and life, and the physical weight of lead has only an indirect relationship to that. Purity of the materials and variability in the process are probably the biggest things that should determine life. Even very small amounts of contaminants or small reductions in certain desired additives can have significant impacts, and there's no good way to know that short of expensive lab tests. I would even go so far as to say that more lead may mean lower life, since it could mean thicker grids with less active material (lower capacity) or thicker plates with less open space between (more likely to short).
Bottom line, there's unfortunately no real way to know short of real life testing for life, and even then I'd expect quite a lot of variation from cheap cells - some may have quite good life and some may be junk.
Old 01-18-2020, 08:45 AM   #43 (permalink)
Member # 52361
There could be differences, but at this point in time, I'm satisfied it's the exact same battery, marketed at a different price, with a different sticker, with a different warranty.
If you've got info on some additive, added on the assembly line, that doesn't affect weight, appearance, or CCA, I'd listen
Old 01-18-2020, 09:34 AM   #44 (permalink)
Member # 86724
I'd assume, and we all know what that means, that they make so many batteries a day using the same equipment.
some turn out better than others when they are QC'd.
those get fancy labels and warranties and ratings, and the lesser ones become value batteries.
like semiconductors.
You make a silicon wafer and you don't know what you've got until you start testing cpus.
but that's all conjecture on my part.
Old 01-18-2020, 02:06 PM   #45 (permalink)
Member # 66684
I have a friend that owns a fuel additive company. His products varry from $5-15 and are for gas and diesel engines..... they are all the exact same product with different color dye in them
Old 01-18-2020, 02:54 PM   #46 (permalink)
Member # 53528
id assume they arent testing every battery so theyre not classifying them upon the results
im gonna have to agree with projectjunkie, i think the batteries are the same and the price difference is due to the sticker and warranty length. they do this same thing in plenty of other industries, pay more for a longer/better warranty for the same product
Old 01-20-2020, 02:03 PM   #47 (permalink)
Member # 52361
I'm thinking you've got something going on there, even a low quality battery shouldn't shit the sheets that early, clearly more CCA is better, but I'm spinning my 7.3s easily, are you starting out with 12.6v? Drawing when sitting? Starter motor suspect? One defective battery? Bad connection on one battery? I'd pull them, charge and load test, I'm curious.
I missed this earlier, keeping the truck aroubd, I could see the value in the warranty
Old 01-20-2020, 11:39 PM   #48 (permalink)
Rednek
Member # 52387
This... Sum Ting Wong...
Old 01-21-2020, 05:59 AM   #49 (permalink)
today
fredycruger's Avatar
Member # 225557
got same 650's in my 99 7.3 and it starting just fine in this 10-20 weather
they been in there since last spring
fredycruger is offline   Reply With Quote Quick reply to this message
Old 01-26-2020, 04:52 PM   #50 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
I took them back and used the warranty with success. The process was a pain though. First they failed the test. But of course they were at 11.6 and 11.8 volts. So they put them on the charger for an hour. Then they load tested again and both failed again.
Both were Korean. I got Maxican batteries the second time. Maybe they will work harder.
Definitely no issues, just chitty batteries. I already had the alternator rebuilt (rewound from 70a to a 165a) and added a new gear reduction starter along with all new cables.
