semi-budget "1 TON" buildup thread - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-01-2006, 01:50 PM   #26 (permalink)
rockinfive+2's Avatar
Member # 2592
Send a message via AIM to rockinfive+2
Hurry up and get those axles in we have snow runs coming up
rockinfive+2 is offline   Reply With Quote Quick reply to this message
Old 12-01-2006, 03:10 PM   #27 (permalink)
rockthedog's Avatar
Member # 19510
you got that right!...........i just picked up the 60 from it's cutting.......i'll post up tonight
77fj40, 1 TON
530-268-9494
tlca# 12281
semi_budget 1ton build
linking the rear
rockthedog is offline   Reply With Quote Quick reply to this message
Old 12-01-2006, 07:38 PM   #28 (permalink)
one 55 guy's Avatar
Member # 78189
right on glen
now you"ll have a rubicon crawler !! want to follow me ???
& make a beater out of it ?? I"m happy for ya! also thanks for going to s&t with us !! we had a great time !!see ya 55guy out!
one 55 guy is offline   Reply With Quote Quick reply to this message
Old 12-01-2006, 08:30 PM   #29 (permalink)
rockthedog's Avatar
Member # 19510
no mike , THANK YOU for letting me ride along at snt that was an epic adventure for sure
i don''t know about following you , ive seen your rig do some incredible stuff
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-01-2006, 09:40 PM   #30 (permalink)
Member # 5600
About same setup as my Cruiser I just got done with..Except I'm still running rear 55 springs and flipped 40 front with SR...
....Pay close attention to engine placement for DL angles and fan clearence...
I'm running the master and adapter from Rockstomper..It stops on a dime with 39's
I scored a front 60 for a Blazer body..I traded a 10/12 bolt axle combo I got for free..The axle needed a complete rebuild...But what do you expect for nothing...It had 4:56's and a trash-loc..I traded the trac-loc for a brand new spool..Found the dually 14 bolt for 50 bucks..Had 4:56's too...
...On that 60...Try to rotate pinion up via rotating outer c's, if you can..You have to cut one off anyway..I didnt..And regret it...With front flipped springs and shackle revearsal.. I ended up with 12* of caster
...I just had Moser cut down the stock shaft..cost about 75 bones..used the savings on 35 spline outers and new u-joints....Hy-steer can be a bitch on a budget with a Scout 2 box..I'm going to go behind the axle with the TR when I get more mulla...
I ended up with a pretty flat belly with my SM420/300 combo...Not too bad on DL angles also.....
I love the end result..It wheels like mad and is soooo much more fun to drive..Good luck on your build..Feel free to pick my brain if you need to!
I got two things for sure in this world, my word and my balls. I'm not breaking them for anyone.
AZFJ is offline   Reply With Quote Quick reply to this message
Old 12-02-2006, 12:22 AM   #31 (permalink)
Member # 14437
Just finished mine with the same mind set. I'm still open in the front, spooled in the rear but it's a blast to wheel. I didn't cut mine down at all and LOVE the stability. I'm still getting used to the width but I love being able to stand on it when necessary (or just because) and send the 42s up in smoke. BTW, I went LOMAX for the case. For about $1200 (including $100 for a 205 core) I have 3:1 gears with 32 spline front and rear output. When I ran the numbers, I sold my 300 and scrounged the core 205 from Toploader.
freds40 is offline   Reply With Quote Quick reply to this message
Old 12-02-2006, 11:04 AM   #32 (permalink)
rockthedog's Avatar
Member # 19510
thanks for the input AZ and Fred...... nice to see a variation of the same plan, those are a couple nice rigs....and your both onthe brain picking list.
i'll get to do some shop time today to work on the axles...got the detroit in the 14b last night .....i'll post pics later
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-02-2006, 02:48 PM   #33 (permalink)
Member # 24859
Glenn, just curious, how close does your steering shaft come to hitting the frame ? or is it even close ? the one from the firewal to the box.
Mellonhead
peesalot is offline   Reply With Quote Quick reply to this message
Old 12-02-2006, 09:30 PM   #34 (permalink)
rockthedog's Avatar
Member # 19510
hey john i think it's an inch + or- i won't see it again till thurs.......
spent some time at FAO today.....we finished the 14 bolt ...neil showed me how to set the backlash(i never new )
so the 14 bolt has the detroit and 4:56 installed .
here's a lame pic of it sitting on the bench the lame part of it is me in the background playing with a new $25 drill bit
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-02-2006, 09:56 PM   #35 (permalink)
rockthedog's Avatar
Member # 19510
finally got all four hubs mated to the new 3/4ton rotors....but not without a little glich.
the rear dually hubs mated to the rotors w/o any problems
the front had issues.......i removed the 1ton rotor and in the process of putting the 3/4 ton rotor on ,the rotor cracked.....it seems the wheel stud from the 1ton has a slight extra shoulder on it that was a little larger than the hole ,probably less than a butt hair but enough to crack it.
solution: rather than find new wheel studs i brought a 1ton rotor to the hardware and found a drillbit that fit the larger hole...11/16 .....the parts runner showed up with the new rotor the same time i returned with the bit.
i drilled out the 3/4ton rotors and we were back in bussiness.......sucked cracking a brandnew rotor but oh well
here are the cracks.....i wish i would have got a pic of the different wheel studs
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-02-2006, 10:05 PM   #36 (permalink)
rockthedog's Avatar
Member # 19510
someone needs to tell me how to post multiple pics per post
here are the four amigos
the rears (left) also have the bearings races and seals in place.
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-02-2006, 10:17 PM   #37 (permalink)
rockthedog's Avatar
Member # 19510
i got my 60 back from WFO in grass valley........
it's now 4.5" shorter and the spring perch is relocated....to 27"cruiser width......nice little extra touch by Trevor, cutting the stock perch off and re-welding it.........i know i couldn't cut that thing off without mangling it
i also got my new 4340 dutchman longside inner i can't believe how beefy this thing is.....
lame axle pic:
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-02-2006, 10:22 PM   #38 (permalink)
rockthedog's Avatar
Member # 19510
a little comparison
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-02-2006, 10:26 PM   #39 (permalink)
rockthedog's Avatar
Member # 19510
of course i had to use a course spline birf to compare.....thats all that was laying around...... peesalot can relate, huh john
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-02-2006, 10:39 PM   #40 (permalink)
rockthedog's Avatar
Member # 19510
the 60 is getting it's ARB this week and wed night clint and i are heading up to start actually gettin busy on my 40........the 14bolt and rear 60 series springs are first to go in...........i'm ready!
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-03-2006, 08:00 AM   #41 (permalink)
rugburn's Avatar
Member # 45
Nice work.....
What was the charge from WFO to narrow the housing for the Dana 60?
John Runberg
Swedish American :usa:
rugburn is offline   Reply With Quote Quick reply to this message
Old 12-03-2006, 11:12 AM   #42 (permalink)
88 mangler's Avatar
Member # 31780
here is another one of you hard at work.
88YJ, d60 with some goodies&14bolt,atlas,111"wb,40"maxxis trepedors,some other stuff and 6 extra angry hampsters under the hood and a ATO built tf999!:D
tow rig: 07.5 6.7l dodge 2500
Dixon 4Wheelers
Build it, Break it,Fix it, Repeat!
88 mangler is offline   Reply With Quote Quick reply to this message
Old 12-03-2006, 12:31 PM   #43 (permalink)
Member # 5600
belly
Old 12-03-2006, 03:53 PM   #44 (permalink)
Member # 29301
lookin good Glen
And I was sooo looking forward to another midnight Cadillac trail-fix...NOT!
I hope this doesn't jinx your hi-lift streak
Clint,
Helping your old-man wrench on his rig, very Admirable.
You will never hear any comments about your rig from me...other then positive ones
1972 FJ40 - never ending project has been sold / 2005 Tacoma AC
TLCA 14254
mr_manny is offline   Reply With Quote Quick reply to this message
Old 12-03-2006, 04:59 PM   #45 (permalink)
Member # 24859
Not anymore amigo. My front has 4340 chromo inners , CTM's , dedenbear knuckles, NWF hi-steer, and 30 spline cheby outers.
The only thing you got on me is wb unless you got fuel injection.
Mellonhead
Old 12-03-2006, 05:11 PM   #46 (permalink)
Member # 2592
Originally Posted by mr_manny
Clint,
Dont tell Clint that he has a big head now dont feed him anymore .
Old 12-03-2006, 07:00 PM   #47 (permalink)
one 55 guy's Avatar
Member # 78189
belly pan ?
who built that skid plate ? whos rig is that on ??? very nice !!!
Right on CLINT !!!!! take care of your dad !!!
Old 12-03-2006, 08:38 PM   #48 (permalink)
rockthedog's Avatar
Member # 19510
Originally Posted by rugburn
Nice work.....
$150 to narrow the 60.........awesome shop....they were going to hook up with me on thanksgiving to meet my schedule and they been sharing there experience with the dana60 newbie..me. i've learned alot about building my axle from trever and bo....
that is one form fitting skid plate....nice!
manny i don't want to do anymore wrenching in the wee hours on caddy.....it's getting old. clint has definetly got my back! i don't need antmore hi-lifts.....iv'e won 3 in the last 3 years.
john , i will ALWAYS have more wheelbase than you , infact i'm grrabbin 3 more inches with this build
i wanna see that axle you built it sounds wild
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-03-2006, 09:52 PM   #49 (permalink)
88 mangler's Avatar
Member # 31780
lookin good Glen
Clint,
i dont know if you would call it help. all i have really done is do a lot of standing around. the time i did do something i cracked his rotor
clint
Dixon 4Wheelers
Old 12-03-2006, 10:00 PM   #50 (permalink)
Moderator
RustyNailJustin's Avatar
Member # 8568
Really like that belly pan
KOH 2009 Team 435
KOH 2010, 2011,2012,2013,2014, 2015 Team 4431
EMC 4619 2014,2015,2016
TLCA# 5305
RustyNailJustin is offline   Reply With Quote Quick reply to this message
