Help me ID my brake parts - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-18-2013, 12:53 PM   #1 (permalink)
Member # 35855
Ftoy needs better brakes. Trying to get an idea what I already have.
Hammers-#817
RockinSpider is offline   Reply With Quote Quick reply to this message
Old 09-20-2013, 02:49 AM   #2 (permalink)
mtbrjon's Avatar
Member # 36007
You have a factory booster/master and front disc. Why do you need "better" brakes?
Sent from AutoGuide.com Free App
"I wanna get me a truck and soop it up with some metal!" -Wingo
mtbrjon is offline   Reply With Quote Quick reply to this message
Old 09-23-2013, 08:53 AM   #3 (permalink)
Race Radio Vendor
RuggedRadios's Avatar
Member # 122268
MC has been leaking between reservoir and the master cylinder. Looking to replace it and or the booster. Is this a dual diaphragm booster? I need better brakes because since I got the ftoy it has had a low pedal that improves with pumping, even after many correct bleeding attempts.
Thanks for the insight mtbrjon, would you happen to know which years these were factory?
Rugged Radios
(888) 541-7223
Forum members receive 10% off retail! Use coupon code PIRATE10
RuggedRadios is offline   Reply With Quote Quick reply to this message
Old 09-23-2013, 10:44 AM   #4 (permalink)
a2b
a2b's Avatar
Member # 22547
okay so you need brakes that actually work, not better brakes that what you have. right?
i can't tell what calipers are those? are those the ifs calipers or the solid axle ones?
you want the ifs calipers
-Hobie
GOTPROPANE.COM
HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER!
a2b is offline   Reply With Quote Quick reply to this message
Old 09-23-2013, 11:02 AM   #5 (permalink)
mtbrjon's Avatar
Member # 36007
I like disc on all wheels. The Chevy 1/2 ton caliper conversion that a few vendors sell is cheap and easy. You'll want to get the Landcruiser MC for non-abs I think it's 1" bore. Like R2D2 said you want IFS front discs.
Old 09-23-2013, 11:05 AM   #6 (permalink)
a2b
a2b's Avatar
Member # 22547
he definetly has the IFS rotor, just not sure about caliper
-Hobie
GOTPROPANE.COM
Old 09-23-2013, 12:00 PM   #7 (permalink)
Member # 35855
I will get better pics of the caliper.
Hammers-#817
Old 09-26-2013, 12:06 AM   #8 (permalink)
Member # 43587
Send a message via AIM to TBItoy
Looks like he has the IFS hub swap since the calipers are mounted on the outside of the knuckle ears, probably a LC rotor re-drilled to fit on the back of the IFS hub.
And what looks to be "regular" ifs calipers (not the bigger late model/v6 calipers)
The Gremlin - small ugly linked beater Toyota
TBItoy is offline   Reply With Quote Quick reply to this message
Old 10-07-2013, 09:00 PM   #9 (permalink)
Blue Devil Toyota's Avatar
Member # 13438
Brakes sucked till I did this mod. Starting at post 42 https://www.pirate4x4.com/forum/suzuk...v-build-2.html
South Bay Drive Line
Blue Devil Toyota is offline   Reply With Quote Quick reply to this message
