Build order? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-30-2010, 06:56 PM   #1 (permalink)
112
Member # 129989
Build order?
Hi, my name is JD. I have been a lurker for a while on the F- Toy forum. I just got my donor rig today and i'm looking forward to my build.
I have read many of the build threads. From those of you who have built a f-toy, what is the proper order? From start to finish? I want to avoid having to redo work that has already been done.
Anything you would have done differently?
Thanks ahead of time.
Flame on!
112 is offline   Reply With Quote Quick reply to this message
Old 10-30-2010, 08:34 PM   #2 (permalink)
Moderating Midget
wngrog's Avatar
Member # 1154
Send a message via AIM to wngrog
That's a great question actually.
Prep Frame
Get suspension in place *make roller*
Get drivetrain right
Weld on FToy
Wire/Plumb
Floors/Skins
Nolen Grogan
2016 4Runner TRD Pro
1998 Land Cruiser
1984 FJ-60
2013 RZR-XP4
USAF Veteran 1988-1998 GOD Bless America
wngrog is offline   Reply With Quote Quick reply to this message
Old 10-30-2010, 08:38 PM   #3 (permalink)
Bastardized's Avatar
Member # 28626
Send a message via Yahoo to Bastardized
Prep Frame
Weld on FToy
Wire/Plumb
Floors/Skins
even easier..... just buy Nolen's
Bastardized is offline   Reply With Quote Quick reply to this message
Old 10-30-2010, 09:53 PM   #4 (permalink)
Member # 75648
sweet! im on step 4.5!
sellout
TachedOutOffRoad is offline   Reply With Quote Quick reply to this message
Old 10-31-2010, 11:11 AM   #5 (permalink)
Not a Wenzelite
MT4Runner's Avatar
Member # 44480
And before you weld everything: cycle your suspension with only the main leaf in place, and make sure your front axle/assist ram don't hit your lower crank pulley or your lower coolant line. Ask me how I know.
Also check your rear driveline angle. If it's too steep, you need to consider a L52 (short) tranny, move your rear axle back, or lower the t-case.
MT4Runner is offline   Reply With Quote Quick reply to this message
Old 10-31-2010, 11:43 AM   #6 (permalink)
mtbrjon's Avatar
Member # 36007
Prep Frame
Tack on or mock up FToy
Mock up seats then adjust chassis height or notch fame to fit seats properly. Most builders don't leave enough head room, Ask me how I know. You need at least 4" between your helmeted head and the upper bars.
Wire/Plumb
Floors/Skins
Fixed it for ya.
"I wanna get me a truck and soop it up with some metal!" -Wingo
mtbrjon is offline   Reply With Quote Quick reply to this message
Old 10-31-2010, 05:54 PM   #7 (permalink)
112
Member # 129989
Thanks for all the info. Keep the tips coming.
Old 11-01-2010, 06:54 AM   #8 (permalink)
Not a Wenzelite
MT4Runner's Avatar
Member # 44480
Tack everything before you weld anything.
Put your seat mounts in double-shear and mount the seats with quick pins instead of bolts. Mount your harnesses with clips instead of bolts. During the build (and after), you will appreciate being able to pull and replace your seats in 3 minutes instead of 30.
Old 11-01-2010, 11:20 AM   #9 (permalink)
Member # 1663
If you put a floor in the rear, make sure you can remove the tcase. We had the floor in tight, and when we broke the rear output at a comp, we had to cut everything out to get the spare in. We are now very versed at changing a tcase. We can get it out and back in in under 45 min
maveric is offline   Reply With Quote Quick reply to this message
Old 11-01-2010, 02:53 PM   #10 (permalink)
Brian Ellinger's Avatar
Member # 1088
Prep Frame
Weld on FToy
Wire/Plumb
Floors/Skins
Interesting thought. We did:
-figure seat relative to chassis. Then chassis relative to frame.
-cut frame, clean up.
-place drivetrain, axles at full bump (no springs yet)
-adjust/ tweak from there.
We opted to place axles, with axles in place to keep tires out of the chassis tubes, that may of these rigs hit.
Now on FACEBOOK!
Thank you to our loyal customers!
Diamond Axle
Diamond axled buggies take 2 1st's, at Worlds WEROCK!!
Front Range Off-Road Fab with NEW forum!
NEW BUILD FTOY #44
Brian Ellinger is offline   Reply With Quote Quick reply to this message
Old 11-01-2010, 06:18 PM   #11 (permalink)
Moderating Midget
wngrog's Avatar
Member # 1154
It seems to me like all the numbers have been run on these things so if you are sticking with the "formula" then there should not be a big need to worry about the suspension hitting anything.
Of course, that is the salesman in me. I did not build mine, but from other rigs I have done, that is the order that we did them.
Nolen Grogan
1998 Land Cruiser
1984 FJ-60
2013 RZR-XP4
