Battery location - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-24-2011, 07:08 PM   #1 (permalink)
Member # 98157
Battery location
I am just curious, were do most of you F-Toy builders like to install the battery, front, back, middle. I am pondering were to put my battery
Dennis Roby is offline   Reply With Quote Quick reply to this message
Old 01-24-2011, 07:17 PM   #2 (permalink)
Member # 78096
I did mine front passenger under the dash mounted sideways with terminals facing the cab.
Jeep07 is offline   Reply With Quote Quick reply to this message
Old 01-24-2011, 08:47 PM   #3 (permalink)
noob
Member # 66544
I have mine in the back, told myself it was for weight distribution
El Destructo! I void warranty's!!!
Team Rock Limo
F-Toy #F002
Yukon gear/Randy's Ring & Pinion, Trail Gear, BFGoodrich Tires, RuffStuff, 12 Volt Guy
noahfecks is offline   Reply With Quote Quick reply to this message
Old 01-24-2011, 09:45 PM   #4 (permalink)
a2b
a2b's Avatar
Member # 22547
i have had mine in 4 places.
1. a red top right behind passenger seat mounted at the lowest part of the frame rail to keep COG low. this worked well. it also had a skid plate underneath it.
2. a small batt right in front of the pass seat to make it accesseible to chargers.
but i found out that those small batteries really arent reliable in the long run with winching to be done.
3. same small batt underneath pass seat. this was super clean and it was out of the way, however, you had to take the pass seat out to get to the batt. PITA!
4. the final resting place, redtop, in the far back. easily removable and acsesible for charging.
-Hobie
GOTPROPANE.COM
HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER!
a2b is offline   Reply With Quote Quick reply to this message
Old 01-25-2011, 01:35 AM   #5 (permalink)
Member # 66153
I've got mine right behind my passenger seat
F-TOY #36
Ricks72ntx is offline   Reply With Quote Quick reply to this message
Old 01-25-2011, 08:22 AM   #6 (permalink)
Tech Editor
Air Ride's Avatar
Member # 1656
Behind the driver or passenger seat as low as possible.
camo is my hero, even if he is gay
Air Ride is offline   Reply With Quote Quick reply to this message
Old 01-25-2011, 08:41 AM   #7 (permalink)
Brian Ellinger's Avatar
Member # 1088
Far back, top of battery even with top of frame rail. Did it for weight distribution, and still 500# heavier in the front.
Now on FACEBOOK!
Thank you to our loyal customers!
Diamond Axle
Diamond axled buggies take 2 1st's, at Worlds WEROCK!!
Front Range Off-Road Fab with NEW forum!
NEW BUILD FTOY #44
Brian Ellinger is offline   Reply With Quote Quick reply to this message
Old 01-25-2011, 09:08 AM   #8 (permalink)
Member # 1663
Mounted directly above the rear axle. Mine is on top of the rails. And yes, it tends to tip over.
maveric is offline   Reply With Quote Quick reply to this message
Old 01-25-2011, 01:54 PM   #9 (permalink)
Member # 81153
Mine is tucked up under the dash where it is very hard to get to.
Nathan Unruh
Unruh Racing
Ultra 4 Car #4477
Formula Toy #063
Napolian is offline   Reply With Quote Quick reply to this message
Old 01-25-2011, 02:12 PM   #10 (permalink)
ghettowheeler's Avatar
Member # 32191
Here is mine during the build.
Team Ram Rod!
formula 4 32
THATS HOW I ROLL!!!!!!!
ghettowheeler is offline   Reply With Quote Quick reply to this message
