Arb ???? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-11-2010, 05:40 PM   #1 (permalink)
ghettowheeler's Avatar
Member # 32191
Arb ????
Well last trip out on fordyce one of the bolts that holds the ring gear to the carrier shot out of my rear housing piercing the housing leaving a 14mm hexagon hole. I didn't realize this until I got home and unstrapped the rig off of the trailer. Pretty weird ha I have never heard of this happening. So I pulled the rear diff out to access the damage. All of the bolts on the ring gear were hand tight and one bolt was completely missing. Everything else looked ok so I got a new bolt and tightend everything up. After installing the diff into the housing and testing the ARB the locker is stuck on (engaged). I can't get the ARB to disengage. I can hear air coming out of the axle breather tube. My guess is the o rings went bad (dried up from no gear oil)Any tricks I can do without pulling it all apart again?
Team Ram Rod!
formula 4 32
THATS HOW I ROLL!!!!!!!
ghettowheeler is offline   Reply With Quote Quick reply to this message
Old 11-12-2010, 04:42 AM   #2 (permalink)
offroad_joe's Avatar
Member # 16829
Never had one stuck on. But after sitting for a while mine have had slite seal leaks from the seals drying out. I shoot a little WD40 in the inlet and work it a few times. Leaks always go away until it sits for a while again.
2014 Tin Bender Jambo November 15,2014
doesn't mean I can't be a douche bag
10-4, thanks for the Cliff's notes... I don't think I ever read the "bounty thread" so I was/am clueless on this. Sounds to me like camo is a HGTD douchebag though.
offroad_joe is offline   Reply With Quote Quick reply to this message
Old 11-12-2010, 06:58 AM   #3 (permalink)
Member # 66153
I had a bolt shoot out just like that. Welded the hole up cause at the time I thought it got tagged by a rock. But once I got home pulled the 3rd and was missing one of the bolts off the ring gear and most the others were loose like yours.
Just redid them with loctite and been ok since. No idea on the ARB
F-TOY #36
Ricks72ntx is offline   Reply With Quote Quick reply to this message
Old 11-12-2010, 07:59 AM   #4 (permalink)
Brian Ellinger's Avatar
Member # 1088
Tear it apart, replace the orings on the coupler. Really what needs to be done. However, I would tear the locker apart while youre in there, to find how its stuck engaged. Also while its apart, fine all the mating surfaces for the ring gear flange, as the holes will have pushed up burrs from the bolts banging around.
Now on FACEBOOK!
Thank you to our loyal customers!
Diamond Axle
Diamond axled buggies take 2 1st's, at Worlds WEROCK!!
Front Range Off-Road Fab with NEW forum!
NEW BUILD FTOY #44
Brian Ellinger is offline   Reply With Quote Quick reply to this message
Old 12-16-2010, 09:08 PM   #5 (permalink)
Member # 177252
Originally Posted by brian ellinger View Post
tear it apart, replace the orings on the coupler. Really what needs to be done. However, i would tear the locker apart while youre in there, to find how its stuck engaged. Also while its apart, fine all the mating surfaces for the ring gear flange, as the holes will have pushed up burrs from the bolts banging around.
x2
F-toyBuggyGuy is offline   Reply With Quote Quick reply to this message
