Z71 to 3/4 ton conversion. Anyone done it? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-02-2010, 10:20 AM   #1 (permalink)
Member # 78077
i have a great old truck 92 Z71 has a NV4500 trans and a 5.7 that runs great. My only hang up is the 10 bolt and weak suspension. I am not wanting to sas this truck. just thinking about buying a parts truck 2500 8 lug and swapping everything over. Anything that wont just bolt up. I know the cv shafts are different size so i will have to use the front IFS carrier and cvs, but does it bolt right in. I dont have one to check out so I am asking for the knowledge from this board for help. Thanks
Don't blame me, I voted against him.
#rawkon is offline   Reply With Quote Quick reply to this message
Old 02-02-2010, 11:24 AM   #2 (permalink)
Member # 13384
Send a message via AIM to SolidAxleDurango
You're a turd.
08 Kawa ATVs / 14 AC Wildcat X <- we ride / 07 Ram <- we pull / 12 Keystone Avalanche <- We sleep
SolidAxleDurango is offline   Reply With Quote Quick reply to this message
Old 02-02-2010, 11:31 AM   #3 (permalink)
Member # 78077
Originally Posted by SolidAxleDurango View Post
You're a turd.
Your an Azzhole. but that doesnt help with my question.
Anyhow I found the info on anohter board. Thanks for nothing solidaxlePOS
Old 02-02-2010, 11:38 AM   #4 (permalink)
Member # 13384
Originally Posted by #rawkon View Post
...Anyhow I found the info on anohter board..
Do us a favor. Spend more time there.
Old 02-02-2010, 11:39 AM   #5 (permalink)
Member # 78077
Eat a dick! your nobody special either.
Old 02-02-2010, 11:57 AM   #6 (permalink)
Member # 13384
You're not trying very hard!
Old 02-02-2010, 12:14 PM   #7 (permalink)
Member # 17632
I think you probably found that it's do-able, yes? I've seen it done, so I know it can be done, but the rate at which things can just be swapped without modification is unknown to me. That's all I got.
Travis..
18 Ram 2500 4x4 Big C and a 6 speed
73 Dodge W100, 400 4spd, stepside project
crashnzuk is offline   Reply With Quote Quick reply to this message
Old 02-02-2010, 12:31 PM   #8 (permalink)
Member # 78077
Its pretty straight forward, but I might just machine down the 14 center and make a new bolt pattern to fit my wheels like this guy did.
https://pirate4x4.com/forum/showthread.php?t=853055
Old 02-02-2010, 12:32 PM   #9 (permalink)
Member # 78077
With people like you, its a wonder why people automatically think i am inbread when i tell them i am from Oklahoma. Stop messing around with your sister and lets get to talking about trucks again.
Old 02-02-2010, 12:44 PM   #10 (permalink)
Member # 13384
With people like you, its a wonder why people automatically think i am inbread when i tell them i am from Oklahoma. Stop messign around with your sistere and lets get to talking about trucks again.
Hey speak and spell, you're not helping your "not a turd" case.
Old 02-02-2010, 12:57 PM   #11 (permalink)
665.0coupe's Avatar
Member # 80841
Why is the 10 bolt and weak suspension a hang up? Are you towing something or hauling something that is overloading the suspension and axles? Or are you just bored and looking for something to do?
Sounds like a lot of work to get a truck that has 2500 suspension and axles and is still tagged and weight rated as a 1500.
And then why would you want to upgrade the suspension and axles but modify them to keep the same wheels and light truck tires from the 1500.
Sounds to me like you need to find a 2500 with a blown engine or trans and swap the parts from the 1500 to a 2500.
665.0coupe is offline   Reply With Quote Quick reply to this message
Old 02-02-2010, 04:49 PM   #12 (permalink)
Member # 20092
just find a mini 14b semi floater from one of those 'HD' 1500s. It has the correct bolt pattern and is a direct swap.
'94 Toyota Land Cruiser FJZ80 - Vortec L33 5.3l, 4L60e, elocked, 3" OME lift, 315 KM2s, Warn 8074.
rock-rod is offline   Reply With Quote Quick reply to this message
Old 02-02-2010, 07:06 PM   #13 (permalink)
supersize75k5's Avatar
Member # 29341
You're a turd.
Thanks for the great tech and contributions..
supersize75k5 is offline   Reply With Quote Quick reply to this message
Old 02-02-2010, 08:15 PM   #14 (permalink)
Member # 72000
while i dont think youll break a semi-float 1.5" shaft,i personally think the full floater is worth alot of piece of mind. if you have wheels youre attached to and want to stay 6 lug id covnert a FF to 6 lug before swapping in the SF axle.
a friend of mine runs a 6 lug 14 bolt in his half ton chevy. the WTF looks it gets from people that realize its a 14 bolt then that its 6 lug are priceless
i personally would swap a FF in the rear. if you dont mind being 8 lug id leave it that way,and upgrade the rear springs. id prolly SAS it,but in a tow rig the 3/4 ton IFS would prolly work fine.
scotty
85 grand waggoneer(what's left of it)
77 scout II truggy
84 chevy home made crewcab
Delightfully Tacky,Yet Unrefined
nightcrawlers is offline   Reply With Quote Quick reply to this message
Old 02-02-2010, 08:22 PM   #15 (permalink)
Member # 65983
the key here is no matter what you put into axle wise its still a half ton frame... now i will admit im not sure of the differences between the frames in the old c/k body trucks BUT there is more than axles and some heavier springs that make a truck 3/4 ton.... what are your plans for it towing wise? ive never had any issues out of any of my half ton chevies and i used to tow 20 plus foot boats on a daily basis with them, as far as half tons go they are the best ive ever used
just driving a camry.....
xjdoug is offline   Reply With Quote Quick reply to this message
Old 02-03-2010, 12:06 AM   #16 (permalink)
Member # 78077
And again, your an asshole. not contribute something useful if this conversation isnt over your head already
Old 02-03-2010, 12:08 AM   #17 (permalink)
Member # 78077
My intention is to fix the weak link. I read on another thread where they used a FF14 adn machined down the bud to fit 1/2 ton wheels and drilled new bolt pattern in the drums adn flanges. I am not attached to my wheels, but i dont want 6 lug on the frotn and 8 on the rear. Still lookin at options. thansk for all teh useful replies so far
Old 02-03-2010, 12:31 AM   #18 (permalink)
Member # 103610
Send a message via AIM to jeep937
My dads '96 Z is called a "Heavy Half", done.
jeep937 is offline   Reply With Quote Quick reply to this message
Old 02-03-2010, 06:56 AM   #19 (permalink)
Member # 72000
which weak link? the rear axle and suspension,or the IFS front?
i dont blame you,but id prolly make the front 8 lug to match it. my friend did the 6 lug conversion because he had aluminum wheels he was attached to and they dont make them in 8 lug.
i dont know what the various weight ratings are on stock wheels,but seems you should be better off in a tow rig with 8 lugs. if the IFS dont bother you just swap in the 1 ton IFS. otherwise id SAS it-even if you just used a 10 bolt.
i was definately not suggesting you run 2 different lug patterns and carry 2 spares in your tow rig
scotty
77 scout II truggy
