Joel's multipurpose 40 on 41s - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-16-2017, 08:43 PM   #101 (permalink)
Member # 5326
I started using 36 grit sanding discs on a 2" roll-loc disc. That blasts off mill scale quick. Try and keep the disc flat so the edge doesn't wear out too fast.
They are pretty cheap and quick.
For cleaning up cold finish stuff or tube I use the coarse (brown) scotchbrite pads.
Old 07-23-2017, 11:15 PM   #102 (permalink)
Member # 171591
New job lined up (yay!) so I've been trying to knock out as much on the FJ40 as I can before time gets constrained again.
Structure is getting close but some things just take time. Case in point: my front shock towers.
I was worried about cracking through the narrow cross section at the front of the mount point. It has a nasty stress riser that was just begging to break here. Check this one!
So I welded on it a bit.
Better but the sides being open aren't doing much for me. I can see what some folks just do hoops with tabs hanging off the bottom. That wouldn't clear my hood and this was 3/4 done so I decided to work with what was there.
Started with some random bent scrap I had leftover from something or other. Pretty much using 0.120" wall on everything here.
It wasn't quite long enough so the top is made from three pieces. Side started.
Liberal use of paper doll studies like usual.
It's not quite perfectly symmetrical (gotta fit around the bits I have) but having one side done makes the other a heck of a lot easier.
Liking the fit of that...
Did some welding myself as I figured I couldn't let Steve have all the fun. Note to self. If you're welding both sides do the inside first. My pretty welds became a bit less so after I did the inside second. Live and learn ehh?
Fast forward a couple weeks and I had Steve drop by to burn in the real version.
Oh and I already had some gussets in the back that used pencil rod as trim. Figured it'd be nice to mimic that detail and it'll keep me from cutting open my forearms when working in the bay, so I added pencil rod down both sides. And shock towers done.
Well 99% anyways. I'd still like to put in one more support aft of this assembly, but that'll depend on headers and I need to get the engine back in the bay first to check.
-Joel
Structure piece count (this round): +26 pieces
Net added to date: +57 pieces
https://www.pirate4x4.com/forum/toyota-land-cruiser/2192889-joels-multipurpose-40-41s.html
frjiolee is offline   Reply With Quote Quick reply to this message
Old 07-24-2017, 07:58 PM   #103 (permalink)
Member # 171591
More welding...
We burned in the motor mounts all the way. I made gussets for shear support on the top surfaces.
Welded.
So while Steve got into his work (bah dun dun), I played lackey and passed him stuff, including spare MIG gloves because the frame rails got mighty toasty at the mounts we just gusseted.
I also whipped out a quick plate to support my winch fairlead. I was sorely tempted to make this out of carbon, but since I'd still need brackets and bolts to mount a carbon panel, simple functionality won out. I suppose I could still skin it in carbon if I want to, but it feels kinda half-assed to add pure decoration without purpose. This is only 0.060 or so it's not that heavy.
We got that burned in too.
That's pretty much it for the engine bay for now.
I'm excited because this means I finally get to drop the motor back in so I can get moving on pedals, steering, intake and exhaust. With the new job lined up I decided it was ok to start spending money again and bought a bunch more of the little stuff I'll need going forward.
-Joel
Structure piece count (this round): +5 pieces
Net added to date: +62 pieces
Old 07-25-2017, 12:49 PM   #104 (permalink)
Member # 171591
More welding yet...
I had formed up some door bars a while back but wanted to check fit vs doors to be sure I wasn't blocking hardware or anything before I welded them in. Did the check. What do you know I'm blocking hardware, specifically the door latch and handle. *sigh*
I can't get an exact fitment because I still need to cut down my doors. The body has been shortened by 3" which does wonders for the overall proportions of the rig, but does come with a great deal of extra work. I just mocked it in place based on the upper hinge.
I literally couldn't have hit this any worse. The handle pretty much lines up with the bar perfectly.
After starring at it for a while. Trying to see what it would take to bias the bar up or down I just wasn't happy. I could add a bend but that's a PITA since I don't have easy access to bender anymore. Plus I like straight lines direct to nodes... Eventually I decide F--- it. I'm putting the bar where I want it (albeit biased as far to the inside as I can manage) and I'll rework the door handle as needed.
It still took some creative welding to get down around the junction at the rocker. Not perfect coverage when using stupid electrode stick-out (gas lens can only do so much) but it's not going anywhere.
But this next picture makes it so worthwhile... Now that's some proper triangulation! Note the added rear shock bars down the bumper/frame junction as well.
I also don't have access to the bad ass tube notcher I was using before so I got to do these with the chop saw method (well, band saw in my case). For a 1.75 to 1.75 tubing coping the base angle you need is 28 degrees. Effectively if you cut at 28 degrees off from straight on each side that's pretty close to the correct coping for a 90, then you add and subtract from each side cut for whatever angle you really need. There's more description here plus base angles for various tube sizes: https://www.pirate4x4.com/forum/shop-...-pictures.html
My favorite tip from the above thread was just to use old toilet paper rolls to figure out what you needed then trace it over your actual tube. That works like a charm, and I wish I would have figured that out sooner.
Unfortunately, I did give myself one more headache to deal with. Rear seat is not so happy with the last bit of structure added. Scratch fab = making problems, then solving them.
It's close so I think it's solvable, just one more thing to do.
-Joel
Structure count +4 pieces this round
Total added to date: +66 pieces
Old 07-26-2017, 09:40 PM   #105 (permalink)
Member # 171591
Modding by the "seat" of my pants (sorry couldn't help it).
I decided to stop being a wuss and figure out what it would take to modify my rear seat to fit. I did a great deal of looking before I picked this one (Bestop Trailmax II for a CJ) and it's about as narrow of a bench as they come. Custom = $$$, so let's see what this thing is made of.
With the back pulled off, I thought I had pretty good odds of clearing the new bars.
So I sucked it up and started cutting out the hog's rings. Likely one more tool to pick up but I need to see if [member=83]65imp[/member] has a set I can borrow before I do. The stock CJ style rear feet are coming off too.
Dang there's a bunch of these things. Took many more pics so I can reassemble as intended, but this gives the idea.
For the back rest to land properly I had to get the seat further forward. This was the critical notch. I'll patch it later.
Ended up taking a scootsch off the riser parts as well.
But mocked in place I'm still stoked. Actually places the back seat better than it was before. I fit back there (barely) which is perfect as anyone bigger than me would be driving or in shotgun. Wife and girls are much smaller.
And kid approved, just to be sure.
More to come...
-Joel
Old 07-28-2017, 11:07 AM   #106 (permalink)
Member # 171591
To try to stay ahead of Steve, I've been building as much as I could just about anywhere on the vehicle that I know shouldn't be changing...
Random little one: tailgate closeout.
I built some perimeter flanges to give my panel something to bolt to and carry shear.
I may not skin the inside so I thought the flanges looked kind boring and were heavier than needed (wanted some strength for shear but areas between bolts weren't doing much)
So I got a little creative with the plasma cutter and scalloped them all.
Smooth it out on the belt sander (seriously, buy yourself a big combo belt/disc sander, I use this constantly). Fun fact: slag from plasma cutting throws way more sparks than the base metal does. It's kinda weird.
Pro tip regarding stitch welding (segmented welding if you prefer the proper term): Sharpie your pattern in place. Tack whatever you're welding at the end of each stitch, then you start on the opposite end and weld until you hit the tack. Steve's either a damn clever dude or has just been doing this a while. Can't believe I never thought of that. Also FYI if you ever see a segmented weld on a drawing they should be called out as length of each weld followed by spacing of the weld centerlines. So a 1-2 weld is one on, one off (not one on, two off).
Turned out pretty nice and saved about 1/2 a lb.
Why is it important to take off mill scale? It melts at a much higher temperature than steel so when you weld on it, it pretty much guarantees you an undercut. Check out the one spot I missed on the perimeter flanging. Compare the vertical and horizontal welds below... Same guy same machine setup.
While I was busy scalloping flanges, I also carved up my motor mounts. Before:
After:
I already pulled about a lb a piece out of these guys. I'm still debating cutting these down to only 4 bolts, but since it's offroad and loads can be violent, I figured a little extra load sharing won't hurt me, hence the finger I left on each.
-Joel
Structure part count +6 pieces this round
Net added to date +72 pieces
Old 07-28-2017, 10:54 PM   #107 (permalink)
Member # 171591
Seat mounting is making progress but I'm not 100% happy with it.
Fronts first...
I'm still trying to package the biggest 3" mufflers I can manage in the boat sides. That worked out to be a magnaflow 18x6" can. It's tight but it almost worked as is.
It's getting mighty close toward the back edge though, I only have the muffler shimmed up with a heavy larger of cardboard on each side as shown. I wanted more space so I segmented the mount on each fore/aft leg and suddenly it was a great deal happier. I still need to package some serious heat shield under here and I'm only going to have about 3/8" to do so. I'm also either going to have to clearance that main cross bar or shove a fast turndown in there to clear it.
Figuring out I could make the above cuts was all based upon a pretty nice find. The aft mount point for the front seats to the frame were only welded on the rear edge. That made it pretty simple to chisel them up into a slight angle and it left a heck of a lot less to redo.
Happened to notice that front cross bar of this seat structure had some healthy weld deformation in it. More than I could take out by hand so I rigged up some support and cold formed it with my jeep.
Much better.
And burned in.
So the fronts are in good shape. If anyone knows of a really bad ass heat insulation product I'm all ears.
The rears are giving me a debate though...
Front mounts for rear seats will be fine. Have a strategy there. The aft mount needs to serve as both a riser and let me bolt in a lap belt interface point, likely from the side. Issue is that I also have a big ass notch in my frame for shock clearance.
I was thinking I'd kill two birds with one stone and make a big doubler to go on top. This is 1x3 0.120 wall.
Good news is that it's the right height, should be plenty for both mounting seat to and a lap belt interface. Downside, it's heavy about 4 lbs per side, which for whatever reason gives me heartburn here since it's seems like a really inefficient support. I also can't guarantee it'll clear the shock at full flex. However if I bias it toward the inside I'm giving up room for my fuel cell and I'm not even really sure it's needed. Now that I have the rear angle tubes in, I'm struggling to picture a load path where this fails. Maybe it'd buckle in a bad rear end collision... Not sure.
I think I just need to suck it up, do the flex check, and fight for full height (not trivial). Then suck it up again and say I'd feel incredibly dumb if someday somehow I managed to have an issue at an intentional weak spot in my frame. Suck it up enough to run about 6 lbs of insurance vs. a lighter mount.
Thoughts?
-Joel
Old 07-29-2017, 09:10 AM   #108 (permalink)
RickyB's Avatar
Member # 26835
Looking great! In the overall scheme of things, whats another 4 pounds if it saves the frame... and the kids..
79 FJ40 in lots o pieces - Sold
'77 FJ40.5
RickyB is offline   Reply With Quote Quick reply to this message
Old 07-30-2017, 03:42 AM   #109 (permalink)
Random Dude
Member # 467273
Originally Posted by frjiolee View Post
This is as good a chance as any to ask how folks are best breaking up mill scale. Wire wheels seem to work well but they're still pretty time consuming.
I'm not good enough to get consistent welds with the scale still on it and I do have a great of tabs and brackets coming up in my future fairly soon.
As always comments appreciated.
-Joel
IMHO, a stripping disc is THE way to strip mill scale (unless you sandblast).
EDIT: also, this build is looking great. Thanks for taking the time to share it.
PLEASE BUY AMERICAN SO I DON'T HAVE TO LEARN CHINESE
- The 4th little pig built his house of reinforced concrete, with wolfskin rugs in every room -
<-- Random crap you might find useful
ExWrench is offline   Reply With Quote Quick reply to this message
Old 08-02-2017, 10:53 PM   #110 (permalink)
Member # 171591
Thanks for the review. I looked at a few recommendations and decided to try the stripper discs... 10 pack inbound from Amazon.
In the meantime:
Floorboard risers/support structure...
Finished a big piece of what I needed to run the exhaust in the boat sides plus give my floorboards something to bolt to.
This was a piece of 1x3 I ripped in half. Bit of trimming and welding at the ends.
Developed a bit of an arc after it's trip down the bandsaw but nothing a clamp couldn't solve.
Burned in a bunch of weld nuts prior to welding to the rig. Weird watching them smoke when welding adjacently.
Need some side supports at the rockers but it's a great deal closer. Side weld nuts will be used for fuel, brakes, and/or wiring harness runs depending what I end up packaging where.
Structure count +4 pieces this round (not counting inserts since I just welded them w/ mods)
Total structure +76 pieces
Old 08-05-2017, 07:21 PM   #111 (permalink)
rockthedog's Avatar
Member # 19510
More to come...
-Joel
Outstanding work! Can't wait to see it running. Curious , is the diagonal support off the b pillar going to clear your head ?
77fj40, 1 TON
530-268-9494
tlca# 12281
semi_budget 1ton build
linking the rear
rockthedog is offline   Reply With Quote Quick reply to this message
Old 08-06-2017, 03:06 PM   #112 (permalink)
Member # 171591
Should be OK, it's further outboard than it looks in some of these shots. It's probably a bigger risk for the kids being thrown forward if they weren't well buckled in. Either way I have quite a bit of roll bar padding in my future.
Old 08-06-2017, 03:07 PM   #113 (permalink)
Member # 171591
Getting close to the end of the structural tube work, just a few more things to do.
I was kind of proud of this round though... In the MillenWorks shutdown I brought home a couple weird looking multi bend pieces that I figured I could find some sort of use for.
Figured out ways to get 6 pieces (thus far) out of these two bits. I'm also getting better at tube notching via hole saw. I found it's easiest for me to eyeball tangency and go back to mark the deepest point of the cut.
Then I ADD two cut marks to make the side of the fish mount at relative angles to my first line. This way my base angle is always whatever it was I needed and I don't have to do relative math. For two tubes of the same size, it's just 28 degrees each way of added material on each side of my cut. Case in point:
The above fit was done with no trimming.
And now I have a solid grab point on either side of my dash structure kinda like a curved pistol grip on both sides. I got the idea from the Can Am side-by-sides, which use vertical handles as their grab points.
Added oh crap handles on the A-pillar the same way. These flair inward to avoid the doors. In both cases I did some test fitting (not shown), so I think they'll be good.
Next up, I've been working on harness mounting. I'm basing much of the design on Billavista's excellent off road tech series. In this case, these articles:
- BillaVista.com-Driver Restraint Systems Tech Article by BillaVista
- BillaVista.com-Driver Restraint System Installation Tech Article by BillaVista
I actually really like the sewn on style harnesses Bill reviewed as well.
- Pro Armor Harnesses Tech Article by BillaVista
Anyways, I added a bit of hardware, specific to harnesses. Both front and rear are a challenge to position perfectly so I'll be using double sheer brackets for the attachments and to get things perfect. Rear should harnesses use a cross bar in between the C-pillar nodes. I should be just below the rear wind hatch if I measured correctly.
Front shoulder harnesses use this protrusion from the shock node.
Barring rear seat mounting stuff, I think the rear is ready for a fuel tank, floorboards, and body close outs.
Progress!
-Joel
+7 pieces this round
+83 pieces total
Old 08-23-2017, 11:22 PM   #114 (permalink)
Member # 171591
Kind of a random post... One of the things I inherited from the MillenWorks closure is this bitching wood plaque commemorating Rod Millen's custom Land Cruiser creation as documented in Four Wheeler magazine.
I know there have been various pictures of this rig floating around the internet for a while.
If anyone knows the present owner, I'd love to offer this to them. If I'm not successful in finding that, let me know if you're interested and make me an offer. It's way cool but I don't have a good place to put it.
Old 09-24-2017, 11:33 PM   #115 (permalink)
Member # 171591
First of several updates that have been done for a while but not documented... I finally even got to start screwing with carbon fiber. More on that in a second.
Rear seat is getting close. Remember that odd ball bend I reference a while back?
Got a couple more pieces out of it. Turned out the bit I had left was about right for the forward shift I needed for the rear seat.
Burned in a couple patch panels on the side where I clearanced it prior.
Once I'd added a couple kickers to the frame and shaved down flange nuts welded into the ends, this was pretty damn stout.
The seat frame had some side plugs welded in where I'd cut it . Added couple more at the rear seat uprights just to tidy things up a bit.
Part of the trick in getting the rear seat to land right was planning the rear footwell. I ended up having it slope upward slightly which seemed the most comfortable against my toes and I'm kind figuring I'm a decent size model for the back seat. If you're bigger than me, you're calling shotgun.
I've been working on a shed I've been cutting up from a giant metal tradeshow backdrop (inherited from my former company now defunct). One bonus is that I ended up cutting off maybe 30 or so premade metal tabs. I have a feeling these suckers are going to be useful all over the place.
I debated tabs vs. strips like I did on the rear tailgate ares (however that one will show and it's intended as a shear panel), this isn't so I stuck with tabs for simplicity. They are a touch harder to line up this way but I got to play with a cool tool I picked up a while back that helped with that. "Stronghand MagTab:. It's cheap at only $15 or something and works really well.
So the carbon fiber. Why carbon fiber? Well why not? It's light, stiff, looks bitching and contrary to the big downside for most folks, mine was free. This panel is a 5 mm thick with a 2 mm core (sandwhich construction).
Other dowsides? Well I probably won't use it directly over the fuel tank (the resin can burn making for a lousy firewall). Hit it hard enough and you can fragment the stuff. I do have a ways to go before I'm thinking bout driveshaft loops, assuming that's even possible with higher travel. Funny one, with carbon you have to be careful with your choices on nuts and bolts. You can run into galvanic corrosion using it, because of the high... wait for it... carbon content. I'm not planning on going mudding with this.
Anyways. I have a floorboard.
Almost (needs bolts) and a rear seat (almost, needs rear mounts). Whatever, it's progress and progress is good.
Structure count +17 pieces this round (tabs count since I had to modify them)
Net parts added to date +100 pieces
Old 10-14-2017, 09:59 AM   #116 (permalink)
Member # 171591
Took the XJ out last week and had a blast... Random pic from the adventure hoping to light a fire under my ass to keep moving on this one.
Old 10-14-2017, 03:58 PM   #117 (permalink)
Member # 790033
Awesome.
Cledizzle is offline   Reply With Quote Quick reply to this message
Old 10-22-2017, 12:44 AM   #118 (permalink)
Member # 171591
Time to get the FJ's engine ready to go in.
Reminder: base specs:
LS3 Block stroked to 416
10:1 Compression
Callie's Compstar 4" Crank
Callie's Compstar H-Beam Rods
Wiseco Pistons
ARP Main Studs
CCP Stage 4 Blower Cam (240/254 .613/.596 115)
Roll master double timing set
Melling 10296 Oil Pump
L92 Rockers with BTR Trunion Kit
LS7 Lifters
Ported L92 Heads
Manley Stainless Valves
Manly Pushrods
PAC Springs with Titanium Retainers
ARP Head Studs
LS9 Head Gaskets
24x Reluctor 1x Cam Gear
Biggest change needed was swapping out the cam. What the engine came with was too big for off road use (at least assuming I wanted to crawl as well as throw sand). I also wanted to inspect what I could and make sure things were healthy inside.
Started by pulling valley covers. No surprised here. The valve train install appears to be fresh (note the grease on the tips).
ARP head studs peaking out. Thus far the engine has had everything it was supposed to.
Cam it came with looks nice perfect peaking through windows.
LS6 style PCV system confirmed.
I did check what would be involved in making hooking up all 4 steam ports. On the LS3 intake it looked like more shaving than I wanted to do. It was no where close to landing.
I’m also not a fan of running little AN hoses on top of the intake since it always seemed like that would be a high spot to trap air anyways (maybe we don’t care if trapped air is up out of the way). At the end of the day I decided to keep it simple and run the 2 port steam tubes. I needed block off bits for the others and found that the aftermarket pieces are cheaper than OEM. This also probably saved me a few grams on my rock crawler build.
Still going to have to pull it apart for the cam, but no issues thus far.
Old 10-23-2017, 11:28 PM   #119 (permalink)
Member # 171591
So the cam that that this came with is too damn big and I need torque down low. I spent a great deal of time researching cams (dedicated chatter on that subject is over here: https://www.norotors.com/index.php?topic=21962.15)
As part of that I decided to check the port volumes. If you have a nicely graduated cylinder that would work well. I didn’t so I did all my checks with 91% isopropyl alcohol and measured by weight.
Thanks to Daniel (Mpbdy) for the recommendation. Since it was alcohol it made for easy evaporation and avoids rust. I’ve also heard of some folks using oil to be sure it can’t weep past the valves but that sounded like a mess.
Checked three ports for inlet and three for exhaust.
No real magic to this other than making sure you’ve turned over the crank enough that you’re 100% sure the valve is closed. Take weights before and after.
Stole a nose snarffler from my daughters to help pull the liquid when complete.
Results indicate a pretty big port.
Note the math above is wrong. Turns out the 0.786 g/cm^3 density I found is already for 91% isopropal. That makes my final ports sizes 282 cc for intake and 96 cc exhaust (not 257 cc and 87 cc as shown on my sheet above)
One oddity I ran across. I had a moment of panic cleaning out the intake ports and I found that the port had broken through the casting wall. WTF? You can just see it peaking out around the corner.
Pulled the valve covers back off to try to figure out where and figured out it’s the void beyond the tip of the rocker bolt.
I debated trying to smooth or plug this somehow (JB weld maybe?), but I didn’t want to run the risk of it coming loose and getting a slug of hard epoxy down the intake.
After a bit of looking online, I finally figured out that almost all LS3 head ports do this. There’s apparently a bump intended to keep the hole blind that protrudes into the intake port. If you want to smooth out the passage this bump gets carved off. More details in this thread…
https://ls1tech.com/forums/generatio...bolt-area.html
So what folks really do it put some thread sealer on the rocker bolt to be sure it can’t be a leak path or a means of oil consumption. Given there’s not much discussion on what type of thread sealer I ended up using Teflon paste (aka plumber’s pipe dope).
Last test before ordering a cam… I tried to borrow a spring force gauge, but it wasn’t compatible with LS style heads.
I figure there’s been enough attention to detail in this engine assembly thus far that so long as I go milder than the cam the engine came with (both lift and duration), I should be fine. That’s not a tough hurdle to clear.
-Joel
Old 10-25-2017, 12:46 AM   #120 (permalink)
Member # 171591
With the port data in hand I wanted to close the loop on a cam. Decided to pull the trigger on a paid recommendation from Cam Motion. The deal is $30 for the service, but if you buy a cam from them it goes toward the cost of the cam.
What they came back with was damn close to what I’d been circling the drain on, and I’d had good success with Cam Motion lobes on a few Futral cams in the past.
Final specs 218/226 .595"/.587" 114+4 LSA, 110 ICL:
I was amazed how quickly this came in. They turn these around in like 3-4 days. Bad ass. So armed with one full open evening after work I launch into my cam install. Pulled all the rockers and pushrods.
Opened up the front end, I found the first of two issues by whoever build this engine: Oil pump wasn’t torqued. (Note the rattling washer, all were only finger tight).
Not a huge deal but a good reminder of the importance of due diligence. I would have checked this regardless of a cam swap, but the cam was a good excuse.
The timing chain has a bit of play. I looked it up found several dozen folks asking the same question (there’s no specs on chain slop in my FSM either). I did find that some versions of LS motor used a timing chain guide, however I don’t think those are intended for a double roller so again, calling this OK.
I love installing cams on an engine stand because it’s so damn easy to just flip the thing upside down and now the lifters won’t collapse into the cam void.
Bearings look fine.
Big difference in duration (new on left, what came with motor on right)
New cam in the hole. Assembly lube utilized.
Go to reinstall the cam retainer plate, and I find a second issue. The engine builder used flange head nuts where this version of the retainer plate is supposed to be flat head torque bolts.
Suck… I have this engine well apart. Rockers and pushrods are already pulled, bottom end is open, basically 99% of the sensitive bits exposed. Spend some time debating whether I can I run it with only 0.020” engagement on a non standard bolt? They’re still 10.9 so decent stuff but can I live with myself fudging it?…
Answer: Nope, just not comfortable and that’s an unacceptable place to be when assembling an engine. Nothing to be done but suck it up and find the right bolts.
Sooooooo, I break out the syran wrap and get busy. I have just about all the sensitive bits of the engine exposed top, front, and bottom. Wrap the engine, wrap the front cover, wrap the valve covers, wrap the oil pump, wrap the tray full of rockers/pushroods. Bag up and label all the hardware. Sometimes car projects really are two steps forward one step back.
That’s life sometimes…
-Joel
PS a quasi local dealership had the bolts so thankfully I only lost a few days, not a week like I had feared.
Old 10-31-2017, 10:44 AM   #121 (permalink)
Member # 171591
The tensioner thing came in two versions and was pointed out on another forum so I actually already second guessed myself and decided to add an LS2 piece.
LS2 is really a damper (not a tensioner) and runs inside the chain only.
LS3 serves more like a proper tensioner.
LS3 style will not work with a double roller chain. Some folks have had failures with them as well..
LS2 timing chain Damper or tensioner? - LS1TECH - Camaro and Firebird Forum Discussion
LS2 version ordered. Sucks to redo stuff but I do still have pretty decent access on the engine stand and I don't want to be second guessing myself. FWIW gm parts direct has an offer going for 5% off. It was "MINUS5" if anyone wants to try for something else".
Old 10-31-2017, 10:46 AM   #122 (permalink)
Newbie
Member # 134699
Had good experience with the LS2 timing setup in 3 builds. I think thatíll suit just fine. Great progress, keep up the good work.
rooster18 is offline   Reply With Quote Quick reply to this message
Old 10-31-2017, 10:51 AM   #123 (permalink)
Member # 171591
I need to do a bit of catching up. Part of the reason why I love the forum is the chatter and sounding board services you guys offer. The LS2 vs. LS3 damper thing is a great example. I just wish I hadn’t put so much stuff back together already. Home sick today, but the wife is worse so this got typed up from an urgent care while she gets checked for strep throat.
Where we left off the actual engine build, I decided I couldn’t live with myself running the wrong bolts on the cam retainer plate. After a bit of hunting around I confirmed a local dealership had them in stock.
$19 in bolts later I was back in business.
One interesting detail, I’ve never seen a slotted countersunk hole before. GM was apparently looking at some pretty nutty tolerance stack ups.
I was going to port the oil pump since there’s a touch of flashing on the inside edge.
However, one of Melling’s bolts just started to strip when I went to open up the second one (I can feel/see it start to give without breaking loose), so I aborted and decided to leave it alone. A fractional percentage of oil flow improvement vs. risk of jacking up and/or fighting the pump for days wasn’t worth it the risk.
I did replace the crankshaft seals in both the front and rear covers.
Rear cover is a bit of a paint to get off while on an engine stand. I managed but it wasn’t fun. Specs claim the cover should sit flush to 0.02” (0.5 mm) above the block surface (below in my case since I’m working upside down).
I figured the seal would find a happy place on the crank so I installed with slight upward pressure on the cover to get things damn close to flush.
On the front cover the process is the same except I installed the harmonic balancer first (cover in place but all bolts loose to be sure the seal would be centered.
There are special tools for this but I don’t see a need.
Damper comes nicely packaged, but you get to assemble it yourself.
Borrowed the special balancer install tool from 65imp. These are handy enough I’d own one if Mike wasn’t so close, so much better than trying to get it far enough on for a stock bolt to grab.
You do have to be sure the pulley slides into the seal nicely when doing it this way as with the cover loose there’s no guarantee it’ll line up.
Ok, that’s about it for the front and rear of the long block.
-Joel
Old 10-31-2017, 10:53 AM   #124 (permalink)
Member # 171591
Moving down to the bottom of the engine.
Bores look perfect on all cylinders. No funny journal play on any rods. Just bitching forged yumminess that all looks perfect.
Rods have numbers hand etched in each, no something I’ve seen before but at least it’s in a low stress spot so it should be fine.
Happy to confirm the 24x crank encoder wheel. That makes life, drive by cable a bit easier. I’ll be running a 99+ f-body harness and ECU to control this.
I bought some plasti-gage to check bearings and the like, but ended up not doing it. Seeing the fresh install of the pushrods me left feeling loathe to tear apart the con rods. Given what I’ve seen to date the odds of finding something so egregious I’d want to rebuilt this with new bearings seems like really low odds. I did put a torque wrench on them set to about 80% of rated (specs I found for the rod bolts were either 40 or 45 ft lbs. and I checked at 35). Nothing budged so I’m 90% decided to leave it alone. If you think I’m an idiot and I need to suck it up, feel free to voice your thoughts as to why.
I did have some work to do on my windage tray. 1) hardware on a 98 ls1 mains are smaller than this engine—though, to be fair I don’t know if that’s an LS3 thing or a 416 stroker thing since much of my hardware isn’t stock anymore.
Either way, I needed to open up the holes in the windage tray and that’s how I gashed my thumb a while back. Drill caught and spun the whole thing around a while back. Thought a good grip was enough. It wasn’t. Ouchie.
Once I got the windage tray to land over the studs I discovered the long stroke was causing an interference to the tray.
That means I either need to space it downward or I need to buy a long stroke windage tray. They do sell those.
https://ls1tech.com/forums/generatio...dage-tray.html
For the 4.000" stroke windage tray: 19244049
For the 4.125" stroke windage tray: 19202609
For the 4.200" stroke windage tray: 19244051
The problem with a long stroke windage tray is that the recessed mounting points to interface to studs. That’s not going to work with my oil pickup tube, which naturally goes with the Kevco oil pan that the structure of my engine bay was designed around… Well that sucks. Looks like I need to figure out a way to use what I have. I can get close with a few heavy washers, but that leaves me pretty short on the stud for the thickness of a heavy washer, windage tray, pickup mounting tab, AND flange nut. Debated whether I should just suck it up and notch the windage tray for this one position. Maybe treating this like a jam nut and only letting half the threads engage isn’t the end of the world either.
I also didn’t have the OEM deformed metal lock nuts for this size, I wasn’t sure this was an OEM size, and I wasn’t that sure the deformed metal would engage anyways. Since these aren’t doing much of anything structurally I went and found some ARP “all metal” locking nuts that came in a perfect 10 pack.
Downside is that the “locking” on these is just some teeth on the inside of the flange not actually a deformed thread nut like I hoped. Kinda lame.
There’s another challenge: the oil pickup mount tab doesn’t quite land on the stud either since the oil pump is spaced forward slightly to account for the double roller timing chain.
Note the oil pump spacers in the second pic above. It’s probably only 0.100” or so but shifting the pickup didn’t work out plug and play in my case.
I debated cutting and welding the tab, but I was concerned it might not land at a good angle and this metal is oily. Looked like I’d have just enough metal so I used a burr to open up the slot. It worked out.
-Joel
Old 10-31-2017, 10:53 AM   #125 (permalink)
Member # 171591
With the addition of some heavy washers as spacers everything cleared the windage tray.
But if I biased the windage tray all the way against the studs the wrong way I could JUST have contact. That seems damn tight and so I dimpled the pan at key locations to gain another 1/16” or so, then biased the tray install in the happy direction.
Added another dimple where the pickup crosses over the bottom. Measurement leave the pickup sucking from maybe 5/16 ” off the pan which looks good to me.
New oil pan gasket, with RTV in the corners per FSM specs.
As I think about it, the one piece I’m still not happy with is the damn windage tray nuts, specifically the one supporting the pickup tube. I was able to torque it fine and it does have teeth to engage the metal, however, if that ever loosened up it seems like the pickup could droop, maybe touch the bottom of the pan and maybe cause an oil issue.
I’m probably overthinking this, but with engines I don’t want to screw around. In the LS1 tech thread above several folks talk about spacing the tray downward which would prevent engagement of a deformed metal nut even if I had one. It almost seems like I’d need to get the deformed metal version then shave a nut down to something approaching a jam nut.
Not shown: Pulled off all the syran wrap, pan installed and torqued. Pushrods and rockers back in their homes (specific rocker bolts with pipe dope as mentioned earlier), valve covers on, and everything torqued.
Next up: engine accessories.
-Joel
Still need to do my pushrod and valve spring verification, but since that’s all topside work I buttoned up a bunch of stuff, (which naturally some of the helpful suggestions mean I’ll end up redo’ing. I’d still rather have this be as solid as I can get it.
