F-toy 131 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-28-2011, 06:04 PM   #1 (permalink)
Member # 166732
F-toy 131
I've been working on it since last August and have got it to the point where I am starting the engine wiring harness. I have searched and read all of izelos post. I talked with ORS about a harness but figured what do I have to loose trying to stip it myself first. It's a 87 motor and harness. Has anyone done this?
steelhead4life is offline   Reply With Quote Quick reply to this message
Old 04-29-2011, 07:10 AM   #2 (permalink)
Not a Wenzelite
MT4Runner's Avatar
Member # 44480
I bought a 22RE that had already been in a buggy, and I only had to do about 20% of the wiring to get the harness I wanted.
It's not impossible--I'd say it's a time vs. money thing. If you've got a lot of time, but need the money for other parts, then do it.
Steelhead---are you from the Idaho area?
MT4Runner is offline   Reply With Quote Quick reply to this message
Old 04-29-2011, 03:30 PM   #3 (permalink)
Member # 166732
Thanks for the info. I got most of it done up already. Down to a handfull of wires and the start and charging system. I don't think I'm going to use eather of the fuse blocks. I want to keep it as clean as I can. I'm hoping be able to have the EFI fun on a single relay and run some type of ANL fuses for the power. Am I way off or should I find room for the blocks. I kept the diag. connector inline with the harness already. I'll try and find time to post pictures. It's not much to look at for now.
I'm in Eastern Wa. Might have seen part of the build on NW-wheelers.
Old 04-29-2011, 08:57 PM   #4 (permalink)
Not a Wenzelite
MT4Runner's Avatar
Member # 44480
Good--diagnostic connector is the one piece I skipped, and I need to go back and put it back in.
Make sure you put in some sort of incandescent/resistive load in for the CEL and charge light. The ECU needs to see a resistive load there. I haven't been on Crash's site for awhile, but I'll get on there and check it out! Dan/notstock has told me about your area--I need to get over there and check it out sometime.
Old 04-30-2011, 01:12 PM   #5 (permalink)
Member # 37213
the best way to do it is start at the computer and work your way out
ill share some crap from my local board that really helped me along the way
Here's my notes.
EO1 brown wire -- ground
EO2 brown wire -- ground
#10 wht/red -- injectors
#20 white -- injectors
STA black -- neutral start switch
IGT blk/wht -- ignitor
#1 grn/wht -- cold start injector
E1 brown -- ground
NSW green -- not sure what this is for
EPU -- this one is not shown coming out of the ecu. It may not have a wire there.
APU -- same as EPU
W violet -- this is the negative for the check engine light
#4 blue/red -- to VSV. You won't have to touch it
T grn/ylw -- check connector
#5 grn/blk -- HAC sensor
IDL blk/wht -- TPS
#6 grn/ylw -- O2 sensor
IGF blk/ylw -- ignitor
E2 brwn/blk -- AFM
#2 Blue/wht -- VSV
OX black -- O2 sensor
#3 -- same as APU and EPU
VCC white -- TPS and HAC sensors
KNK black -- knock sensor
VTA blue -- TPS
NE blk/red -- ignitor
THW green -- water thermo sensor
L3 ylw/blk -- ECT computer
ECT ylw/grn -- ECT computer
L1 red/wht -- ECT computer
L2 ylw/red -- ECT computer
VC blue/red -- AFM
#7 red/ylw -- 4wd indicator
VS ylw/blue -- AFM
THA yellow -- AFM
SPD grn/blue -- speed sensor
BATT wht/blue -- EFI fuse
B/K grn/wht -- from stop light switch. Any constant power will do
B1 black -- EFI main relay
B black -- EFI main relay
Toyota with Stickies, links, beverage holder and other accessories
metchosin joe is offline   Reply With Quote Quick reply to this message
Old 05-07-2011, 12:06 AM   #6 (permalink)
Member # 166732
Thank you. I know you didn't do that in 10 min. My job has me out of town during the week so I'm hoping to finish up the wiring this weekend.
What amp rating is the main efi relay? I decided to use a Maxi-fuse block instead and the next step is wiring the main efi relay and the charging system.
Old 05-09-2011, 11:03 AM   #7 (permalink)
Member # 37213
for my set up im running 15 amp fuses for the computer and fuel pump
