big dumb loads... post your pics. - Page 523 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-15-2019, 07:19 PM   #13051 (permalink)
v30crewcab's Avatar
Member # 687834
isn't some of the drill stem slightly radioactive? may be why its so cheap.
88 chevy crewcab 6bt nv4500
72 scout 60/14b 40's
v30crewcab is offline   Reply With Quote Quick reply to this message
Old 05-15-2019, 08:58 PM   #13052 (permalink)
Newbie
M92pv4u's Avatar
Member # 860424
The box and the pin threads and Mating surfaces wear out. If the pipe is used long enough the recirculating sand will wear the inside of the pipe out which may cause it to break while drilling.
M92pv4u is offline   Reply With Quote Quick reply to this message
Old 05-15-2019, 10:48 PM   #13053 (permalink)
2big bronco's Avatar
Member # 66684
Not really big and kinda dumb...
After 2 years my free harbor freight trailer decided it no longer liked having 300 gallons of water on it. It was mostly fine untill the tank slid back beyond the rear axle going up the hill.
if you didnt grow up riding, crashing, and fixing 3 wheelers you had a shitty childhood
Old 05-16-2019, 12:31 AM   #13054 (permalink)
Member # 85771
Originally Posted by DMG View Post
I think the question wasnít about the service life of steel tube. He wanted to know why it was taken out of service.
Correct
Thanks for the answer.
Make Forums Great Again!
ky scrambled is online now   Reply With Quote Quick reply to this message
Old 05-16-2019, 04:20 AM   #13055 (permalink)
arse_sidewards's Avatar
Member # 256962
Good to know the HF trailer can carry a compact car in a pinch.
arse_sidewards is online now   Reply With Quote Quick reply to this message
Old 05-16-2019, 04:47 AM   #13056 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
Thumbs up
No joke. That's like 2500lbs. I'm about to load a 17kw generator, a compressor, a 255 Lincoln and a plasma cutter on my HF trailer. Sounds like I'll be way under it's working load limits.
Action Fab is online now   Reply With Quote Quick reply to this message
Old 05-16-2019, 05:35 AM   #13057 (permalink)
Member # 256962
Having used them a couple times in person (as opposed to just looking at them in the store) I think welding the joints and a welded steel deck would go a hell of a long way toward stiffening it up at which point you'd probably bend the axle if you tried to actually use it hard.
Old 05-16-2019, 05:42 AM   #13058 (permalink)
Mr. Mindless's Avatar
Member # 24238
Proof & reminder that load securement isnít optional
#571 Last Minute Motorsports
koh19 pit crew: 4632
koh18 codog: 901, 4816 - pit crew: 928, 209, 4610
Mint17 pit crew: 4454, 946, 8199
koh16 codog: 2700 - pit crew: 572, 928, 4610
koh15 pit crew: 572
Mr. Mindless is offline   Reply With Quote Quick reply to this message
Old 05-16-2019, 05:47 AM   #13059 (permalink)
DMG
Member # 8145
I have a small HF trailer I bought to use behind an atv for moving firewood, etc around at our cabin. I welded it up and painted it with rustoleum and it has really held up well to some rough use.
DMG is offline   Reply With Quote Quick reply to this message
Old 05-16-2019, 05:53 AM   #13060 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
I've had mine setup for dirt bikes. But since selling both the dirt scoots and the Prius I use to pull them with, it has just sat around. I have some pipe projects here on the farm to weld up and dont want to build a skid for the bed of my truck. I also don't want to get my box van stuck in a field. I figure the HF trailer behind the tractor will be perfect. They really do seem to hold up well though. I figured up that mine had around 1100 lbs on it when I had it loaded up with bikes and gear. It made the trip out to Utah and back like that without any issues. Pretty impressive for a $350 trailer.
Old 05-17-2019, 02:03 AM   #13061 (permalink)
Member # 7412
To lazy to swap trucks.
https://gunracer1.imgbb.com/
m35A2C 4x4 sitting on 49" R2s,suburban 454/465/205 43" ag tires,Durango on tons and 40s
gunracer1 is offline   Reply With Quote Quick reply to this message
Old 05-17-2019, 06:25 AM   #13062 (permalink)
Member # 24238
good god
also, bbcode.
<img src="https://i.ibb.co/HgMkVgk/5345-A4-CD-9-E12-478-C-BACC-EA28-F9787-DF0.jpg" alt="5345-A4-CD-9-E12-478-C-BACC-EA28-F9787-DF0" border="0">
koh15 pit crew: 572
Old 05-17-2019, 06:45 AM   #13063 (permalink)
Member # 192237
winner
(probably has bigger brakes than anything pre-80s)
Old 05-17-2019, 07:00 AM   #13064 (permalink)
Member # 7412
it towed it just fine, i was surprised the brakes worked as well as they did. heck if i had trailer brakes i would not have be afraid to run 70 down the road. edit, i have no idea who to get a pic from there now a days.
Old 05-17-2019, 08:14 AM   #13065 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
Knowing how heavy my 5500lb warehouse forklift is. That's crazy that you didn't even have trailer brakes.
Old 05-17-2019, 08:50 AM   #13066 (permalink)
YotaAtieToo's Avatar
Member # 25632
13.7k according to Google
Old 05-17-2019, 09:26 AM   #13067 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
Jesus, dude. How heavy is that trailer? 5-6k lbs? Looks like a mostly steel deck, hydraulic tilt 24'?
Old 05-17-2019, 09:38 AM   #13068 (permalink)
Member # 79509
That's very subjective
Black Sheep is offline   Reply With Quote Quick reply to this message
Old 05-17-2019, 10:58 AM   #13069 (permalink)
Member # 7412
26' and your right about everything else. I didn't tow it far, power wise the truck seemed fine. And the brakes felt decent. I did have a load leveling hitch on it, that helped for sure. I sure as hell have towed loads that felt worse. I had I picture on this thread with a old D6 behind my 2500 on a bumper pull. That was just shit.
Old 05-18-2019, 10:44 PM   #13070 (permalink)
Rooster831's Avatar
Member # 361841
we pulled a 50's d4 with a 96 1500 like 60 miles on a bumper pull with no trailer brakes aswell, good times
Spending thousands of dollars on a vehicle for the sole purpose of driving over shit in the woods.
Rooster831 is offline   Reply With Quote Quick reply to this message
