semi-budget "1 TON" buildup thread - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-03-2006, 10:05 PM   #51 (permalink)
rockthedog's Avatar
Member # 19510
Originally Posted by 88 mangler
i dont know if you would call it help. all i have really done is do a lot of standing around. the time i did do something i cracked his rotor
clint
i've had to do as much standing around as you , we'll be tearing into it this week
i'm glad it broke then instead of when i tightened the lug nuts later.......when i couldn't see the cracks
77fj40, 1 TON
530-268-9494
tlca# 12281
semi_budget 1ton build
linking the rear
rockthedog is offline   Reply With Quote Quick reply to this message
Old 12-04-2006, 09:44 AM   #52 (permalink)
sand dune coon's Avatar
Member # 57123
looking good glen.. nice build thread you got going here..
one question though,, If the spring perches on the gm dana 60 are 32" wide and your leaf spring width is 27" how did you guys come up with 4.5 inches to trim off and not 5 inches?
thanks
sand dune coon is offline   Reply With Quote Quick reply to this message
Old 12-04-2006, 04:23 PM   #53 (permalink)
Member # 5600
Originally Posted by one 55 guy
who built that skid plate ? whos rig is that on ??? very nice !!!
Thanx...Rick at Trick Toys Fab in LHC, AZ built it..its on my 40...Holding up the D300...Counter sunk allen screws...flat with bottom of the frame rails...
I got two things for sure in this world, my word and my balls. I'm not breaking them for anyone.
AZFJ is offline   Reply With Quote Quick reply to this message
Old 12-04-2006, 05:25 PM   #54 (permalink)
rockthedog's Avatar
Member # 19510
thanks
the spring perch on the pass side of the 60 is fixed into the centersection casting ........ the measurment from the pass side "c" to the center of the pass side perch has to match the measurment of the drivers side "c" to the center of the drivers side perch........in order to maintain the 27" measurment between the spring perches, the magic number to be removed from the long side(drivers side) is 4.5 inches.......keep in mind the axle is only being trimmed on one side , that is why there is a half inch measurment ........the other half inch is on the untrimmed side .
whew....did i overcomplicate that or what?
hope that helps
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-05-2006, 10:40 AM   #55 (permalink)
Member # 18993
gm dana 60's are 31.5 inch spring width
there, simplified in all its glory
R.I.P. RYAN
[QUOTE=Grumpy_old_fart;7711636]yeah, sure build it. drive it. can i get an insurance policy with your name on it, so i can be beneficiary when you die?[/QUOTE]
e-hills4x4 is offline   Reply With Quote Quick reply to this message
Old 12-05-2006, 12:58 PM   #56 (permalink)
Member # 31735
That works. Glen's explanation wasn't making any sense to me.
Cruiser is looking good. You should really put mogs under this thing though that way you can sell my the one ton stuff. I'm not used to how tippy my cruiser is now that its sprung over.
numtel is offline   Reply With Quote Quick reply to this message
Old 12-05-2006, 01:33 PM   #57 (permalink)
Wilson's Avatar
Member # 7233
thanks
because Chevy width is 31.5", dodge is 32-32.5"
Old 12-05-2006, 07:28 PM   #58 (permalink)
rockthedog's Avatar
Member # 19510
well who wants to do anything simple
ben , i won't sell my axles but i will sell you my 2.5"backspace 10x15 rockcrawlers......keep some of that tippy away
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-05-2006, 10:27 PM   #59 (permalink)
Member # 31735
I've got my 37's on 15x8 2" backspace. I am just used to being much lower. I'm done with school in a week and a half. I'll have to come by and see what you've got done and show you what's changed on my cruiser.
Old 12-07-2006, 10:36 PM   #60 (permalink)
rockthedog's Avatar
Member # 19510
well , clint and i got busy today.........
the goal was to remove old rear axle and 55 springs.....install 60 series rear springs,14 bolt and disc brakes.
i started off smacking my left elbow 4x's in the same spot in the first 15 min..... after that it went pretty smooth , except for the pounding in my elbow for the next 8 hours
we backed it in my folks garage and let all the air out of my sx's to get it in
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-07-2006, 10:38 PM   #61 (permalink)
rockthedog's Avatar
Member # 19510
took out the old goods.....i was thinking how long i waited to aquire all this stuff and now its coming out
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-07-2006, 10:45 PM   #62 (permalink)
rockthedog's Avatar
Member # 19510
to put the 60 springs in i had to modify the stock spring pins.....i popped the pin out of the 2 holed plate and drilled it out to fit a 4.5 inch 5/8 bolt also i used a thin shoulder 60 series 5/8 hole bushing from sor...i will put a part number in for the archives later.
the inside hole in the stock spring hanger had to be drilled to 5/8 as well.....
the part # for the bushings is.......
289-60-C ............when flipping 60 series spring for wheelbase and using these bushings, they fit my fj40 spring hangers perfectly.
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-07-2006, 10:46 PM   #63 (permalink)
rockthedog's Avatar
Member # 19510
another..........the bolts are tacked in three places .....crappy pic
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-07-2006, 10:47 PM   #64 (permalink)
rockthedog's Avatar
Member # 19510
springs
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-07-2006, 10:49 PM   #65 (permalink)
rockthedog's Avatar
Member # 19510
14 b install
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-07-2006, 10:50 PM   #66 (permalink)
rockthedog's Avatar
Member # 19510
in
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-07-2006, 10:52 PM   #67 (permalink)
rockthedog's Avatar
Member # 19510
the pinion angle is aprox and the perch is tacked enough to hold , and close enough to install the breaks
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-07-2006, 10:52 PM   #68 (permalink)
ROCK HUGGER's Avatar
Member # 4329
Those pins look familiar. How much more wb did it give you over the 55 springs.
Keep the pics coming
ROCK HUGGER is offline   Reply With Quote Quick reply to this message
Old 12-07-2006, 10:53 PM   #69 (permalink)
rockthedog's Avatar
Member # 19510
hubs on
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-07-2006, 10:55 PM   #70 (permalink)
rockthedog's Avatar
Member # 19510
i forgot to take a pic of the breaks mocked up for bracket location but i'm sure you can use your imagination
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-07-2006, 10:57 PM   #71 (permalink)
rockthedog's Avatar
Member # 19510
hubs back on....and by the way the ruffstuff brackets were a perfect fit ...very nice product. oh the super beefy 3 hole spring perches were perfect fit for the 14b as well
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-07-2006, 11:06 PM   #72 (permalink)
rockthedog's Avatar
Member # 19510
so the paint is drying on the calipers and stuff so well add a photo or two tomarrow.......we will mount the calipers and install the axle shafts and seal the diff cover ....add oil ...put on the dually rollers and i'll be pretty much done till next week......the dana 60 is back in vacaville getting the arb and inner seals
i won't be painting the 14b or pads or u- bolts black till the t-case and pinion angle are finished .....AFTER the spring pearches are finish welded in place
one more,,,,,,
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-07-2006, 11:12 PM   #73 (permalink)
rockthedog's Avatar
Member # 19510
hey david wazup
nice springs eh?
the best we could tell , the wheelbase is now about 102" that is 4 more than with the 55 springs
i used the rear hole on the spring perches as well....i only expected 3 more inches . so that extra inch was a bonus there will be some more trimming of the rear fenders.
thanks again david ....your the man
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 12-08-2006, 11:55 AM   #74 (permalink)
Member # 25622
Glenn, great write up and nice work on the axles. I am stoked for you.
With these longer springs do you plan to run an even longer shackle outback, or relocate the hanger? Seems the rig will sit lower because of more angle in the shackle, but I am guessing.
Will you put in the t-case before setting the pinion angle?
looks great!
Dustin
4Runner/ 325i / crf 50 / mini-trail 50, ttr 125 / wrf 450
Rockzar is offline   Reply With Quote Quick reply to this message
Old 12-08-2006, 01:27 PM   #75 (permalink)
rockthedog's Avatar
Member # 19510
hey dustin
the spring hanger was already flipped for the 55 springs....the overall length of 60 springs are the same as 55's...the center bolt is offset
the spring perches won't be welded until the d300 goes in...they are barely tacked for now.
well i'm back at it ...i will post more pics in a few hours
hi to becky and indi
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
