I did some trailer work. - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-17-2007, 07:02 AM   #26 (permalink)
Ken Carter / BRUISER's Avatar
Member # 3321
Send a message via AIM to Ken Carter / BRUISER
looks good I like it a lot
Ken Carter / BRUISER is offline   Reply With Quote Quick reply to this message
Old 10-17-2007, 07:56 AM   #27 (permalink)
vanguard_anon's Avatar
Member # 55997
That trailer looks really slick, I like it. Do you think you'll load the truck going foward now that it's a gooseneck?
'03 V6 5 speed taco &&
vanguard_anon is offline   Reply With Quote Quick reply to this message
Old 10-17-2007, 01:29 PM   #28 (permalink)
nissancrawler's Avatar
Member # 76684
I actually load it forward with the bumper pull, too. I just keep it backwards like that while I'm doing the SAS and suspension work on it, because I can back the trailer into the driveway and winch it off with the front end facing the garage. It gets moved in and out of the driveway as I work on it.
[QUOTE=nahmus;9175355]asking chit chat to stop before they are done is kinda like asking piranhas to stop after one bite.[/QUOTE]
nissancrawler is offline   Reply With Quote Quick reply to this message
Old 03-26-2008, 07:56 PM   #29 (permalink)
Member # 111494
Nice setup
Originally Posted by nissancrawler View Post
I finished up a bunch of tidbits.
I got a framework and expanded metal welded in between the tongue, and the battery box mounted.
I mounted the ammo can for the winch controls.
I started the wiring panel.
The switch on the far right is for a trailer flasher I'm wiring up. It'll run off the car battery if for some reason the trailer has to be left on the road (either because of towrig or trailer breaking). I'm using two diodes to keep the flasher relays from feeding each other, I don't know if it's necessary, but it won't hurt. *shrug*
The switch second from the right is for charging from the pickup alternator. I have a fusible link, and a diode before the switch. The diode should take care of putting extra draw on the pickup wiring, but I put the fusible link in just in case something happens, it's cheap insurance, right?
The switch under the light runs the light above it, and four small clear led light setups I'm mounting on the trailer for night time loading/unloading. I've done it in the dark for years and hate it.
The space between the switches (where the hole is drilled) is for a small led voltmeter to keep an eye on the battery.
The space on the far left is for a 350 amp marine battery disconnect.
I'm waiting on the battery switch and volt meter currently.
The panel is easily removable with the 4 prong plug, although two battery cables will have to be removed from the switch, not a good way to make that easier.
Everything except for the alternator switch will be switched through the battery switch, if it's off, nothing other than charging the battery will work.
Can I get a wiring diagram and parts list?
james04r6 is offline   Reply With Quote Quick reply to this message
Old 03-27-2008, 02:26 AM   #30 (permalink)
Member # 76684
For what part? I can help, but as to a complete diagram...I just pull this shit out of my ass and do it. Parts...were here and there.
I do need to get some updated pictures up.
Old 03-27-2008, 05:18 PM   #31 (permalink)
Member # 111494
Switch box
Would like to build me one. I not sure how to wire it up or what parts to use. I just bought the trailer it has a 8000lbs winch. I want to wire it up so my truck will charge the winch battery up. If give me some helpful info it would nice.
Old 03-28-2008, 02:23 AM   #32 (permalink)
Member # 76684
Give me a few days to do a diagram and get some pictures. I'm not even sure how I did it, I just went wire by wire at the time.
Old 03-28-2008, 08:22 PM   #33 (permalink)
Member # 111494
Thanks
Old 04-04-2008, 02:59 AM   #34 (permalink)
Member # 76684
Haven't forgot about the diagram, in the mean time, here's a few more pics.
Spare tire holder:
Stabilizers for loading.
Reflective tape:
No-skid tape on top of fenders (darn near split my sack open when it was raining a few times):
Tongue setup:
EZ Jack:
Electrical setup (rolled up wires are for loading lights, and hazard light setup, yet to be done):
Old 04-04-2008, 06:58 AM   #35 (permalink)
Member # 3321
Damn man.. you trailer is more custom then most rigs on the trails
looks good
Old 04-04-2008, 10:35 AM   #36 (permalink)
JCC
Member # 13845
I like the way you have your receiver setup for the winch. I'm looking for a way to do mine, but I have a drop leg jack in the way. JC
88 Zuk. Spring over with RE YJ's Toy axles 5.29's welded rear Aussie up front. LC power steering,105 amp alternator, Short 33's Ramsey 9K qm Soon to have TT 6.4's
JCC is offline   Reply With Quote Quick reply to this message
Old 04-07-2008, 08:28 AM   #37 (permalink)
Member # 70258
Nice work....
The only constructive criticism I would make is that the spare tire holder (strap over tire) will loosen if the spare were to loose air and that spare could flop around some....Just a thought.
Otherwise, looks good!
1987 Samurai 5.0/ 14 bolt/ hp60 welded with 38.5 sx's on h1's C6/1356/np205 108" wb
Jy Dog is offline   Reply With Quote Quick reply to this message
Old 04-07-2008, 09:42 AM   #38 (permalink)
dragoonranch's Avatar
Member # 69640
Send a message via AIM to dragoonranch
It might look a little funny, but you could always mount the winch to one side or another. I can't see how it being a few inches off center would make that much of a difference. Now, if you don't have enough room to mount it infront of it, then that would stop you.
Big Ed
'78 Chevy Big-30
TTC 2010 here we come!
Thanks to all who voted for us, we are gonna put on one hellufa show!
AMSOIL Your last stop for all your Automotive Synthetic Lubricant needs.
Please PM me for quotes or questions.
dragoonranch is offline   Reply With Quote Quick reply to this message
Old 04-14-2008, 08:50 PM   #39 (permalink)
Mechanos's Avatar
Member # 6704
Well, all of my Waytek order finally got here. I got all the cables soldered up tonight, wired in the volt gauge, etc.
I need to get a diode and fusible link for the charging wire, and two diodes and an electronic flasher for the trailer hazards, then it will be done.
Is that volt meter one of the ebay specials? Does it use an alternate power source for the voltmeter or does it pull power from the battery it's monitoring? Does it have a built in power regulator or are you using a separate power regulator?
In the near future I'm going to be replacing the old "battery boiler" converter in my camper with a new Iota Engineering smart charger. My camper currently doesn't have anything to monitor battery condition, so I'm going to be adding a volt meter. I just bought one of these off ebay:
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote Quick reply to this message
Old 04-14-2008, 09:15 PM   #40 (permalink)
Member # 76684
In the near future I'm going to be replacing the old "battery boiler" converter in my camper with a new Iota Engineering smart charger. My camper currently doesn't have anything to monitor battery condition, so I'm going to be adding a volt meter. I just bought one of these of ebay:
It has it's own source. Just a positive and a negative from the battery. It's the main reason I picked that panel.
Old 04-14-2008, 10:12 PM   #41 (permalink)
Mechanos's Avatar
Member # 6704
When you say it has it's own source, do you mean it's powered by a separate battery, or the battery it's monitoring? Where did you get that panel?
Old 04-14-2008, 11:12 PM   #42 (permalink)
Member # 76684
http://cgi.ebay.com/Green-LED-Volt-M...742.m153.l1262
Old 07-11-2018, 10:00 AM   #43 (permalink)
Member # 654993
doing some of these to my trailer ASAP!
rshaw9525 is offline   Reply With Quote Quick reply to this message
Old 07-11-2018, 10:23 AM   #44 (permalink)
Member # 25448
I should go wheeling
SkZuk is offline   Reply With Quote Quick reply to this message
Old 07-11-2018, 08:16 PM   #45 (permalink)
Member # 174683
I thought he was finally going to post the wiring diagram...
tab2 is offline   Reply With Quote Quick reply to this message
Old 07-12-2018, 08:36 AM   #46 (permalink)
ANGER IS A GIFT
Dookey's Avatar
Member # 23680
Typical internet thread is typical.
Old 07-13-2018, 08:17 AM   #47 (permalink)
Member # 52361
After 10 years, looks like you don't need to borrow a trailer anymore
PROJECTJUNKIE is online now   Reply With Quote Quick reply to this message
