Cruiser for sale - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-11-2015, 09:10 AM   #1 (permalink)
Member # 178404
Cruiser for sale
SOLD!
It is with mixed emotions that I'm posting my Cruiser for sale. I want to move on to a new project, but can't without first opening up garage space.
Asking 14k obo
Located in Rochester, NY
Titled as a 1978 FJ40
Body
- 1977 tub with both driver and passenger floor pans replaced
- Rust free tub, fenders, hood and bib
Drivetrain
- Replacement “2F” sourced form CruiserParts.net (’77 block with a ’74 head)
- All new engine gaskets, water pump, oil pump, headers
- GotPropane fuel system
- SM465 4sp transmission w/ granny first gear (full professional rebuild spring ’15)
- Dana 300 transfer case (Novak adapter and 10sp input shaft, JB Conversions 4:1 low gears, JB Custom Fab twin sticks, Advance Adapters HD 32sp rear output, Parts Mike transfer case e-brake kit, 1310 front yoke, 1350 rear flange)
- 10sp GM clutch
- Resurfaced factory flywheel
- New Aisin pressure plate
- New Toyota TO bearing
- New fan clutch
Axles
Front
- Cut and turned FJ60 housing
- RCV 30sp chromo shafts with hub gears
- ARP hub and knuckle studs
- 4x4 Labs high steer arms, tie rod and drag link with 1-ton TRE’s
- 4.10 gears with Aussie Locker
- Aisin lock-outs
- Disc brakes with G&J Aircraft nylon coated stainless steel soft lines
- Tom Woods long-slip shaft
Rear
- GM 14bolt
- Solid 6 lug hubs (narrows WMS to ~62”)
- 4.10 gears with Yukon full spool
- Partial shave with Barnes 4WD 13-bolt diff cover
- GM ton brakes
- Carolina Driveline 1350 CV shaft
Suspension
- Hybrid FJ55 front leaf packs in the front with 14” Bilstein shocks
- Rear double triangulated 4-link using Jeep TJ front coils with 12” Bilstein shocks
- TMR Customs 14bolt truss with pinion guard
- 2” sq., 0.25” wall lower links with Ruff Stuff heims
- 1.5” sq., .120” wall upper links with Ruff Stuff heims
- 108” wheelbase (front axle pushed forward ~5.5”, rear axle pushed back ~12.5”)
Electrical
- E-Z Wire 10 circuit wiring harness
- Roundeyes headlights
- LED tails (running lights, brake lights, and turn signals)
- Front amber turn signals
- Autometer gauges (water temp, oil pressure and voltage)
- Tiny Tach tachometer
- Trollhole distributor
- FJ60 alternator
- Diehard Platinum (Odyssey) 34/78 battery
Other
- (5) 15”x8” steel wagon wheels with weld-it-yourself beadlocks
- (5) 37x12.50x15 Maxxis Creepy Crawlers at ~90+% tread
- Full Metal Tech roll cage with seat cradle and tied into frame
- A to Z Fab DIY rear bumper with swing out
- Rock sliders with scab plates for frame
- Ruff Stuff Specialties rear frame box-in kit
- IPOR belly skid
- Metal Tech tube doors
- Hellfire Fabworks side mirrors
- Corbeau Baja Ultra suspension seats with PRP 4.2 harnesses
- ’93 Toyota T100 brake booster and 1-ton master cylinder
- Aisin clutch master and slave cylinders
- Zinc coated hard lines for brakes and clutch
- Saginaw power steering
- (2) 8 gallon forklift propane tanks (bought new)
- Bestop Soft-top (no doors)
- Trollhole trail top
The Cruiser is plated, but has not been inspected. It is probably 80% street legal for NY. The propane is tuned well – very little exhaust odor and doesn’t attract flies. As long as I can keep myself from breaking the transmission and engine, it wheels/crawls well.
Some general pics...
I have a bunch more pictures so just let me know what you would want to see.
Chris
'85 4Runner with stuff
EnginerdFJ is offline   Reply With Quote Quick reply to this message
Old 12-11-2015, 11:22 AM   #2 (permalink)
Moderator
RustyNailJustin's Avatar
Member # 8568
Thank you for doing a good writeup in your ad.
Build thread.
https://www.pirate4x4.com/forum/toyot...on-v1-1-a.html
KOH 2009 Team 435
KOH 2010, 2011,2012,2013,2014, 2015 Team 4431
EMC 4619 2014,2015,2016
TLCA# 5305
RustyNailJustin is offline   Reply With Quote Quick reply to this message
Old 12-14-2015, 04:55 PM   #3 (permalink)
Member # 66838
GLWS, Nice 40
JT
JT Automotive & Off Road Harrison Ar Shop 870 743 3188 Cell 870 204 2324
katesoffspring is offline   Reply With Quote Quick reply to this message
Old 12-16-2015, 06:10 AM   #4 (permalink)
Member # 178404
Originally Posted by katesoffspring View Post
GLWS, Nice 40
JT
Thanks bud
Old 12-16-2015, 07:02 AM   #5 (permalink)
Member # 44437
Really sweet 40 and exceptionally well built. Not pertinent the sale, but do you have any pics of the rear bumper and the double triangulated rear suspension? What did you build the links out of?
74Fj40 is offline   Reply With Quote Quick reply to this message
Old 12-16-2015, 07:22 AM   #6 (permalink)
Member # 178404
- 2 sq., 0.25 wall lower links with Ruff Stuff heims
- 1.5 sq., .120 wall upper links with Ruff Stuff heims
Only pics I have on my phone at the moment...
Old 12-16-2015, 07:04 PM   #7 (permalink)
Member # 85813
Great rig, not sure how I missed your build.
Looking at your pictures makes me miss my 40, I have one with a very close build sheet just rotting away in storage
Good luck with the sale!
E WHEELER is offline   Reply With Quote Quick reply to this message
Old 12-18-2015, 06:46 AM   #8 (permalink)
Member # 178404
Thanks E
Old 12-18-2015, 11:57 AM   #9 (permalink)
Member # 20378
I've always liked your rig. Sorry to see you sell but look forward to seeing what you do next!
Kuranosuke is offline   Reply With Quote Quick reply to this message
Old 06-16-2016, 09:17 AM   #10 (permalink)
Member # 178404
Welp my loss is your gain. Since the replacement engine is still not running the price has been dropped to $11k. At that price you're basically getting even more stuff for free. Quality parts, rust free body and good people helped me with it along the way.
Link to photobucket album Cruiser - For Sale Note: Powertank mount and fire extinguisher mount (on cage dash bar) are not included.
I would be willing to help with delivery (me towing) depending on location/distance. Should I get it running before it sells, the price goes back up. As always if you have any questions please speak up.
Chris
Old 06-28-2016, 01:04 PM   #11 (permalink)
Member # 178404
Sold. Thanks for playing along.
Old 06-28-2016, 01:42 PM   #12 (permalink)
Moderator
Member # 8568
Nice and congrats
KOH 2009 Team 435
TLCA# 5305
Old 06-30-2016, 07:31 AM   #13 (permalink)
OnTheSpot's Avatar
Member # 34900
Cool rig, new owner should enjoy it. So what's next
Applying the Beef Treatment
OnTheSpot is offline   Reply With Quote Quick reply to this message
Old 06-30-2016, 07:57 AM   #14 (permalink)
Member # 178404
Oh and the engine does run. The shop I bought it from adjusted the rockers such that there were valves always open, so when it's cranked whatever air was drawn into the cylinder was immediately blown right back out. Once that was fixed each cylinder tested to 150+ psi. It now purs like a 39yo kitten.
The new owner is a young kid, still an undergrad, but has been around Cruisers all his life. Used to get dropped off at grade school in a powder blue 40. He's been super excited each time he's come over my house, and had him over this past Saturday to help put the drivetrain back together and ask a bunch of questions. It should be in good hands.
Ahh the all important question of what's next... I tossed it around for a while. Ever since Goatbuilt came out I've wanted to build a one with Cruiser sheet metal. Unfortunately I know how long it took to build this 40, and new a buggy would take at least that long because of cash flow. Then there was the Grunt chassis from Bent Fabrications, dump a mini truck drivetrain in there and have some fun. But again I want to be wheeling sooner than later. So I'm keeping it simple and getting a semi-built '85 4Runner out of Texas that will get some money dumped into it.
I'm also hoping to be packing up the misses and moving to AZ in the next few years. We went to Phoenix in February and loved it. And when/if we move I'd rather have something that's easily tossed on a trailer versus packing up piles of parts and a chassis in a hopeful rolling form.
