Yoda Monster :full blown fj40 rear steer tube buggy - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-10-2011, 09:35 PM   #1 (permalink)
Member # 151427
Last picture taken.
yoda monster is standing on her own four feet now.
Large pile of 70s Jap rust
Double frame rail tube chassis
3800 super charged V6
904 trans
5.1 atlas
Raceline wheels
40/17 maxxis trepador tires
60 front w/PSC steering, Dynatrac chromoly shafts and joints, Dynatrac Hubs, Detroits w/5.13
60 rear w/PSC steering, cv shafts and joints, Detroits w/5.13
alu links johnnies on lowers, hiems on uppers
PRP seats
Griffin radiator and coolers
Vintage heat and air
Fiberglass hood, fenders and grill
most of the work is being done by Richard at The http://thehobbieshop.com/
Hard to say what it really is. It not a frame build since everything is tubed. Not really a tube buggy since it has a boxed cab. It will have some exo cage and some not. A real mixed up beast, just like I want it.
The build started out as a 4link on my YJ(pictured in the back of the second shot), in record time it got way out of hand. I took the jeep apart for the build and then decided that an FJ build would be better. Being a tube buggy it doesn't need much of the original truck the FJ laying outside of Richard's shop seemed liked perfect match.
At that point i dragged the FJ in and tore it apart.
Then Richard built the subframe for the drivetrain and for something that the body could
mount to. Dimple died engine mounts are sweet. Not really needed and you can't really see them but that is how he does things. Lots of cool touches if you look real close.
Then the REAL cutting began and it's not even close to being chopped yet. Richard cut
it up and put enough together to start framing the build.
The next big cuts will be under the door. It will have a major boat side with cutting board skids. Trying to keep it a low center of gravity, the design is centered around being able to slide over and threw stuff with ease.
I didn't want a full SUV like an FJ40 but the FJ45 offered way to little room in the cab.
When bouncing it freaks me out having metal and glass so close. Also will let me move the seat back and have room for stereo junk and a cooler inside the cab.
77 fj40 tube buggy
postaldave is offline   Reply With Quote Quick reply to this message
Old 02-10-2011, 09:36 PM   #2 (permalink)
Member # 151427
The back is shorter then an FJ40 but longer then an FJ45. Basically an FJ45 king cab.
Maybe an FJ46? If there was such a thing.
After that I put the hood and tires on to get an idea of the look. Me liky!
Tires in the pic are not spaced like we will have it and the whole buggy will be a little higher. Total of 116 wheel base is what we came up with.
Next update will have the boat side and the body tied in. Not sure when but there will also be a 6 to 8 inch square bed on the back to balance the look of the front hood.
77 fj40 tube buggy
Old 02-11-2011, 10:04 AM   #3 (permalink)
Member # 16988
fj46
where in KY are you? I love the ideas you've got going
wayneraintree is offline   Reply With Quote Quick reply to this message
Old 02-11-2011, 12:35 PM   #4 (permalink)
Member # 151427
I'm in lex but the build is in winchester
Never heard of 46. Maybe An FJ41 then?
77 fj40 tube buggy
Old 02-12-2011, 09:29 PM   #5 (permalink)
GLTHFJ60's Avatar
Member # 140040
Excellent build! I like the idea of a king cab FJ45
1987 4BTJ60 - MoonShine - 4BT/NV4500/EcoBox/NP205/D60/14B
2004 F-550 - 6.0/ZF6 - full bulletproof
GLTHFJ60 is offline   Reply With Quote Quick reply to this message
Old 02-12-2011, 11:49 PM   #6 (permalink)
Member # 166350
This is exactly what I want to build! Im going to be watching this one for sure!
McCready is offline   Reply With Quote Quick reply to this message
Old 02-13-2011, 05:25 AM   #7 (permalink)
Member # 151427
to get the king cab we cut the big window at the back right where the curve touched the flat of the top and bottom. did the same to the front small window and joined them together.
that took forever to figure out what length/which windows to use to make the total length of cab..
if you do it that was you can't use the small window because the shape is wrong but i'm just going to use lexan or whatever there.
77 fj40 tube buggy
Old 02-28-2011, 08:05 PM   #8 (permalink)
Member # 151427
Here is the latest goings on for the FJ project.
For the sides we went with a huge boatside and tapered them. This cut out most of the rust
and gave me the boatside I wanted. The tapered was added to deal with the FJ body that has
a taper to it. Along with matching that it serves a really cool function. When buggy is on a
rock on the boat side it will push the rear UP and OUT. This makes it more like a race boat
design rather then the basic john boat often put on a buggy with a boatside.
If you look close you can see Richard dimple the body mount. He really loves that tool and
not afraid to use it. I think it's cool as hell too. :jam
Keeping the rig with a very low COG it has to be able to slide very well. While the rig will look
like the width of a normal FJ in fact, the bottom will be VERY narrow and with the steep boatside
it should cut threw rocks like a boat in water. Putting on cutting board like skidplates will help.
I'm still not decided on the sides, having the cutting board stuff like i'll put on the bottom will
likely be the best. I'm thinking running aluminium on the boatside for looks. Not sure how much
drag compared to the cutting board material.
It will look like the rig will have ZERO floor space with the sides like that but in fact Richard
will be cutting in as channel on the floor for legroom. The center console will be higher and
will divide the interior like a rally car. One of the nicest touches is the door jam. Eventhough
the doors are cut way up they still will seal and keep out water and other stuff from coming
into the cab.
and finally the rear window. Just going with a plexi rear window an most of the time
just open but having a nice channel to put it in will be nice. Now that is what i call a rear truck window!
77 fj40 tube buggy
Old 02-28-2011, 10:09 PM   #9 (permalink)
Member # 85813
Diggin it. Please keep the updates commin!
E WHEELER is offline   Reply With Quote Quick reply to this message
Old 03-01-2011, 05:43 AM   #10 (permalink)
LC Hamma's Avatar
Member # 137
Ah yeah, at least you ain't slappin a 40 bezel on there and calling it a Cruzah Buggy. I like the fact you're keeping as much of the body as possible & blending new lines to mesh w/the ole classic lines What kind of bed or tube creation will there be in the rear?
'72 FJ55 & '73 FJ40
'91 Ram W250 5 spd. CTD SC/SRW
'93 Ram W350 5 spd. CTD SC/SRW
'99 Ram 3500 4X4 5 spd. CTD SC/DRW
'12 Alaskan Camper NCO
If you drive a watered down IFS Chebby & have a beard, shave it off
LC Hamma is offline   Reply With Quote Quick reply to this message
Old 03-01-2011, 07:18 AM   #11 (permalink)
Member # 29
BAD ASS!!!! I love the boatsides. Finally someone has some great pics of how tey are doing that. I think I may steal this idea. I REALLY like how you chopped the doors down to work with them as well.
Dima
FJ40 crawler, 2006 F250 for tow duties
Flatty is offline   Reply With Quote Quick reply to this message
Old 03-01-2011, 09:02 AM   #12 (permalink)
Member # 151427
The bed will start at the bar under the rear window. It will have a tube going around the base and one around the top. Should be about six to eight inches high with dimple died metal connecting them. Then bars from the top of cab to the rear of the bed.
77 fj40 tube buggy
Old 03-01-2011, 11:49 AM   #13 (permalink)
Member # 29
Can you get some pics of how you cut teh doors and closed them up.
Thanks
Dima
Old 03-01-2011, 02:42 PM   #14 (permalink)
Moderating Midget
wngrog's Avatar
Member # 1154
Send a message via AIM to wngrog
Awesome. Keep them coming.
Nolen Grogan
2016 4Runner TRD Pro
1998 Land Cruiser
1984 FJ-60
2013 RZR-XP4
USAF Veteran 1988-1998 GOD Bless America
wngrog is offline   Reply With Quote Quick reply to this message
Old 03-01-2011, 02:53 PM   #15 (permalink)
jedrattle's Avatar
Member # 21750
We love pictures around here!!
Team RattleKann
`73 Courier..all Yota underneath
`05 Cummins...tow ho
jedrattle is offline   Reply With Quote Quick reply to this message
Old 03-01-2011, 08:20 PM   #16 (permalink)
Member # 151427
alright picture whores. i'll get more of the doors.
no big deal on the doors, just cut them right at the bottom of the
lower door hinge. that real work was the building a channel that the
door would go into. really good work was done by him on that fab.
77 fj40 tube buggy
Old 03-01-2011, 09:00 PM   #17 (permalink)
Member # 177232
Very nice work!!!! Its funny how addicting this stuff gets. I havent finished one project and im already collecting parts to do another. I love what you are doing
RusowRacing is offline   Reply With Quote Quick reply to this message
Old 03-02-2011, 03:22 AM   #18 (permalink)
Member # 20907
Cool build. Good to see something a bit different and with more 40 panels then just a grill and bonnet.
2012 FJ Cruiser, 1984 BJ42 "Middy" Landcruiser, 1977 HJ45 Landcruiser, 1966 FJ45V Landcruiser
twisty_toy94 is offline   Reply With Quote Quick reply to this message
Old 03-06-2011, 04:19 PM   #19 (permalink)
Member # 63280
Send a message via MSN to brooksy1
I like it
Although I would bring the front diff back a bit towards the firewall. Make it 113" instead of 116".
brooksy
C44F-Custom 4x4 Fabrications Australia
Pro Mod LS1 buggy, FIREBUG Unlimited buggy & V8 FJ40
brooksy1 is offline   Reply With Quote Quick reply to this message
Old 03-06-2011, 07:11 PM   #20 (permalink)
Nightshade's Avatar
Member # 40793
Send a message via AIM to Nightshade Send a message via MSN to Nightshade Send a message via Yahoo to Nightshade
Love the idea of the king cab, subscribing to keep an eye on things.
I'd rather die on my feet than live on my knees.
Nightshade is offline   Reply With Quote Quick reply to this message
Old 03-07-2011, 08:27 AM   #21 (permalink)
Eskimo's Avatar
Member # 10429
Diggin' it.. keep 'em coming!
FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/ORI's/42's - Sold.
Eskimo is offline   Reply With Quote Quick reply to this message
Old 03-07-2011, 01:39 PM   #22 (permalink)
Member # 92812
Very cool.
1984 Toyota FJ60 Turbo Diesel Land Cruiser
Ducks is offline   Reply With Quote Quick reply to this message
Old 03-07-2011, 08:00 PM   #23 (permalink)
Member # 26149
Can you roll the windows all the way down?
Scooterloo is offline   Reply With Quote Quick reply to this message
Old 03-11-2011, 05:27 AM   #24 (permalink)
Member # 105385
That is speaking to me there!
You just going to tube out the bed or will it be a dovetailed "full " bed like a 45?
Love the design! really different!
87 samurai 3sp auto/1.8 kick tcase/4:1 dana300, yota axles, 4 link rear, 39" krawlers.. reds
build thread:
97 FZJ80 RCV birfs,chromoly rear axles,4.88s , 315 K02s
lenross1 is offline   Reply With Quote Quick reply to this message
Old 03-15-2011, 10:21 AM   #25 (permalink)
perfection in plasma
carslut's Avatar
Member # 25823
Send a message via ICQ to carslut
neat project
carslut is offline   Reply With Quote Quick reply to this message
