Head room - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-19-2014, 08:45 AM   #1 (permalink)
Member # 20276
Head room
Man how much head room do you guys have on your f-toy setup?
Right now with the bottom of my chassis level with the frame rails with f-toy frame brackets and using 1"x1" Sq tubing for floor board frame.tubing laying on the frame. I only have a fist between my head and cage, The rear of the seat mount at floor level and the front is 2" about floor pan.
Do yall have the same problem.
01 RAM 2500 24V CUMMINS DD/Krawlerhauler
85 Yota Buggy 4.3/tb350/x2ler/2.5tons/42"s
Ramrock is offline   Reply With Quote Quick reply to this message
Old 11-19-2014, 10:37 AM   #2 (permalink)
Member # 364081
I mounted my chassis 2" above frame rails for headroom
Jimmy_MBF is offline   Reply With Quote Quick reply to this message
Old 11-19-2014, 11:02 AM   #3 (permalink)
Tech Editor
Air Ride's Avatar
Member # 1656
It all depends on what kind of seats you are using. With Mastercraft seats and everything mounted as you described I have the fist size clearance around my head and I'm 6'2".
camo is my hero, even if he is gay
Air Ride is offline   Reply With Quote Quick reply to this message
Old 11-19-2014, 12:35 PM   #4 (permalink)
Member # 20276
Im running the racetrim wide style.
They bottom tab mount like most seats.
Im 5,11" but i have a tall torsoe.
Old 11-19-2014, 04:24 PM   #5 (permalink)
Member # 1663
I believe my chassis is mounted level with the frame, and with the PRP's in mine, I have 3" over my head with a helmet on, and I'm 6'2". The back of my seats are sitting on the frame, the fronts up about 2".
maveric is offline   Reply With Quote Quick reply to this message
Old 11-19-2014, 06:33 PM   #6 (permalink)
a2b
a2b's Avatar
Member # 22547
i put in the seat mounts before i mounted the chassis. we ended up putting the chassis 1.5" off the top of frame rail. if i did it again i would do the same but i would also mount the seats lower than the top of the frame rails like i did the first time. even if it meant notching into the frame rail. the space under the seat ended up being waisted and the lower you get your body the better the COG is. which is a great way of dealing with COG concerns rather than the "interweb stellar idea" of running flat springs
-Hobie
GOTPROPANE.COM
HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER!
a2b is offline   Reply With Quote Quick reply to this message
Old 11-21-2014, 09:55 AM   #7 (permalink)
Member # 20276
Man im running rockwells and h1/42'. So i have ton of COG.
Head room is the big thing for me. I can chop a 1/4' out of acouple brackets/tabs. Maybe get the seat down 3/4" lower...
Old 11-21-2014, 12:54 PM   #8 (permalink)
Member # 121245
here is mine with chassis 1.5" above the frame, wide corbeau seat, rear seat mt 1" above frame, front seat mt about 2.75-3" above frame, im 5-11"
Whiten is offline   Reply With Quote Quick reply to this message
