Another wierd GN setup in Alabama - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-02-2010, 12:16 AM   #1 (permalink)
Member # 78077
http://mobile.craigslist.org/grd/1770652841.html
Odd axle arrangement. never seen this before. Changing that inside tire must be a real PIA.
Seems like ti would be a very sturdy design though.
Don't blame me, I voted against him.
#rawkon is offline   Reply With Quote Quick reply to this message
Old 06-02-2010, 01:43 AM   #2 (permalink)
Member # 138487
theres a couple manufacturers that built these trailers....i can't think off hand the name of the companys. They are extremely well built and spread the weight better to alleviate the worry of a bent axle if overloaded.
A neighbor of my dads has one and i helped him do bearings and brakes several years ago.....everything on his was standard dexter parts. And yes changing the inner tires/servicing brakes & bearings is a complete pain in the ass unless you pick up the ass end of the trailer with a front end loader while it's hitched to the truck.
1983 Dodge W250: 440 HP big block under the hood sitting on 38.5 Boggers......And it goes on
psycoticredneck is offline   Reply With Quote Quick reply to this message
Old 06-02-2010, 02:37 PM   #3 (permalink)
Member # 132500
There was just a thread about that kind of thing - https://www.pirate4x4.com/forum/showthread.php?t=887321
The one you posted has two sets of springs per axle which looks to me like it'd locate the axles a lot better. But I still don't really get the point... I don't think I'd want to put 24,000 plus tongue weight on that trailer, and the whole setup is more complicated than it needs to be.
Machinos is offline   Reply With Quote Quick reply to this message
Old 06-02-2010, 05:09 PM   #4 (permalink)
Member # 33623
They are really a great trailer. I used this style when I worked construction and I have one here on the farm. They haul everything I have and that is up to 30k. The down fall, changing the inner tires. Last time I changed tire I just flipped it on its side and took them off that way. My tires last longer on it than they do on the tandem dual flat bed.
Can't go to sleep or the clowns will eat me!
Hot dog is offline   Reply With Quote Quick reply to this message
Old 06-02-2010, 05:51 PM   #5 (permalink)
jasonmt's Avatar
Member # 3236
This particular arrangement also allows you to use the single tyre weight ratings rather than the dual tyre weight ratings, with the ubiquitous 235-85-16 LRE you gain over 2100#'s of weight capacity over running 4 sets of duals using the same tyres.
[QUOTE=Roxywheels]The trolls always out themselves :laughing: :roxy:[/QUOTE]
jasonmt is offline   Reply With Quote Quick reply to this message
Old 06-02-2010, 07:57 PM   #6 (permalink)
Member # 119289
isnt that know as a "trailmax" suspension, or something similar? backhoe trailers use that setup alot......
'97 f450; 24v cummins, zf5, 19.5s, no stickers, no smoke, no stacks, no bullshit
some zilch is offline   Reply With Quote Quick reply to this message
Old 06-02-2010, 09:39 PM   #7 (permalink)
Member # 132500
But again, I don't think I'd want to put nearly that much weight on a trailer made for single wheel axles...
