semi-budget "1 TON" buildup thread - Page 8 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-05-2007, 10:10 AM   #176 (permalink)
rockthedog's Avatar
Member # 19510
mc installed
EDIT: this mc was a piece of crap and the wrong one .....it was defective out of the box.
page 10 of this thread has the install and replumbing of the new one
77fj40, 1 TON
530-268-9494
tlca# 12281
semi_budget 1ton build
linking the rear
rockthedog is offline   Reply With Quote Quick reply to this message
Old 01-05-2007, 10:13 AM   #177 (permalink)
rockthedog's Avatar
Member # 19510
i got some lines plumbed, ss braided are in. and installed the drag link....today i'll do the tierod install shocks and hopefully finish the brakes...
brakes are a pain
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 01-05-2007, 04:19 PM   #178 (permalink)
TxCruzr's Avatar
Member # 9380
Send a message via AIM to TxCruzr
Glad to know your using 15" rims and they fit. I guess I better load up on dremmel grinding stones and start now
What brake setup are you using? It would be nice to have a working setup with front and rear disc that actually work for once.
For Sale!!
TxCruzr is offline   Reply With Quote Quick reply to this message
Old 01-06-2007, 11:26 AM   #179 (permalink)
rockthedog's Avatar
Member # 19510
i'm using gm 3/4 ton cal(8 lug), mid 80's vette mc....the rock stomper kit would prolly be easier and chea[er.....the vette mc is made for 4w disc ....i'll let you know how it works
4.5"angle grinder with the coursest wheel you can find and some ear plugs....7' grinder would be better
i've got to say plumbing an entire system from scratch is a BIG pain ...i'm sure next time will be easier after all was said and done the front are blead and work good the rear is leaking at the master. the mc is metric i found adapt for the small size two front brake ports however the rear single port is a 12mm #1 thread and an adpt was impossible to find here so a tube shop made me a custom line for it ......they put in a reg dbl flare brake line and needs to be what i would call a tapered pipe fitting.....now i'm on the lookout for this adpt...12mm#1 male 3/16 fmale
anyway it leaks at the arrow
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 01-06-2007, 11:27 AM   #180 (permalink)
rockthedog's Avatar
Member # 19510
some random pics
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 01-06-2007, 11:28 AM   #181 (permalink)
rockthedog's Avatar
Member # 19510
nuther
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 01-06-2007, 11:29 AM   #182 (permalink)
rockthedog's Avatar
Member # 19510
yo
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 01-06-2007, 11:31 AM   #183 (permalink)
rockthedog's Avatar
Member # 19510
i welde a couple 1/4"bolts to the center section to attch clamps for the line ...it's pretty secure
crimmy pic
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 01-06-2007, 11:32 AM   #184 (permalink)
rockthedog's Avatar
Member # 19510
tabs i made x4
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 01-06-2007, 11:34 AM   #185 (permalink)
rockthedog's Avatar
Member # 19510
got the steering done ...i put about a .25" toe in at the rotors for now..
does anyone know the best toe for a d60?
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 01-06-2007, 11:35 AM   #186 (permalink)
rockthedog's Avatar
Member # 19510
the steering is grey , somehow it looks blue
that's about it for now
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 01-06-2007, 12:01 PM   #187 (permalink)
rockinfive+2's Avatar
Member # 2592
Send a message via AIM to rockinfive+2
Glen might want to put a spring on each flex line and pin them next to the frame if not your tires will grab them and yank them off
rockinfive+2 is offline   Reply With Quote Quick reply to this message
Old 01-06-2007, 12:14 PM   #188 (permalink)
Member # 24859
Glen, 1/8 in at rotor & 1/4 if you are measuring at the tread. A 1/4 at rotor is a little much IMO.
Looks good.
Mellonhead
peesalot is offline   Reply With Quote Quick reply to this message
Old 01-06-2007, 03:56 PM   #189 (permalink)
OnTheSpot's Avatar
Member # 34900
I try and set toe in to about 1/8" at the tread. This has given me no issues thus far. Granted I still have a cruiser axle, but I don't see how a Dana 60 needs more toe in.
Applying the Beef Treatment
OnTheSpot is offline   Reply With Quote Quick reply to this message
Old 01-06-2007, 05:20 PM   #190 (permalink)
bkcruiser's Avatar
Member # 3396
Glen,
Isn't it going to be kinda hard to undo the u-bolt plates, with the brake line tabs welded to them?
Not that you would ever need to replace a center pin, but...
Originally posted by RustyNailJustin[QUOTE]There are no memories like those formed during unfavorable conditions. Anyone can wheel when it's nice out.[/QUOTE]
70fj55,37's,four shifters,cruise control,and a pig hood ornament!!! Also a mini truck that weighs alot less :)
bkcruiser is offline   Reply With Quote Quick reply to this message
Old 01-07-2007, 12:39 AM   #191 (permalink)
rockthedog's Avatar
Member # 19510
Originally Posted by bkcruiser View Post
Glen,
yah bill, i thought about that but i figured i would get away with it for now ......i will prolly move them to the axle tube someday ..... i wanted to leave the axle tube clean until shocks and trac bar are located.... the flexible ss lines ought to make it ok for now .....and no i don't plan on changing ant center pins right away unless i'm wheelin with you of course
i plan on putting the springs on next ken , i just ran out of time .......
i guess i'll move it to 8th inch toe ....unless someone can splain why i shouldn't
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 01-14-2007, 09:12 PM   #192 (permalink)
NORCALFJ40's Avatar
Member # 51625
Come awn Glenn, wheres da updates mang?? Im bored here!
NORCALFJ40 is offline   Reply With Quote Quick reply to this message
Old 01-15-2007, 09:59 AM   #193 (permalink)
88 mangler's Avatar
Member # 31780
no updates this week. he took the week off from working on it.
88YJ, d60 with some goodies&14bolt,atlas,111"wb,40"maxxis trepedors,some other stuff and 6 extra angry hampsters under the hood and a ATO built tf999!:D
tow rig: 07.5 6.7l dodge 2500
Dixon 4Wheelers
Build it, Break it,Fix it, Repeat!
88 mangler is offline   Reply With Quote Quick reply to this message
Old 01-15-2007, 06:14 PM   #194 (permalink)
rockthedog's Avatar
Member # 19510
i'll be working on it a little thurs. i'm getting the d300 together for now , and getting caught up on other stuff. i'll post up then.
one development however......i've come to the painful conclusion that to finish it as soon as i want i'm going to have to dump the 4:1 ........ i'm still going to try and do the hd outputs. unless someone wants to donate about $600
i still have fr n rr driveshafts to get and they won't be cheap......
the 4:1 will have to happen some other time....300's are pretty easy to pull when the time comes
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 01-15-2007, 10:19 PM   #195 (permalink)
NORCALFJ40's Avatar
Member # 51625
The 4:1 would be nice, but with that 1st gear on the 465, it should be plenty low enouh to get you by untill the 4:1 comes right?
Old 01-18-2007, 10:56 PM   #196 (permalink)
rockthedog's Avatar
Member # 19510
well i finally made it back up to GV and spent a day on the 40...nice and warm
didn't do a whole lot worth taking pics of but i know i like looking at peoples stupid pics as much as therir good ones
i picked up the adpt for the 12mm x 1 :3/16th....by looking at it you can see how the diff between them would cause the leak.
on the left is the custom 12mm fitting the right is the adpt.....the port in the master is a oppo image of the tip of the adpt.
obvious now why it was leaking
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 01-18-2007, 10:58 PM   #197 (permalink)
rockthedog's Avatar
Member # 19510
here is a shot of the line lock....i opted for the electric becuase i was too lazy to plumb the manual
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 01-18-2007, 11:00 PM   #198 (permalink)
rockthedog's Avatar
Member # 19510
some of these pics are a bit fuzy......
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 01-18-2007, 11:01 PM   #199 (permalink)
rockthedog's Avatar
Member # 19510
spring for the brake lines.....ken
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 01-18-2007, 11:03 PM   #200 (permalink)
rockthedog's Avatar
Member # 19510
the adpt
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
