TJM Air Locker Sale was $950 now only $879.99 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Brand Specific Tech > Toyota - FJ Cruiser
Old 10-11-2017, 11:31 AM   #1 (permalink)
Member # 677449
Send a message via Skype™ to X-DIFF
Arrow TJM Air Locker Sale was $950 now only $879.99
Hey guys,
We are having a massive sale on our TJM Air Lockers until the start of the new year. The TJM Lockers are well made and wide range of features such as the ones listed below:
  • Unique one piece cross shaft (instead of the usual three) with hardened thrust washers.
  • Larger pinion gears are used in comparison to most standard differentials.
  • No carrier modification needed (other than the drilling and tapping of a bulkhead fitting port)
  • Large pre-tensioned 3/8” bolts hold the pro locker hemisphere together.
  • Air operated piston style actuator eliminates the possibility of oil being pumped into the airline.
  • Separate pneumatic system that has no internal 'o' rings or oil seals adding to its operational simplicity and low maintenance.g to lbs
  • Tested for outstanding Performance and Quality for over 20 years! Manufactured in Australia.
  • TJM Pro Lockers combination of simplistic design with components of exceptional strength and quality will leave you satisfied with your choice for years to come.
  • Reinforced rubber external hose extension is supplied as standard to minimize the risk of the airline being damaged by debris while driving.
  • Recessed colored L.E.D. cabin switches show clearly when TJM Pro Locker is on or off
To find out more please visit https://xdiffautoparts.com/Technical...ed_air_lockers
Or email or call us @ [email protected] or 734-470-0013
X-DIFF is offline   Reply With Quote Quick reply to this message
